LX-P1300 Pigment-Based Inkjet Label Printer
LX-P1300
As low as $4,487.00
Out Of Stock
  • Pigment-based ink for durable and long-lasting labels
  • Prints up to 2" wide
  • Fast first print out time: 10 seconds or less
  • Print resolution up to 1200 dpi
  • Built-in auto cutter unit
  • USB and Ethernet connectivity
Show more
OVERVIEW
The Canon LX-P1300 inkjet label printer is a small, pigment-based printing solution built to quickly and easily print color labels with accurate graphics used for shipping, inventory, product packaging, and many other areas.
LX-D5500
ABOUT THE LX-P1300 PIGMENT-BASED INKJET LABEL PRINTER
MANY USES
The LX-P1300 printer is ideal for printing in color affordably and on demand, providing items with longlasting identifying markings. Transportation and warehousing labels (shipping and inventory), manufacturing labels (food and beverage, health and beauty packaging), retail labels (pharmacy medication instruction), and general product labels can be printed on-demand in short run lengths. Printing labels on-demand rather than printing large volumes in advance can save on storage space and
excess label media costs. Other uses for the LX-P1300 include printing items such as tickets, temporary ID tags or badges, decals and stickers. The LX-P1300 is also compact, and can be easily used on a desktop.
DURABLE HIGH QUALITY IMAGES
The LX-P1300 printer utilizes pigment-based inks to provide extensive durability and long-lasting results. Pigment inks do not run, smudge or fade away when used with inkjet compatible media. And with a print resolution of 1200 x 1200 dpi, fi ne details including small text are reproduced clearly.
POWERFUL PERFORMANCE
The LX-P1300 printer can be used for fast printing on-demand, with a first print out time of 10 seconds or less. Short run printing easily allows for quick changes to be made to label graphics or text when needed. In addition, a built-in auto cutter allows labels to be cut at preset intervals so that they can be used immediately.
ENVIRONMENT IN MIND
The LX-P1300 printer complies with both the EU RoHS and WEEE current directives for reduction of hazardous substances and waste products. In addition, on-demand label printing can assist with sustainability eff orts since it can help reduce the overprinting of excess labels that might become obsolete and need to be disposed of. Plus, inkjet label printers like the LX-P1300 are effi cient and only use ink on the sections of the label where printing is needed, helping to reduce the quantity of ink used. This means that labels can be printed quickly, and therefore can help increase productivity.
LABEL PRINT LANGUAGE EMULATOR
The Canon Label Print Language Emulator is designed to enhance the compatibility and integration of Canon label printers. This downloadable software enables Canon label printers to support existing ZPL®7 applications seamlessly. The Canon Label Print Language Emulator also enables users to register color background images and use them behind the rendered image from ZPL commands. This free software is available via download from www.usa.canon.com/support.
CUSTOMER CARE
For investment protection, eCarePAK extended service plan options1 are available beyond the initial one-year advanced exchange limited warranty period. An eCarePAK plan can help save on costs associated with post-purchase maintenance and can help maximize uptime throughout the product life.
BarTender
BarTender
Download Your 30-Day Free Trial
TEKLYNX
TEKLYNX
Main Unit Spec
Printer
Printing Method
Pigment-based Inkjet
Print Speed (up to)
First Print Out Time: 2" x 3" Label: 10 seconds or less1
Default Print Speed: 120 mm/second (4.7 inches/second)1
Range: 50 - 120 mm/s1
Preset Options: 120, 80, 70, 60, 50 mm/s
Number of Nozzles
2,816 dots
Print Resolution (Up to)
1200x1200 dpi
Ink Compatibility
4 (1 x Black, 1 x Cyan, 1 x Magenta, 1 x Yellow)
Shop Compatible Ink
Paper Sizes
Width: 28.4 - 63.0 mm (Including Liner)#60;br/>Length: 25.4 - 400.0 mm (Including Liner)
Maximum Printable Area
Width: 56.0 mm
Length: 397.0 mm
Minimum Margin
Top/Bottom Margin: 1.5 mm
Left/Right Margin: 3.5 mm
Paper Thickness
0.145 - 0.255 mm
Paper Compatibility
Label Roll Media with Roll Holder (IJ Coated: Matte or Glossy)
Roll Paper Maximum Outer Diameter
Outer Diameter: Up to 75 mm, Core/Inner Diameter: Up to 25.4 m
Body Durability
300,000 Sheets / 5 Years2
Estimated Output Number
Approx. 2,000 Sheets per cartridge set2
General
OS Compatibility
Windows 10 (64/32 bit), 8.1 (64/32 bit), 7 SP1 (64/32 bit)3
Standard Interface
USB 2.0
Ethernet (10/100/1000Base-T)
Power Source
AC 100-240v, 50/60 Hz
Power Consumption (approx.)
Operating /Maximum: Approx. 22.0 W (Average)
Sleep Mode: Approx. 6.0 W or Less
Dimension (W x D x H)
5.3" (W) x 9.8" (D) x 9.8" (H)
Weight
11.02 lbs.
Operating Temperature:
Temperature: 41° - 95°F (5° - 35°C)
Operating Humidity:
Humidity: 10-90% RH (Non-Condensing)
Noise
Acoustic Information
Operating Noise (Max.): 50dB or less4
Standby Noise: 30dB or less4
Warranty
1 Year Warranty5
Auto Cutter Unit
Built-In
Cartridge Fill Volume
Black / Cyan / Magenta / Yellow: 14.5 ml
Maintenance Cartridge Info & Fill Volume
WT-X201 Maintenance Cartridge2
Approx. 24,000 Sheets2
Operational Method
LCD: No
Buttons/LEDs: 2 Buttons / 7 LEDs
Optional Hardware Module
RH-L02 Roll Holder
Certifications/Standards
RoHS Compliance
Brochures
File Name
Canon LX-P1300 Pigment-based Inkjet Printer Brochure
Date
09.14.22
File Size
0.2 MB
File Name
Canon LX-P1300 Pigment-Based Label Printer Consumables Accessories Brochure
Date
11.29.22
File Size
0.1 MB
File Name
Canon LX-P1300 Service and Support Brochure
Date
11.29.22
File Size
3.4 MB
File Name
Label Printing Materials Catalog
Date
06.16.25
File Size
13.1 MB
Product Disclaimer
  1. Print speeds may vary depending on system configuration, interface, software, print complexity, print mode, page coverage, type of paper used, etc. Excludes pre-cleaning.
  2. Based upon standard print conditions and print size print size of 2"x3" inkjet coated matte label, 7.5% Duty/Color, 50 sheets x4 jobs/day, excludes manual cleaning.
  3. Operation can only be guaranteed on a PC with pre-installed Windows® 10 (64/32-bit), Windows 8.1 (64/32-bit), Windows 7 (64/32-bit.
  4. Acoustic noise is based off the measurement following ISO7779, and the display number shall follow ISO9296.
  5. Warranty and Support programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details.
  6. Printer weight measured excluding ink cartridges installed.
  7. ZPL is a trademark of Zebra Technologies Corp., registered in many jurisdictions worldwide. All other trademarks are the property of their respective owners.
