Tungsten AutoStore
AS 5-49 1Y
As low as
$0.00
Out Of Stock
- Multichannel Capture Integration
- Optical Character Recognition (OCR)
- Document Conversion
- Electronic Forms Processing
- System-to-System Connectors (40+ pre-built connectors)
- Business Process Automation and Workflow Support
Show more
Need to order more than 10?
Learn More
Need help making a purchase? Contact a Sales Expert at 800-385-2155>
Return Policy
Out Of Stock
Hardware Requirements | |||
Small Deployment Recommendation | Medium Deployment Recommendation | Large Deployment Recommendation | |
CPU | Single Dual-Core Desktop CPU: 2 GHz or higher | XEON or Opteron CPU: 2MB or more 2nd level cache1 or 2 CPUs/cores | XEON or Opteron CPU: 2MB or more 2nd level cache Multiple CPUs/cores |
RAM | 2 GB | 2-4 GB | 4 GB+ |
HDD | 10 GB | 40 GB | 100 GB |
Network | 100 Mbs | 100/1000 Mbs | 1000 Mbs |
Usage | Small Branch Office | Small to Medium Branch Office or MFP Hub Server | Single Enterprise Server or Processing Slave |
Software Requirements Hardware
- Microsoft® Windows® operating system (OS) running on computer with at least a 2 GHz Processor
- Minimum 2 GB of RAM is necessary but 4 GB or greater is recommended
- Minimum of 10 GB of hard disk space-NIC Card
Operating Systems
- Supported Microsoft® Windows® operating systems:
- Windows Server 2012 R2: Standard and Datacenter
- Windows 8.1 (3264 bit): Pro and Enterprise
- Windows 7 (3264 bit): Professional, Ultimate, and Enterprise with the latest service pack
- Windows 10
Additional Software
- Microsoft® .NET Framework 3.5
- Microsoft® .NET Framework 4.0
- Microsoft® .NET Framework 4.5
Resources
File Name
Tungsten AutoStore Brochure
Date
04.01.26
File Size
0.9 MB
Product Disclaimer
- Canon offers products that contain certain security features, yet many variables can impact the security of your devices and data. Canon does not warrant that use of features will prevent security issues. Nothing herein should be construed as legal or regulatory advice concerning applicable laws; customers must have their own qualified counsel determine the feasibility of a solution as it relates to regulatory and statutory compliance. Some security features may impact functionality/performance; you may want to test these settings in your environment.
- Canon U.S.A. does not provide legal counsel or regulatory compliance consultancy, including without limitation, Sarbanes-Oxley, HIPAA, GLBA, Check 21 or the USA Patriot Act. Each customer must have its own qualified counsel determine the advisability of a particular solution as it relates to regulatory and statutory compliance.
- A list of compatible and supported devices may be accessed at .
- Subscription to a third party service may be required. Subject to third party provider terms and conditions. A complete list of compatible route destinations can be found at www.kofax.com/.
- Kofax AutoStore 8.0 utilizes AES 256, SHA-2 256, and SHA-2 512, ECDSA 256 for document encryption. Communications encryption is HTTPS and SSL.
