Out Of Stock
imageRUNNER 1643P
IR1643P 120V
As low as $0.00
Out Of Stock
  • Print up to 45 ppm (BW)
  • Print up to 8-1/2” x 14”
  • 2,300-sheet maximum paper capacity
  • Black-and-White
  • Compact
  • User-Friendly
Return Policy
imageRUNNER 1643 Series Brochure
imageRUNNER 1643P
MAIN UNIT
TYPE
Monochrome Laser Printer
CORE FUNCTIONS
Print
PROCESSOR
Canon Dual Custom Processor2 (Shared)
OPERATION PANEL
5-Line LCD Panel
MEMORY
1.0 GB RAM
INTERFACE CONNECTION2
1000Base-T/100Base-TX/10-Base-T
Others (Standard): USB 2.0 (Host) x3, USB 2.0 (Device) x1
PAPER SOURCES (LETTER, 20 LB. BOND)
Standard: 550-sheet Paper Cassette, 100-sheet Stack Bypass
Optional: 550-sheet PAPER FEEDER PF-C1 (up to 3) Maximum: 2,300 Sheets
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND)
Maximum: 150 Sheets
SUPPORTED MEDIA SIZES
Cassette: Letter, Legal, Statement, Executive Bypass: Letter, Legal, Statement, Executive, Custom size
(3" x 5" to 8-1/2" x 14"), Envelope (C5/DL/ COM-10/Monarch)
SUPPORTED MEDIA WEIGHTS
Cassette: 16 lb. Bond to 32 lb. Bond (60 to 120 g/m2)
Bypass: 16 lb. Bond to 73 lb. Cover (60 to 199 g/m2)
PRINT SPEED (BW AND COLOR)
Up to 45 ppm (Letter); Up to 36 ppm (Legal)
WARM-UP TIME
From Power On: 30 Seconds or Less3
From Sleep Mode: 3 Seconds or Less
DIMENSIONS (W x D x H)
16-1/8” x 14-13/16” x 10-13/16” (409 mm x 376 mm x 275 mm)
INSTALLATION SPACE (W x D x H)
24-5/16” x 43-7/16” (617 mm x 1104 mm)
WEIGHT4
Approx. 25.3 lb. (11.5 kg)
PRINT SPECIFICATIONS
FIRST-PRINT-OUT TIME (LTR)
Approx. 5.7 Seconds
PRINT RESOLUTION (dpi)
600 × 600
STANDARD PAGE DESCRIPTION LANGUAGES
UFR II LT, PCL®5e/6, Adobe® PS® 3 (Standard on 1643iF/1643P, optional on 1643i) Optional: Barcode Printing Kit
DIRECT PRINT
Supported File Types:
TIFF, JPEG, PDF and XPS (only LPR) Available from USB memory, LPR
OPERATING SYSTEM
Windows 10/8.1/7 (32/64 bit), Windows Server (2019/2016/2012 R2 (64 bit)/2012 (64 bit)/ 2008 R2 (64 bit) /2008 (32/64 bit), Mac® (OS X 10.6 and later => 10.9 ~ 10/14) Linux (Web Distribution)
PRINT FEATURES
Suspend Job Timeout, Profile Settings, Secure Print, Header/ Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Front/ Back Covers, Toner Reduction, Poster Printing
STORE SPECIFICATIONS
MEMORY MEDIA
Standard: USB
SECURITY SPECIFICATIONS
AUTHENTICATION
Standard: Department ID
Optional: uniFLOW and uniFLOW Online
NETWORK
Standard: IP/Mac Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6
DOCUMENT
Standard: Secure Print
ENVIRONMENTAL SPECIFICATIONS
POWER REQUIREMENTS
120-127 V, 60 Hz, 7.1 A
PLUG (MAIN UNIT)
NEMA 5-15P
POWER CONSUMPTION
Maximum: Approx. 1370W
Sleep Mode: 1.9 W5
Typical Electricity Consumption (TEC) Rating6 0.50 kWh
STANDARDS
ENERGY STAR® Certified
Rated EPEAT® Silver1
CONSUMABLES
TONER
Toner T06 Black
TONER YIELD (ESTIMATED @ 5% COVERAGE)
20,500 Images (Estimated Yield @ ISO 19752 Coverage)
FOOTNOTES
  1. For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
  2. imageRUNNER 1643P model does not have direct connection capabilities, and does not come standard with Wi-Fi.
  3. Time from device power-on until copy ready (not print reservation).
  4. Includes consumables.
  5. 1.9 W Sleep mode not available in all circumstances due to certain settings.
  6. Based on ENERGY STAR Product Specification for Imaging Equipment Version 3.0.
NOTE: Check for availability and details for uniFLOW solutions.
