IX-R7000 Card & Badge Printer
As low as $0.00
Out Of Stock
  • Thermal retransfer sublimation
  • Edge to edge printing
  • Supports CR80 size plastic cards
  • Prints up to 145 cards (single), 72 cards (double) per hour
  • Print resolution up to 600 dpi
  • Encoder or laminator option available
Show more
OVERVIEW
The Canon IX-R7000 ID card & badge printer is designed to produce photo quality images with edge to edge printing on dual-sided ID cards with speed and efficiency.
LX-D5500
ABOUT THE IX-R7000 CARD & BADGE PRINTER
WIDE VARIETY OF USES
Engineered for speed and capable of high-quality output, the IX-R7000 printer is ideal to produce single and dual-sided cards in vibrant color.  For ID cards, visitor badges, loyalty cards, membership cards, hotel room keys, gift cards, business cards, and even access control cards, over-the-edge printing can deliver the professional look needed in sectors like education, accommodations and hospitality, retail, administrative & support services, government and more. Printing cards on-demand allows users to print what is needed when it is needed, so there is no need to maintain a large inventory.
HIGH PERFORMANCE
The IX-R7000 printer is fast and can print up to 145 cards per hour, with a single-sided card printing in approximately 25 secondsFootnote1. And with a high-capacity feed hopper of up to 250 cards and the ability to refill cards while printing, performance is maximized.
EASY TO INSTALL AND USE
The IX-R7000 printer has a small, compact footprint, allowing it to easily be installed on a desktop or under a counter.  The easy to read LCD display and straightforward operation buttons make the printer simple to use.
DESIGNED WITH SECURITY FEATURES IN MIND
The IX-R7000 printer card feed hopper can be removed and stored separately while not in use to help keep blank cards secure. In addition, the printer is designed with a slot to attach a security cable lock to help protect against device theft.
OUTSTANDING PRINT QUALITY
Professional-looking crisp and clear photo-quality card images are produced by the IX-R7000 printer with up to 600 x 600 dpi resolution using dye-sublimation thermal retransfer printing. Printing on the front and back of cards, along with edge to edge printing, help create a high-quality high-resolution finished product quickly.
ENCODER ACCESSORY OPTION
The encoder accessory option can be used to put almost any type of information onto a smart card printed on the IX-R7000 Card & Badge Printer.  The optional encoder accessory supports two types of smart cards: contact smartcard interface, contactless smartcard interface.
LAMINATOR ACCESSORY OPTION
The laminator accessory optionFootnote7can be fully integrated into the IX-R7000 Card & Badge Printer to streamline the process of card printing and lamination.  The laminator accessory provides dual-sided lamination, which helps to preserve and protect cards by adding additional durability and security features.
CUSTOMER CARE
For investment protection, eCarePAK extended service planFootnote2 options are available beyond the initial two year on-site limited warranty period. An eCarePAK can help save on costs associated with post-purchase maintenance and help maximize uptime throughout the product life.
BarTender
BarTender
Download Your 30-Day Free Trial
TEKLYNX
TEKLYNX
Main Unit Spec
Printer
Printing Method
Dye-Sublimation / Retransfer
Print Speed (up to)
Single Sided: Footnote1
Approx. 25 Seconds/Card (YMCK)
Max. Print Speed 145 Cards Per Hour (YMCK)
Dual Sided: Footnote1
Approx. 50 Seconds/Card (YMCKK)
Max. Print Speed 72 Cards Per Hour (YMCKK)
Print Resolution (Up to)
600 x 600 dpi
Card Sizes
Card Size
CR-80 Size (2.1" x 3.4" / 54 x 86.5 mm)Footnote2
Maximum Printable Area
Width: 54 mm
Length: 86.5 mm
Card Thickness
Card Thickness
30 mil - 39.3 mil (0.76 - 1.0 mm)Footnote2
Card Compatibility
Card Types
PVC Plastic Cards
Body Durability
100,000 Cards / 5 YearsFootnote1
Card Capacity
Hopper Capacity
250 Cards (30 mil (0.76 mm) Thickness/Card)Footnote2
General
OS Compatibility
Windows 10, 11 (64/32 bit), 8.1 (64/32 bit), 7 SP1 (64/32 bit), Server 2008 R2 (64 bit)Footnote3
Standard Interface
USB 2.0
Ethernet (10/100/1000Base-T)
RS-232C
Power Source
AC 100-240V, 50/60Hz
Power Consumption (approx.)
Maximum: Approx. 300 W
Dimension (W x D x H)
11.7" (W) x 13.4" (D) x 17.2" (H)
Weight
42.8 lbs.
Operating Temperature:
Temperature: 50° - 95°F (10° - 35°C)
Operating Humidity:
Humidity: 20-80% RH (Non-Condensing)
Noise
Acoustic Information
Operating Noise (Max.): 58dB or lessFootnote4
Standby Noise: 35dB or lessFootnote4
Warranty
2 Year WarrantyFootnote5
Color/Monochrome
Full Color or Monochrome Printing
Print Modes
Single Sided (Simplex) / Dual Sided (Duplex)
Removable Card Hopper
Yes
Consumable Types
Ink Ribbons: IXR-YMCKK or IXR-YMCK
Retransfer Film: IXR-RFILM
Print Mode Detail
Single Sided (Simplex): Color / Monochrome
Dual Sided (Duplex): Side 1: Color (YMCK) / Side 2: Monochrome (YMCKK)
Print Yields
IXR-YMCK: 500 Cards (Single Sided: ColorFootnote1)
IXR-YMCKK: 400 Cards (Double Sided: 1st Side Color, 2nd Side Monochrome)Footnote1
IXR-Film (Transfer Film): 500 Cards (Single Sided)Footnote1
Operational Method
LCD: Yes (2 Line LCD - 16 Character)
Buttons/LEDs: 4 Buttons / 1 LEDs
Anti-Theft Wire Lock Security Slot
Built-in
Resources
File Name
Canon IX-R7000 ID Card Printer Encoder Accessory Brochure
Date
07.24.26
File Size
0.1 MB
File Name
Canon IX-R7000 Card & Badge Printer Brochure
Date
08.03.26
File Size
0.8 MB
File Name
Canon IX-R7000 Service and Support Brochure
Date
08.03.26
File Size
3.3 MB
Sort By:
Untitle Video
Identity management is a major initiative in today’s healthcare environments. When outdated badge production practices became a significant roadblock for one home healthcare agency, they turned to Canon technology for a solution to help enhance security, control costs, and centralize operations. Watch this Customer Chronicle to discover how Canon’s IX-R7000 ID card printer and BarTender software supported their in-house badge printing process.
Untitle Video
The Canon IX-R7000 Card and Badge printer will print access control and time & attendance security badges along with promotional ID cards featuring full over-the-edge printing and an optional encoder for use with CR80 cards.
Product Disclaimer
  1. Based upon standard print condition print size of 2.1"x3.4" inkjet coated CR80 PVC card at 30 mil (0.76mm) thickness, 80 cards/day. Print speed based on click to drop, average print coverage, with USB connectivity, Cards Per Hour (CPH).
  2. Card material compatibility may vary. Supported card materials include; PVC,PET-G, PET, composite PVC and PC cards, CR-80 size, measured at 30 mil (0.76 mm) thickness, in regards to ISO 7810. Certain restrictions may apply.
  3. Operation can only be guaranteed on a PC with pre-installed Windows® 11 (64/32-bit), Windows® 10 (64/32-bit), Windows 8.1 (64/32-bit), Windows 7 (64/32-bit).
  4. Acoustic noise is based off the measurement following ISO7779, and the display number shall follow ISO9296.
  5. Warranty and Support programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details.
  6. Printer weight measured excluding IXR-YMCK, IXR-YMCKK, or IXR-RFILM installed.
  7. A separate Installation service package is required for the installation of the IX-R7000 encoder and/or laminator.
