LX-P5510 Pigment Inkjet Label Printer
LX-P5510
As low as $9,999.00
Out Of Stock
  • Pigment-based ink for colorful and vivid graphics
  • Prints up to 4" wide on roll or fan folded media
  • Optional Rewinder and Auto Cutter accessories available
  • Fast print speed: Up to 11.8 inches per second
  • Print resolution up to 1200 dpi
  • Roll capacity up to 200mm
  • USB and ethernet connectivity
Return Policy
Main Unit Spec
Printer
Printing Method
Pigment-based Inkjet
Ink Cartridges
4 (1 x Black, 1 x Cyan, 1 x Magenta, 1 x Yellow)
Shop Compatible Ink
Print Resolution
1200x1200 dpi
Max Print Speed
First Print Out Time: 4" x 3" Label: 10 seconds or less
Default Print Speed: 300 mm/second (11.8 inches/second)
Range: 50 - 300 mm/s
Preset Options: 300 mm/s, 200 mm/s, 150 mm/s, 120 mm/s, 100 mm/s, 90 mm/s, 80 mm/s, 70 mm/s, 60 mm/s, 50 mm/s1
Supported Media Types
Label Roll Media (with Roll Holder) & Label Fanfold Media (IJ Coated: Matte Paper, Matte Synthetic, Gloss Paper)
Media Capacity
Roll Media: Outer Diameter: Up to 200 mm
Core/Inner Diameter: Up to 76.2 mm
Fanfold Media: Media Height: Up to 850 mm
Media Size & Thickness
Media Size: Width: 25.4 - 120.0 mm (Including Liner)
Length: 6.0 - 500.0 mm
Media Thickness: 0.145 - 0.255 mm
Maximum Printable Area
Width: Up to 105.9 mm (with AIS “On”)
Length: 3.0 - 497 mm
Minimum Margin
Top/Bottom: 1.5 mm
Left/Right: 2.7 mm (including Liner, with AIS “On”)
Product Life
Approx. 6 Million Sheets / 5 Years2
General
Output per Cartridge Set
Approx. 34,000 Sheets2
Cartridge Fill Volume
Black / Cyan / Magenta / Yellow: 240 ml
Maintenance Cartridge
WT-X401 Maintenance Cartridge
Approx. 100,000 Sheets
Operational Method
LCD: No
Buttons/LEDs: 4 Buttons / 8 LEDs
Connectivity
USB 2.0, Ethernet (10/100/1000 Base-T), RS- 232C (For External Devices)
OS Compatibility
Windows 11 (64bit), Windows 10 (64/32 bit)3
Operating Environment
Temperature: 41° - 95°F (5° - 35°C)
Humidity: 10 - 90% RH (Non-Condensing)
Options
CU-L02 Auto Cutter Unit Module
RH-L03 Roll Holder Module
Rewinder
Power Consumption (approx.)
Maximum: Approx. 268 W
Operating: Approx. 29 W
Electrical
AC 100-240V, 50/60Hz
Acoustic Information
Operating Noise (Max.): 55dB or less
Standby Noise: 35dB or less4
Warranty
One-Year On-Site Limited Warranty5
Dimension (W x D x H)
15.2” (W) x 22.4” (D) x 15.5” (H)
Weight
55.1 lbs.6
Brochures
File Name
Canon LX-P5510 Label Printer Brochure
Date
04.26.23
File Size
0.5 MB
File Name
Canon LX-P5510 Inkjet Label Printer Consumables And Accessories Brochure
Date
04.26.23
File Size
0.1 MB
File Name
Canon LX-P5510 Service & Support Brochure
Date
03.06.24
File Size
3.6 MB
Product Disclaimer
  1. Print speeds based on 4 x 3 inkjet coated label and may vary depending on system confi guration, interface, software, print complexity, print mode, paper coverage, type of paper used, etc.
  2. Based upon standard print conditions and print size of 4”x3” inkjet coated matte label, 7.5% Duty/Color, 100 labels x 50 jobs/day, excluding manual cleaning and printhead.
  3. Operation can only be guaranteed on a PC with pre-installed Windows 11 (64bit), Windows® 10 (64/32-bit)
  4. Acoustic noise is based off the measurement following ISO7779, and the display number shall follow ISO9296.
  5. Warranty and Support programs are subject to certain conditions and restrictions. See usa.canon.com/support for details.
  6. Printer weight measured excluding print head or ink cartridges installed.
  7. ZPL is a trademark of Zebra Technologies Corp., registered in many jurisdictions worldwide. All other trademarks are the property of their respective owners.
