The Canon LX-P5510 label printer is designed to be reliable and flexible, delivering high-resolution, full color labels. By utilizing pigment-based ink for moisture resistance and durability, the LX-P5510 helps improve efficiency and productivity by creating long lasting labels as needed.
LX-P5510 Pigment Inkjet Label Printer
- Pigment-based ink for colorful and vivid graphics
- Prints up to 4" wide on roll or fan folded media
- Optional Rewinder and Auto Cutter accessories available
- Fast print speed: Up to 11.8 inches per second
- Print resolution up to 1200 dpi
- Roll capacity up to 200mm
- USB and ethernet connectivity
Return Policy
OVERVIEW
ABOUT THE LX-P5510 PIGMENT-BASED INKJET LABEL PRINTER
WIDE VARIETY OF USES
The LX-P5510 printer is designed to print vibrant, high-quality, long lasting labels on-demand. With high-performance pigment inks that are formulated to withstand water, abrasion, harsh chemicals, and UV or sunlight exposure, the LX-P5510 printer can be used in a variety of sectors and applications. From transportation and warehousing (shipping and inventory), to manufacturing (food & beverage, chemical), retail (pharmacy, grocery), agriculture (crop production), and wholesale general packaging and labels, the LX-P5510 printer can help save on storage space and costs by printing labels on-demand rather than printing large volumes in advance. Other uses for the LX-P5510 include printing items such as tickets, temporary ID tags or badges, decals, stickers, and more.
DURABLE, HIGH-QUALITY IMAGES
With 1200 x 1200 dpi output, the LX-P5510 printer’s pigment inks are formulated not to run, smudge or fade away when used with inkjet compatible matte or gloss media. The sharp imagery of fine details, including but not limited to small text and barcodes, are reproduced with clarity and accuracy which helps aid in capturing a customer’s attention and helps products stand out.
FLEXIBLE AND POWERFUL PERFORMANCE
The LX-P5510 printer is capable of fast print speeds up to 300 mm / 11.8 inches per second. The printer can print labels on media up to four inches wide, and has an estimated output per ink cartridge set of approximately 34,000 sheets2. Additionally, on-demand, short-run printing allows for quick implementation of changes made to label graphics or text when needed.
OPTIONAL REWINDER AND AUTO CUTTER
The optional Rewinder accessory allows users to rewind printed labels output from the LX-P5510 printer for later use, and is ideal for higher-volume production label printing environments. The optional Auto Cutter is designed to automatically separate labels at your desired interval upon printout. These items are sold separately.
ENVIRONMENT IN MIND
The LX-P5510 printer complies with both the EU RoHS and WEEE directives for the reduction of hazardous substances and waste products. In addition, on-demand label printing can assist with sustainability efforts since it helps to eliminate the overprint of excess labels that may become obsolete and need to be disposed of.
LABEL PRINT LANGUAGE EMULATOR
The Canon Label Print Language Emulator is designed to enhance the compatibility and integration of Canon label printers. This downloadable software enables Canon label printers to support existing ZPL®7 applications seamlessly. The Canon Label Print Language Emulator also enables users to register color background images and use them behind the rendered image from ZPL commands. This free software is available via download from www.usa.canon.com/support.
CUSTOMER CARE
For investment protection, eCarePAK extended service plan5 options are available beyond the initial one-year on-site limited warranty period. An eCarePAK can help save on costs associated with post-purchase maintenance and can help maximize uptime throughout the product life.
Main Unit Spec
Printer
Default Print Speed: 300 mm/second (11.8 inches/second)
Range: 50 - 300 mm/s
Preset Options: 300 mm/s, 200 mm/s, 150 mm/s, 120 mm/s, 100 mm/s, 90 mm/s, 80 mm/s, 70 mm/s, 60 mm/s, 50 mm/s1
Core/Inner Diameter: Up to 76.2 mm
Fanfold Media: Media Height: Up to 850 mm
Length: 6.0 - 500.0 mm
Media Thickness: 0.145 - 0.255 mm
Length: 3.0 - 497 mm
Left/Right: 2.7 mm (including Liner, with AIS “On”)
General
Approx. 100,000 Sheets
Buttons/LEDs: 4 Buttons / 8 LEDs
Humidity: 10 - 90% RH (Non-Condensing)
RH-L03 Roll Holder Module
Rewinder
Operating: Approx. 29 W
Standby Noise: 35dB or less4
Product Disclaimer
- Print speeds based on 4 x 3 inkjet coated label and may vary depending on system confi guration, interface, software, print complexity, print mode, paper coverage, type of paper used, etc.
- Based upon standard print conditions and print size of 4”x3” inkjet coated matte label, 7.5% Duty/Color, 100 labels x 50 jobs/day, excluding manual cleaning and printhead.
- Operation can only be guaranteed on a PC with pre-installed Windows 11 (64bit), Windows® 10 (64/32-bit)
- Acoustic noise is based off the measurement following ISO7779, and the display number shall follow ISO9296.
- Warranty and Support programs are subject to certain conditions and restrictions. See usa.canon.com/support for details.
- Printer weight measured excluding print head or ink cartridges installed.
- ZPL is a trademark of Zebra Technologies Corp., registered in many jurisdictions worldwide. All other trademarks are the property of their respective owners.
