imagePROGRAF TZ-32000 MFP Z36
As low as $0.00
Out Of Stock
  • 36” Large Format Technical Documents Printer
  • Up to 4 24” x 36” size prints per minute*
  • Z36 Scanner with Advanced Editing & Networking Capabilities
  • Integrated Top Output Stacker
  • Standard Dual Roll Configuration with Hot-Swap Media Capability
*All speeds measured using plain paper, Fast Q5 mode. Print speed is based on internal testing. Print speed may vary depending on the number of copies selected, as well as on the settings for size, type, and orientation of paper.
Show more
Overview
Where Precision Meets Productivity
This 36" large-format technical documents printer is designed for optimal production, efficiency, and versatility, the imagePROGRAF TZ large-format printer is a cutting-edge hybrid solution. It stands out in the production aqueous inkjet market with its capability to print a wide range of output from monochrome line drawings to vibrant full-color posters on various media substrates. The Z36 scanner acts as a single-footprint and makes workflows easy and seamless with advanced editing capabilities and fast scanning speeds.
The
Fastest
imagePROGRAF.
EVER.
The
Fastest
imagePROGRAF.
EVER.
The Canon imagePROGRAF TZ-32000 MFP Z36
Key Features
Videos
Designed for high-speed production, efficiency, and versatility, the 36” imagePROGRAF TZ-32000 MFP Z36 is cutting-edge hybrid solutions that print up to 4 D-sized prints per minute—making them the fastest imagePROGRAF printers ever. This innovative series stands out by seamlessly producing everything from monochrome line drawings to vibrant full-color posters using the LUCIA TD 5-Color Pigment Ink System across various substrates. Time-saving features like hot-swappable ink tanks and intelligent media handling—which automatically detects media type, width, and remaining length—make operation completely effortless.
Additionally, the TZ-32000 MFP Z36 model expands workflow capabilities by allowing users to edit, deskew, and scan documents at impressive speeds of up to 13 inches per second.
imagePROGRAF eCarePAK Extended Service Plans
Extends service coverage beyond the initial warranty period for up to 5 years total coverage.
ecarepak logo
PosterArtist
Easily create posters and flyers from a free, web-based, template-driven poster creation application.
Bring Your Ideas To life
Everything Large Format at your Fingertips
The Canon Large Format Printer App gives users access to how to videos, printing and photo events, firmware and software updates.
person using phone
Large Format Media
Canon inks and media deliver exceptional beauty and longevity to your prints. We offer a wide range of media types including matte, canvas, glossy and adhesive backings.
A collage of various large format media
ENERGY STAR® Certified
Canon imagePROGRAF printers are ENERGY STAR® certified products. Products that earn the ENERGY STAR® label meet strict energy-efficiency specifications set by the U.S. EPA, helping you save energy and money while protecting our planet.
ENERGY STAR Certified
Main Unit Specs
Printer Type
5-Color 36-inch Printer
Technology
FINE (Photolithography Inkjet Nozzle Engineering)
Print Resolution (Max.)
2400 x 1200 dpi
Line Accuracy(1)
±0.1% or Less
Minimum Line Weight(2)
0.02 mm
Number of Nozzles
Matte Black: 5,120 Nozzles
Other Colors: 2,560 Nozzles per Color
Droplet Size
5 Picoliter
Ink Type
Pigment: Matte Black (MBK), Cyan (C), Magenta (M), Yellow (Y), Black (BK)
Nozzle Pitch (Head Resolution)
1200 dpi x Two Rows
Ink Tank
Shipped with Printer: 330ml MBK; 160ml BK, C, Y, M
Replacement: MBK/BK/C/Y:PFI-340(330ml)/PFI-740(700ml)
M:PFI-341(330ml)/PFI-741(700ml)
Ink Supply Method
Tubing System with Sub-tanks for Continuous Ink Supply
Nozzle Recovery System
Non-firing Nozzle Detection and Compensation
Printer Controller
L-COA PRO
Printer RAM
128 GB (Virtual) 2 GB (Physical)
Hard Drive
500GB (Encrypted)
Media Feed
Roll Feed: Two Rolls, Front Loading
Cut Sheet: Front Loading
Media Width
Roll Feed: 8" - 36" (203.2 mm – 917 mm)
Cut Sheet: 8" - 36" (203.2 mm – 917 mm)
Printable Margins
Roll Feed: All Sides: 0.12" (3 mm) or 0" for Borderless
Maximum Print Length (Single Page)(3)
Roll Feed: 59' (18 m)
Cut Sheet: 24" (610 mm)
Borderless Printing Widths (Roll Media Only)
Custom roll width 8" - 36" with micro margin technology
Media Cutter
Automatic horizontal rotary cutter
Media Thickness
0.07 mm - 0.8 mm
Media Core Size
2" with 3" Core Adapters Included
Maximum Roll Outer Diameter
6.9" or less
Media Output
Front Output: Basket
Top Output: Stacker
Operating System
Windows 11 Enterprise LTSC (x64)
Printer Language
SGRaster, HP-GL/2, HP RTL, PDF, JPEG, CALS G4
Interface
USB B Port
Type: Built-in (Hi-speed USB)
Mode: Full Speed (12-Mbit/sec.), High Speed (480-Mbit/sec.), Bulk Transfer Connector Type: Series B (4 Pins)
USB A Port: Direct USB Thumb Drive Printing
Gigabit Ethernet
Type: Built-in
Standard: IEEE 802.3u 100Base-TX/Auto-Negotiation, IEEE 802.3ab 1000Base-T/Auto-Negotiation, IEEE 802.3x Full Duplex
Protocol: SNMP, HTTP, TCP/IP (IPv4/IPv6), FTP
Wireless LAN
Standard: IEEE802.11n/IEEE802.11g/IEEE802.11b(4)
Security: WEP (64/128-bit), WPA-PSK (TKIP/AES), WPA2-PSK (TKIP/AES)
Power Supply
AC 100 - 240 V (50 - 60 Hz)
Power Consumption
Maximum: Approx. 111 W
Standby: Approx. 1.6 W
Power Off: Approx. 0.1 W
Certifications
ENERGY STAR®, TUV, CB, EPEAT Gold®
Operational Environment
Temperature: 59° F - 86° F (15° C - 30° C)
Relative Humidity: 10 - 80% (No Condensation)
Printer Dimensions
(W x D x H): 60.9" x 37.8" x 46.8"
Weight: 454.2 pounds (Approx.)
Package Dimensions
(W x D x H): 67.1" x 37.2" x 54.1"
Weight: 612.9 pounds (Approx.)
Options
  • 2"/3" Roll Holder Set (RH2-34)
User-Replaceable Items
  • Ink Tank (MBK/BK/C/Y: PFI-340/PFI-740; M: PFI-341/PFI-741)
  • Print Head (PF-06)
  • Maintenance Cartridge (MC-30)
Scan Speed(5)
  • 24-bit Color @ 200 dpi: Up to 3" per second
  • 8-bit Grayscale and Monochrome @ 200 dpi: Up to 13" per second
Copy Speed
24-bit Color @ 200 dpi: Up to 6" per second
Color Space
sRGB
Maximum Resolution
1200 dpi (Optical)
Scan Accuracy(6)
±0.1% : ±1 pixel
Maximum Scan Width/Maximum Media Width
36"/38"
Maximum Scan Length
164’ (PDF); 315" (JPEG); 598" (TIFF)
Maximum Media Thickness
0.003" - 0.04" (0.07 mm - 1.0 mm)
Digital Imaging Technology
Contact Image Sensor (CIS) Technology
(SingleSensor Assembly)
  • 24-bit RGB
  • 16-bit grayscale image capture
  • Panchromatic monochrome and black and white
  • Bi-directional LED light system for optimum object illumination and instant-on scanning capability
Included Software
SmartWorks MFP Scan-to-Copy/File/Email with Real-time Image Viewer; supports TIFF, JPEG, and PDF
Scanner Interface Kit
3x USB 3.2 and 1x USB 2.0 rear and 1x USB 3.2 front, all type A
Operating Environments
10°C - 35°C, 10 - 90% RH, Non-condensing
External Power Supply
100 - 240 VAC Autosensing +/- 10%, 50 - 60 Hz
Scanner Power Consumption
  • Controller Power: 35W"
  • Sleep: 0.2 W
  • Idle: 12.4 W
  • Scanning Color/Grayscale at 200 dpi: 22.7 W/23.3 W
Compliances
ENERGY STAR®, CB(62368-1), CE, FCC(EMC), Cul/UL, CCC, NOM-019, EAC, C-TICK, VCCI, BIS, EMC +LOA, UL AR, WEEE, REACH, RoHS, EU - Tier 3 of Lot 6
Z36 Package Dimensions (W x D x H) and Weight
(With Stand, Pallet, and Scanner)
50" x 17" x 19.5", 75 lb. (Approx.)
Disclaimers
  1. Line accuracy repeatability is guaranteed after a user performs the necessary adjustment and under the same environmental conditions. Applies to media for line drawing (Plain Paper, Coated Paper, CAD Translucent Matte Film, and CAD Tracing Paper) only.
  2. Theoretical value based on data resolution.
  3. The maximum printable length varies depending on the application, OS, and RIP used.
  4. Wireless printing requires a working network with wireless 802.11b/g or 802.11n capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
  5. The scan rate is proportional across the full range of resolutions supported by the scanner. Actual scan times will depend on the host system performance. Quoted top speeds may be limited by the effective bandwidth of the USB 2 and is not guaranteed for all media types.
  6. The quoted scan accuracy may vary depending on the operating environment and the thickness of the media.
Resources
File Name
Canon imagePROGRAF-TZ-Series Brochure
Date
10.16.26
File Size
4.1 MB
File Name
Canon Large Format Full Line Brochure
Date
10.21.26
File Size
10.5 MB
Sort By:
Untitle Video
Deadlines don't wait, and neither should you. With the imagePROGRAF TZ-32000, users can print up to 4 D-sized print per minute, hot swap ink tanks, and with features like intelligent media handling which automatically detects the type, width, and remaining amount of media once loaded make operation a breeze. Plus, with the TZ-32000 MFP Z36 users can edit, deskew, and scan documents in monochrome at up to 13 inches per second at 200 dpi. The imagePROGRAF TZ-32000 Series, innovative technology for those who move quickly.
Product Disclaimer
Recycled paper, chlorine-free paper, and office paper with 100% post-consumer recycled content that meets the paper runnability performance requirements of EN 12281 can be used with this product.
*The imagePROGRAF TZ MFP Z36 system contains multiple components, some of which are manufactured by third parties. To the extent that such third-party offerings come with limited warranties, those such limited warranties are hereby passed to the purchaser, and Canon shall have no obligation.
  1. All speeds measured using plain paper and fast Q5 mode. The 14 secs/ANSI D print is measured after first printout. The 244 ANSI D prints/hour is measured from when the first print begins printing and includes time taken for necessary cleaning and cutting.
  2. Plain Paper, Fast (Q5) mode.
  3. Canon products offer certain security features, yet many variables can impact the security of your devices and data. Canon does not warrant that use of its features will prevent security issues. Nothing herein should be construed as legal or regulatory advice concerning applicable laws; customers must have their own qualified counsel determine the feasibility of a solution as it relates to regulatory and statutory compliance. Some security features may impact functionality/performance; you may want to test these settings in your environment.
  5. For imagePROGRAF Printer Driver. For printing from PostScript applications such as Adobe Illustrator or QuarkXpress, please use a PostScript compatible RIP package. For a list of Canon recommended RIP packages, please consult with Canon Alliance and Industry Market list of RIP vendors.
  6. Your server must be compatible with a webDAV enabled cloud account, including but not limited to, Google, Carbonite or Rackspace, to take advantage of the cloud functionality. Storage capacity and any pricing thereof are based on the third-party cloud provider's current offering, at its sole discretion. Your cloud account is subject to the third-party cloud provider's terms and conditions.
