MegaTank MAXIFY GX7021
GX7021
Discontinued
The MegaTank MAXIFY GX7021 Wireless Home & Office All-in-One Printer is no longer available, but you can find similar products below.
  • Wireless Print/Copy/Scan/Fax
  • Up to 2 years of ink included in the box24
  • Print up to 6,000 black & white / 14,000 color pages using a single set of inks!6
  • 2.7” LCD Color Touchscreen
  • Auto 2-sided printing
  • ADF – 50 sheet 1Pass Auto Document Feeder
Show more
MAXIFY GX7021
PRINT / COPY / SCAN / FAX
Compatible Inks
Built for Business, at the Office or at Home
The MAXIFY GX7021 MegaTank Printer is perfect for small businesses and home offices that demand high volume, low-cost printing with a high amount of versatility and dependability. Print more for less with MAXIFY MegaTank!
MAXIMIZE PRODUCTIVITY, MINIMIZE COSTS7
45,000 Page Duty Cycle6
Get the job done during those busy months with a monthly duty cycle of up to 45,000 pages6.
gx7020
50-Sheet Single Pass Duplex Auto Document Feeder (ADF)
Scan multi-page documents with ease with the 50-Sheet Auto Document Feeder (ADF)— plus scan 2-Sided documents in just ONE pass.
gx7020
600-Sheet Plain Paper Capacity
Load up to 250-Sheets of plain paper in each of the two bottom cassettes and another 100-Sheets of plain paper in the rear tray.
gx7020
Fast Print Speeds
Get the job done quickly with fast print speeds of up to 24 ipm Black and 15.5 ipm color.9
gx7020
Small Footprint
Not only is the MAXIFY GX7021 packed with features, it's also designed small to fit your workspace.
gx7020
THE MEGATANK DIFFERENCE
gx7020
Refillable Ink Tanks
  • High-yield ink bottles minimize waste and downtime
  • Keyed nozzles for each color make refilling easy & error-free
  • Replaceable maintenance cartridges and print heads keep you up and running with no service visits required
gx7020
High Yield, Big Savings
  • Print 6,000 black and white or 14,000 color pages with each full ink bottle set7
  • Print for less than 2 cents per page7
VERSATILE
A Printer Ready for Any Job
  • Designed to tackle any job, big or small. Print up to 47" (inches) in length.
  • Presentations, images, reports, the MAXIFY GX7021 can deliver on anything you need
  • Print on envelopes and labels, on glossy or thick paper
  • Supports a variety of media types and sizes
gx7020
BUILT FOR QUALITY. BUILT TO LAST.
gx7021
Quality. Precision. Dependability.
Get a versatile, high-performing printer backed by Canon’s award-winning customer service.
gx7021
Sharp Text, Crisp Color
With a 4-Color Pigment Ink System you'll get crisp color and black & white documents along with sharp highlighter resistant text.
gx7021
Industry Leading 3-Year Limited Warranty*
Have peace of mind with an included 3-Year or 80,000 Page* Limited Warranty.
Replaceable Maintenance Cartridge & Print Heads
Both the print heads and maintenance cartridge in the MAXIFY GX7021 are easily replaceable should the need arise. No service visits calls required!
CONNECTIVITY
So Many Ways to Print
Connect quickly and easily and set up Wi-Fi® even without a computer. Work over Ethernet, Wi-Fi®, or even straight from a USB stick. Print from a computer or mobile device. Supports the Canon PRINT app2, Apple AirPrint®3, and Mopria® Print Service.4
gx7020
Wireless Connect
Wireless Connect
Complete your printer setup quickly and easily on your Apple® or Android™ device using the printer’s Wireless Connect button.8
Smartphone Copy
Smartphone Copy
With Smartphone Copy, using the Canon PRINT app9, use your smartphone to quickly and easily scan, adjust, and print your documents and photos.
AirPrint®
AirPrint®
Use Apple AirPrint® to wirelessly print documents and photos straight from your iPhone®, iPad® or Mac® — no additional apps required!
Mopria® Print Service,<br />
Mopria® Scan
Mopria® Scan
Connect to Mopria® Print Service or Mopria® Scan app to seamlessly print or scan from your favorite Android device5.
Connect your Workflow to your Favorite Apps
The MAXIFY GX7021 MegaTank Printer integrates seamlessly with major apps including Google Drive, Box, and dozens of others. Scan documents and upload them to the cloud in moments.
gx7020
Features
  • PRINT, COPY, SCAN, and FAX with the MAXIFY GX7021 MegaTank All-in-One Printer
  • HIGH PAGE YIELD: Print up to 6,000 Black / 14,000 Color pages on just a single set of inks.7
  • Get SHARP TEXT AND DOCUMENTS thanks to a 4-Color Pigment-Based ink system, including highlighter resistant text.
  • Have peace of mind with a 3-YEAR or 80,000 PAGES LIMITED WARRANTY.*
  • Easy to use intuitive user interface on a 2.7" COLOR LCD TOUCHSCREEN.
  • HIGH PAPER CAPACITY: Hold up 600 Sheets of plain paper thanks to two 250-Sheet bottom cassettes and a 100-Sheet rear tray.
  • Copy and scan multi-page documents fast and easy with the 50-Sheet AUTO DOCUMENT FEEDER!
  • Scan 2-Sided documents in just one single pass with SINGLE PASS DUPLEX SCANNING!
  • VERSATILE MEDIA SUPPORT – print on matte paper, envelopes, business cards, and more!
  • EASY TO FILL with Keyed Bottle shape for each color to only fit and fill the correct ink tank.
  • EASY SETUP for smartphone and computer so you can get to work faster.
  • Easy Wi-Fi® setup with WIRELESS CONNECT. Connect to Wi-Fi® without the need for a computer.1
  • MOBILE PRINTING: Print from your favorite mobile devices using the Canon PRINT app2, Apple AirPrint®3, and Mopria® Print Service4
  • Built-In ETHERNET connection for Wired LAN support.
  • Print directly from a USB FLASH DRIVE reader.5
  • Built-to last with a MONTHLY DUTY CYCLE of up to 45,000 pages!6
  • STAY WASTE-CONSCIOUS. Thanks to high page yield ink bottles, keep waste and time spent refilling ink to a minimum.
  • Packed with features in a SMALL FOOTPRINT to fit your workspace.
VIDEOS
Sort By:
Untitle Video
MegaTank helps you keep the legend alive with refillable ink tanks. Get MegaProductive without worrying about ink with Canon MegaTank Printers. MegaTank for MegaSavings.
Untitle Video
Boost your productivity with Canon MegaTank printers as your sidekick for success. Print more and refill less with up to two years of ink included in the box. MegaTank for MegaSavings.
Untitle Video
Yeti or not, MegaTank printers let you print a ridiculous amount of pages. Order your MegaTank printer and get up to 2 years of ink included in the box. (Now that’s mega!) Tackle your mega ideas with Canon’s powerful MegaTank printers.
Untitle Video
Print thousands of pages of pure Miami with Canon MegaTank printers. Discover the MegaFun with up to 2 year of ink included in the box. MegaTank for MegaSavings.
Main Unit Spec
Printer
Print Speed (up to)
Black:Black: ESAT Approx. 24.0 ipm9
Color:Color:FPOT Color: ESAT Approx. 15.5 ipm9
Number of Nozzles
Color (C/M/Y): 1.024x3 / Pigment Black: 1,280 / Total: 4,352
Print Resolution (Up to)
Up to 1200 x 600 dpi10
Ink Compatibility
INK TYPE GI-26 Pigment-Based Ink Bottles (Cyan, Magenta, Yellow, Black) INK TANK & FILL VOLUME GI-26 Black Ink Bottles: 167.0 ml GI-26 C, M, Y Ink Bottles: 132.0 ml (each)
Shop Compatible Ink
Paper Sizes
4" x 6", 5" x 5" (Square), 5" x 7", 7" x 10", 8" x 10", Letter (8.5" x 11"), Legal (8.5" x 14"), Executive, U.S. #10
Custom Size: Width: 3.5" - 8.5" / Length: 5" - 47"
Paper Compatibility
Plain: Plain Paper, High Resolution Paper;
Matte: Matte Photo Paper, Double-sided Matte Paper;
Other (Canon): Magnetic Photo Paper, Restickable Photo Paper, Light Fabric Iron on Transfers;
Other (non-Canon): Greeting Card, Envelopes, Recycled paper and Chlorine-free paper can be used
Rear Tray Supported Media Weight
Plain Paper: 64 - 105 gsm OR
Canon Paper: Max. approx. 275 gsm (Canon PP-301) OR
Thicker Paper: approx. 115-250gsm
Bottom Cassette Supported Media Weight Plain Paper: 64 - 105 gsm
Printer Features
Document Printing, Photo Printing, Wireless Printing8, Mobile Device Printing, Business Card Printing, Greeting Card Printing, Label Printing, Square Media Printing Support, Double-sided Matte Paper Support, Print from USB Flash Drive5 HIGH PAGE YIELD: Up to 6,000 (Black & White) / 14,000 (Color)7
Paper Handling
PAPER HANDLING
INPUT Cassette 1: 250 Sheets Plain Paper (Letter)
Cassette 2: 250 Sheets Plain Paper (Letter)
Rear Paper Tray: 100 Sheets of Plain Paper OR 20 Sheets (4" x 6")
Output Tray Capacity
PAPER HANDLING
Noise Level (Approx.)
Approx. 49.0 dB(A) (Plain Paper)
Copier
Copy Speed (up to)
FCOT (Color/Simplex): Approx. 12 seconds9
Copy Features
4-on-1 / 2-on-1 Copy, Document Copy, Fit-to-Page, Frame Erase Copy (Flatbed Only), ID Card Copy, Auto Exposure Copy, Multiple Copy (Up To 99 Pages), Photo Copy, Preset Copy Ratios, Reduction / Zoom Copy (25% - 400%), Standard Copy
Scanner
Scanner Type
Flatbed & ADF (Auto Document Feeder)
Scanning Element
Contact Image Sensor (CIS)
Max. Resolutions
Optical:Optical:1200 x 1200 dpi (Optical)11
Scanner Features
Single Sided (Simplex) Scanning, Single-pass Duplex Scanning Save to PC, Attach to E-mail, Multi-Page PDF, Save to USB Flash Drive, Unsharp mask, Descreen, Reduce slow-through, Rescan, Rotate, Auto Crop, Scan to Folder
Color Depth
Grayscale: 16-bit/8-bit
Color: 16-bit/8-bit Per Color
Max. Document Size
8.5" x 11.7" (A4/Letter)
ADF:8.5" x 14.0" (Legal)
Fax
Modem Speed
Max. 33.6 kbps (Automatic Fall Back)12
Transmission Speed (approx.)
Black: Approx. 3 sec13
Color: Approx. 1 min13
Memory Capacity
Approx. 250 Pages14
Speed Dialing
Max. 99 Locations
Fax Features
Caller rejection, Fax reception reject, Fax number re-entry, Check RX fax info, Dial search, Memory transmission, Answering machine connectivity, Remote reception, Redial, Double sided printing (fax images), FAX to Folder
General
Other Features
Auto Power On/Off, Print/Scan/Copy, Quiet Mode, Wireless Direct Connection, Wireless Connect1, Auto Paper Width Detection, Energy Star® Certified23, User Replaceable Print Head, User Replaceable Maintenance Cartridge Display: 2.7" LCD Touchscreen Smart assistant & automation support: Amazon Alexa™18, Google Assistant™18
OS Compatibility
Windows:15 Windows® 10, Windows 8.1, Windows 7 SP1 Mac:16 macOS v10.12.6 - 10.15 (Catalina) Mobile Operating Systems:17 iOS®, iPadOS, Android™
Standard Interface
Hi-Speed USB
Wi-Fi® (Wireless LAN, 2.4/5 GHz, IEEE 802.11b/g/n)8
Wired LAN (100BASE-TX) / 10BASE-T)
Software Included
(WINDOWS15/MAC16) MAXIFY GX7020 Wireless MegaTank Small Office All-in-One Printer Driver Easy-PhotoPrint Editor Software19, PosterArtist Lite Software22
Mobile Printing Solutions & Apps (iOS® / Android®
AirPrint®3, Mopria® Print Service4, Canon PRINT app2, Easy PhotoPrint Editor App19, Canon Print Service20 (Android), PIXMA Cloud Link2, Creative Park App21
Power Consumption (approx.)
23.0W Copying (0.9W Standby)
Dimension (W x D x H)
Closed: 15.8” (L) x 16.2” (W) x 12.4” (H)
Trays Extended: 15.8” (L) x 25.4” (W) x 15.3” (H)
Weight
28.6 lbs.
Warranty
3-Year or 80,000 Page* Limited Warranty with InstantExchange Program
Reviews
Brochures
File Name
MAXIFY GX7021 / GX6021 Brochure
Date
03.04.25
File Size
2.5 MB
MegaTank MAXIFY GX7021 Compatible Products
Ink
Ink
Product Disclaimer
Specifications are subject to change without notice. Screens, output images, and images are simulated.
Warranty is effective for three (3) years from date of original purchase or the printing of 80,000 pages, whichever comes first. Warranty program is subject to certain conditions and restrictions. See www.usa.canon.com/support/maxify-gx-series-3-year-limited-warranty for details.
  1. Requires a smart device with the Canon PRINT Inkjet/SELPHY app installed and connected to the desired active wireless network to complete cableless setup
  2. Requires an Internet connection and the Canon PRINT Inkjet/SELPHY app, available for free on the App Store and at Google Play. Compatible with iPad, iPhone 3GS or later, and iPod touch 3rd generation or later devices running iOS 12.0 or later, and Android? mobile devices running Android 4.4 or later. Your device must be connected to the same working network with wireless 802.11 b/g/n capability as your printer. Requires a compatible social media account and is subject to that social media account's Terms of Service. Certain exceptions may apply.
  3. AirPrint functionality requires a compatible iPad, iPhone, or iPod Touch device running iOS 7.0 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported.
  4. Requires AndroidTM mobile device with Android 4.4 operating system or later with the Mopria® Print Service pre-loaded with that device and the compatible PIXMA printer on the same wireless network. The Mopria® experience is also available on Android 4.4 or later mobile devices with a download of the Mopria® Print Service from Google Play.   Learn more.
  5. Supported file formats include: JPEG, TIFF and PDF.
  6. Duty Cycle is defined as the maximum number of printed pages for a single peak month.
  7. Claim is based on page yield of 6,000 Black/14,000 Color pages per ink bottle set and MSRP (USD) of $126.96 for full set of GI-26 ink bottles (1 bottle each of Cyan, Magenta, Yellow, Black) as of March 2021. Page yield of color inks is an average yield of cyan, magenta and yellow inks combined. Page yield of included ink bottles used for initial setup is lower than the replacement ink bottles, as a certain amount of ink is consumed to fill into the print head during setup (charging the print head initially). Actual page yield and cost per print will vary significantly based on content printed, ink levels maintained in all four ink reservoirs, and other factors. Page yield is the estimated value based on Canon individual testing method using ISO/IEC 24712 test chart and continuous printing simulation with full set of replacement ink bottles after initial setup. Ink value savings and cost per print comparison with laser is based on total cost (using online manufacturers' prices as of March 2021) of high yield and standard capacity (where high yield are not available) laser cartridges necessary to achieve equivalent page yields by similarly featured color laser printers.
  8. Wireless printing and scanning requires a working network with wireless 802.11b/g/n capability, operating at 2.4GHz or 5.0GHz. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
  9. Document print speeds are the averages of ESAT in Office Category Test for the default simplex mode, ISO/IEC 24734. Photo print speed is based on the default setting using ISO/JIS-SCID N2 on Photo Paper Plus Glossy II and does not take into account data processing time on host computer. Print speed may vary depending on system configuration, interface, software, document complexity, print mode, page coverage, type of paper used etc. Copy speeds are the average of sFCOT and sESAT, ISO/IEC 29183. Copy speed may vary depending on document complexity, copy mode, page coverage, type of paper used etc. and does not take into account warming up time. See www.usa.canon.com/printers/iso-productivity-standardsm for additional details.
  10. Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
  11. Optical resolution is a measure of maximum hardware sampling resolution, based on ISO 14473 standard.
  12. Page count is based on ITU-T No.1 chart or Canon FAX Standard Chart No.1. The number of pages able to be kept in memory will vary based on remaining memory capacity and document complexity.
  13. Black & white document fax transmission speed is based on default setting using ITU-T No.1 chart. Color document fax transmission speed is based on default setting using Canon Color Fax Test Sheet. Actual transmission speed varies depending on document complexity, fax setting at receiving end, and line conditions etc.
  14. The Public Switched Telephone Network currently supports fax modem speeds of 28.8 Kbps or lower, depending on telephone line conditions. Sending and receiving fax machines need to conform to ITU-T v.34 guidelines.
  15. Operation can only be guaranteed on a PC with pre-installed Windows 10, Windows 8.1, Windows 7 SP1.
  16. Internet Connection required during software installation. For full compatibility macOS v10.12.1 or later is recommended.
  17. Some functions may not be available with these Operating Systems. Please refer to manual or Canon website for details.
  18. Requires an active smart assistant account linked and accompanying app enabled, the smart device and printer to be actively connected with permission to the Canon Inkjet Cloud Printing Center, and the required action(s), skill(s), or applet(s) available/enabled to the compatible printer. Voice commands can not be displayed as text on Amazon smart devices with screens.
  19. The Easy-PhotoPrint Editor software requires an Internet connection and is compatible with the following operating systems; Microsoft Windows 10 (64-bit/32-bit), Microsoft Windows 8.1 (64-bit/32-bit), Microsoft Windows 7 SP1 (64-bit/32-bit), macOS High Sierra v10.13, macOS Sierra v10.12, Mac OS X El Capitan v10.11 and Mac OS X El Capitan v10.10.5. Minimum Windows and macOS/Mac OS X requirements are: 2GB of RAM and a monitor with 1024x768 resolution. The Easy-PhotoPrint Editor mobile application requires an Internet connection and the Easy-PhotoPrint Editor app v1.1.0, available for free on the App Store and at Google Play. Compatible with iPad Air2 (2nd Generation), iPad Mini 4 and iPhone 6s or later devices running iOS 10 or later, and Android mobile devices running Android 5.x or later. Certain exceptions may apply. The following file formats are supported: JPEG, PNG, HEIF (devices running iOS 11 and mac OS v10.13 or later), DLP save data, Poster Artist export data, EasyPhoto+ export data, Easy-PhotoPrint Editor export data.
  20. Canon Print Service is a print plug-in for Android smart devices, which enables printing from Android v4.4 - v5.0 devices to many Canon printers via a Wi-Fi network. The plug-in does not work as a standalone app. Available for free at Google Play.
  21. Requires an Internet connection and the Creative Park app, available for free on the App Store and at Google Play. Requires an active 'Canon ID' available for free, and subject to 'Canon ID' Terms of Service. Visit myid.canon for more information. Certain exceptions may apply.
  22. PosterArtist Lite software v3.X is compatible with 64/32 bit versions of Microsoft? Windows? 10, Windows 8.1, Windows 7 and only compatible with select Canon PIXMA (released after July 2015), MAXIFY, imagePROGRAF and Oce printers. Minimum computer system requirements: Pentium4 2.8Ghz CPU or higher with 1GB RAM, 1024x768 pixel display and 5GB of system hard drive space.
  23. As an ENERGY STAR® Partner, Canon U.S.A., Inc. has certified this printer as meeting the ENERGY STAR® energy efficiency criteria through an EPA-recognized certification body.
  24. Claim of up to two (2) years of ink based on average monthly document print volumes of 200 pages continuous printing using 'default printing mode'
