LG-P800 Pigment-Based Inkjet Label Printer
- Designed for printing high-quality labels with reliable performance
- Print up to 8.5” wide on matte or glossy labels using roll or fan folded media
- Up to 1200 x 1200 dpi resolution
- Prints full bleed labels up to 8.5” wide
- Equipped with a 4.3-inch LCD touch panel
- Sub-ink tank system designed to enable printing with minimal interruptions
- ENERGY STAR® Certified
In the box
Overview
High-Mix, Versatile, Full-Color Label Printing
Canon’s LG-P800 8” pigment-based color inkjet label printer is designed for printing high-quality labels with reliable performance. The pigment-based inks help provide labels for a wide range of business applications. The impact of color can help you as you grow your business including as part of your brand recognition strategy. Canon’s LG-P800 can help you with efficient operations.
Features
Wide Variety of Uses
The LG-P800 printer is designed to handle a diverse range of labeling needs, including food and beverageFootnote1, cosmetics, home goods, product packaging, product identification, inventory, shipping, retail, horticulture and more. Its pigment inks are formulated to resist water, smudging, and fadingFootnote2, making the labels suitable for various environments. Additionally, the ability to print on-demand can help reduce storage needs and waste by allowing users to print the quantity required—whether for a single sample or a large production run.
High-Quality Images
With up to 1200 x 1200 dpi resolution, the LG-P800 is designed to deliver clear variable data, barcodes, QR codes, and graphics on both matte and gloss inkjet-compatible mediaFootnote2 2” - 8.5” wide, along with full edge-to-edge printing. This helps support professional-looking labels.
Easy to Use
The LG-P800 printer is equipped with a 4.3-inch LCD touch panel for a great user experience, making it easy to check the printer status and adjust settings. Automatic paper type detection helps so the optimal print settings are applied. The LG-800 has a built-in auto-cutter for workflow efficiency. Equipped with a 500GB HDD, users can easily reprint stored jobs directly from the printer without accessing a PC.
Flexible Media Adaptability and Powerful Performance
The LG-P800 printer is designed to handle a wide variety of label sizes and materials. The Media Configuration Tool (MCT) allows users to easily configure settings for the different media types.
Sub-Ink Tank System
The sub-ink tank system is designed to enable printing with minimal interruptions, helping users to maintain productivity. It allows virtually all the available ink in a tank to be used before having to replace it, helping to limit wasted ink. The ink tanks can also be replaced on-the-fly, without stopping the printer. This can be extremely useful during long print runs.
Non-Firing Nozzle Detection and Compensation
Ink ejection conditions are precisely checked with sensors, and when a blockage is detected, another nozzle automatically provides backup. In addition to helping limit printing failures due to banding, this technology is also designed to help reduce the frequency at which printhead cleaning and replacement is required.
Environment in Mind
The LG-P800 label printer enables on-demand label production, which can help reduce excess inventory and minimize material waste. It also meets ENERGY STAR®Footnote3 guidelines for energy efficiency.
Customer Care
For investment protection, eCarePAK extended service planFootnote4 options are available beyond the initial two year on-site limited warranty period. An eCarePAK extended warranty can help save on costs associated with post-purchase maintenance and help maximize uptime throughout the product life.
Main Unit Spec
Brochures
LG-P800 Service and Support Brochure
01.08.26
12.1 MB
LG-P800 Label Printer Brochure
01.08.26
0.9 MB
Product Disclaimer
- Print speeds may vary depending on system configuration, interface, software, print complexity, print mode, page coverage, type of paper used, etc. Excludes pre-cleaning.
- Operation on PC with pre-installed Windows 11 (64 bit) , 10 ( 64 or 32 bit ), Windows Server 2016,2019,2022 Standard.
- Acoustic noise is based off the measurement following ISO7779, and the display number shall follow ISO9296.
- Warranty and Support programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details.
