MAXIFY MB2720
MB2720
As low as $215.99
4 interest free payments of $54.00 with
klarna Pay Later
Paypal Pay Later
Out Of Stock
  • Wireless 3-in-1 (Print | Copy | Scan)
    • 19 / 13 ipm Print Speed
    • 500-Sheet Capacity
    • Auto 2-Sided Printing
    • 20,000 Page Duty Cycle
    • Energy Star® Certified, EPEAT Silver
    • 1 Year Warranty
Show more
Main Unit Spec
Printer
Print Speed (up to)
Black:FPOT (Black): 6 Seconds - ESAT (Black): 24.0 ipmFootnote1
Color:FPOT (Color): 7 Seconds - ESAT (Color): 15.5 ipmFootnote1
Number of Nozzles
Pigment Black: 1,280 / Color: 3,072 / Total: 4,352
Print Resolution (Up to)
Up to 600 x 1200 dpiFootnote8
Ink Compatibility
PGI-1200 Black - 12.4 ml (Std) / 34.7 ml (XL)
PGI-1200 Cyan - 4.5 ml (Std) / 12.0 ml (XL)
PGI-1200 Magenta - 4.5 ml (Std) / 12.0 ml (XL)
PGI-1200 Yellow - 4.5 ml (Std) / 12.0 ml (XL)
Up to 1,200 Black & White / 900 Color Pages when using XL ink tanks.
Shop Compatible Ink
Paper Sizes
4" x 6", 5" x 7", 8" x 10", Letter, Legal, U.S. #10 Envelopes
Paper Compatibility
Plain: Plain Paper, High Resolution Paper
Glossy: Photo Paper Plus Glossy II, Photo Paper Glossy
Semi-Gloss: Photo Paper Plus Semi-Gloss, Photo Paper Pro Luster
Matte: Matte Photo Paper
Other: Business Card, Label Paper, U.S.#10 Envelopes
Recycled paper and Chlorine-free paper can be used.
Printer Features
AirPrintFootnote5, Mopria® Print ServiceFootnote7, Auto 2-Sided Printing, Advanced Auto Sheet Feeder, Canon PRINT appFootnote4, Document Printing, Microsoft Mobile Print, Quick Toolbox, Wireless PrintingFootnote3
Output Tray Capacity
Upper Cassette: 250 Sheets Plain Paper (Letter or Legal) or 20 Sheets Photo Paper 4" x 6"
Lower Cassette: 250 Sheets Plain Paper (Letter or Legal)
Noise Level (Approx.)
Approx. 56.0 dB(A)Footnote16
Copier
Copy Speed (up to)
FCOT (Color): Approx. 12 SecondsFootnote1
Reduction / Enlargement
25% - 400%
Copy Features
2-on-1 Copy, 4-on-1 Copy, ID Card Copy, AE (Auto Exposure / Intensity) Copy, Collated Copy (ADF only), Fit-to-Page, Frame Erase Copy (Flatbed), Preset Copy Ratios, Preview, Standard Copy, 2-Sided Copy, Zoom
Scanner
Scanning Element
Contact Image Sensor (CIS)
Max. Resolutions
Optical:ADF & Flatbed: 1200 x 1200 dpi (Optical)Footnote11
Interpolated:19,200 x 19,200 dpi (Interpolated)Footnote11
Scanner Features
Push Scan, Scan to Memory (USB Flash Memory), Network Scan, Scan to Cloud, Scan to Email, Scan to Network Folder
Color Depth
48-bit internal/24-bit external
Max. Document Size
Flatbed: 8.5" x 11" (Letter); ADF - 50 Sheet Capacity
ADF: 8.5" x 14" (Legal); ADF - 10 Sheet Capacity
Fax
Modem Speed
33.6 Kbps (Super G3 Color FAX)Footnote12
Transmission Speed (approx.)
Black: Approx. 3 sec. per pageFootnote13
Color: Approx. 1 min. per pageFootnote13
Memory Capacity
Approx. 250 PagesFootnote14
Speed Dialing
100 Locations
Fax Features
Answering Machine Connectivity, Caller Rejection, Check RX Fax Info., Dial Search, Double-Sided Printing (Fax Images), FAX to Network Folder, Extra Fine Mode, Fax Reception Reject, Fax Number Re-Entry, F/T Changing (Manual), Memory Transmission, Redial, Remote Reception
General
Other Features
Custom Profiles, Folder Setting Utility, Highlighter and Smudge Resistant Ink, Access Point Mode, High Page Yield, Job Reservation, Low Cost Per Page Printing, Quick First PrintFootnote1, MAXIFY Cloud LinkFootnote15, Quiet Mode, Standard MIB Support, SNMP Support, Records of Use, Job Reservation, Remote UI, Setting Restrictions, Up to 20,000 pages Duty CycleFootnote2, Auto Power On, Schedule On/Off
OS Compatibility
Computer Operating Systems:
Windows:Footnote17,Footnote18 Windows® 10, Windows 8, Windows 8.1, Windows 7, Windows 7 SP1, Windows Vista® SP1, Vista SP2, Windows Server® 2012, 2012 R2Footnote18, Windows Server®2008, 2008 R2Footnote18
Mac:Footnote19 Mac OS® X v10.8.5 - 10.11
Mobile Operating Systems:Footnote20
iOS®, Android, Windows RTFootnote21 and Windows 10 Mobile
Standard Interface
Wireless LAN (IEEE 802.11b/g/n)Footnote2
Ethernet
USB Flash Memory
Hi-Speed USB
Software Included
WINDOWSFootnote17,Footnote18/MACFootnote19
MAXIFY MB2720 Printer Driver
Master Setup
PosterArtist LiteFootnote22 (Windows Only)
Scan Utility
My Printer (Windows Only)
Network Tool
Speed Dial Utility
Power Consumption (approx.)
27.0W Copying (0.9W Standby)
Dimension (W x D x H)
18.1" (W) x 18.3" (D) x 12.6" (H)
Weight
26.5 lbs.
Warranty
1-Year limited warranty with InstantExchange Program.Footnote23
Recommended Monthly Print Volume
250 - 1,250 Pages per Month - Ideal for 1-4 users
Reviews
MAXIFY MB2720 Compatible Products
Ink
Ink
Product Disclaimer
  1. Document print speeds are the averages of ESAT in Office Category Test for the default simplex mode, ISO/IEC 24734. Document print speeds are the averages of FPOT in Office Category Test for the default simplex mode, ISO/IEC17629:2014. Print speed may vary. During successive printing, the printer may slow down the operation to prevent the internal temperature from rising. Depending on system configuration, interface, software, document complexity, print mode, page coverage, type of paper used etc. Copy speeds are the average of sFCOT and sESAT, ISO/IEC 29183. Copy speed may vary depending on document complexity, copy mode, page coverage, type of paper used etc. and does not take into account warming up time. When scanning or copying a certain volume of documents (approx. 150 sheets in default settings) continuously from the ADF, the printer may switch to waiting mode in which paper feeding stops for several tens of seconds after each scan to prohibit overheating the ADF. See www.usa.canon.com/ipm for additional details.
  2. Duty Cycle is defined as the maximum number of printed pages for a single peak month.
  3. Wireless printing requires a working network with wireless 802.11b/g or n capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
  4. Requires an Internet connection and the Canon PRINT Inkjet/SELPHY app, available for free on the App Store and at Google Play. Compatible with iPad, iPhone 3GS or later, and iPod touch 3rd generation or later devices running iOS 7.0 or later, and Android mobile devices running Android 2.3.3 or later. Your device must be connected to the same working network with wireless 802.11 b/g/n capability as your printer. For users of compatible Apple mobile devices, document printing requires Apple AirPrint, which requires an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported.
  5. AirPrint functionality requires an iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported.
  6. Requires an Internet connection and Google account. Subject to Google Terms of Service. Certain exceptions may apply.
  7. Requires Android mobile device with Android 4.4 operating system or later with the Mopria Print Service pre-loaded with that device and the compatible PIXMA/MAXIFY printer on the same wireless network. The Mopria experience is also available on Android 4.4 mobile devices with a download of the Mopria Print Service from Google Play.
  8. Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/600 inch at minimum.
  9. ADF scan speeds are the average of scESAT30secA in ADF Productivity Measurement test, ISO/IEC 17991:2015. Scan to network folder speeds with ADF are the average of scEFTP30secF in Scan to Network Folder Productivity Measurement test, ISO/IEC 17991:2015. ADF scan speeds/Scan to network folder speeds with ADF will vary depending on system configuration, interface, software, document complexity etc. When scanning or copying a certain volume of documents (Approx. 150 sheets in default settings) continuously from the ADF, the printer may switch to waiting mode in which paper feeding stops for several tens of seconds after each scan to prohibit overheating the ADF.
  10. Optical resolution is a measure of maximum hardware sampling resolution, based on ISO 14473 standard.
  11. The Public Switched Telephone Network currently supports fax modem speeds of 28.8 Kbps or lower, depending on telephone line conditions. Sending and receiving fax machines need to conform to ITU-T v.34 guidelines.
  12. Black & white document fax transmission speed is based on default setting using ITU-T No.1 chart. Color document fax transmission speed is based on default setting using Canon Color Fax Test Sheet. Actual transmission speed varies depending on document complexity, fax setting at receiving end, and line conditions etc.
  13. Page count is based on ITU-T No.1 chart or Canon FAX Standard Chart No.1. The number of pages able to be kept in memory will vary based on remaining memory capacity and document complexity.
  14. Requires an Internet connection.
  15. Acoustic Noise is measured based on ISO7779 standard.
  16. Operation can only be guaranteed on a PC with factory-installed Windows 10, Windows 8.1, Windows 8, Windows 7, Windows Vista or XP.
  17. Available from printer driver and fax driver only. XPS drive is not supported for Windows Server 2003 and 2003 R2.
  18. Internet Connection required during software installation.
  19. Some functions may not be available with these Operating Systems. Please refer to the manual or our website for full details.
  20. Requires a Windows RT compatible device with Windows 10, Windows 8.1 or Windows 8 and the Canon Easy-PhotoPrint app for Windows RT available for free in the Windows Store.
  21. PosterArtist Lite software v2.60.00 is compatible with 64/32 bit versions of Microsoft®Windows®10, Windows 8.1, Windows 8, Windows 7 and Windows Vista®, and only compatible with Canon PIXMA (released after July 2015), MAXIFY, imagePROGRAF and Océ printers. Minimum computer system requirements: Pentium4 2.4Ghz CPU or higher with 1GB RAM, 1024x768 pixel display and 5GB of system hard drive space.
  22. Warranty programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details.
