MegaTank PIXMA G3272 Wireless All-in-One Printer
As low as $0.00
Out Of Stock
  • Wireless Print/Copy/Scan
  • Up to 2 years of ink included in the boxFootnote20
  • Print up to 6,000 black & white / 7,700 color pages using a single set of inks!Footnote6
  • Save up to $1,000 on ink
  • 1.35” Square LCD display
  • Single-sided printing
Overview
PIXMA G3272 - Front View
PIXMA G3272 Logo
Wireless MegaTank All-in-One Printer
Wireless. Print. Copy. Scan.
Features
Maximize Productivity
Print up to 6,000 Black / 7,700 Color pages with just a single set of inks.
PIXMA G3272 - Printer next to Ink Bottles
MegaTank Means Savings
Ink Savings of over $1,000 with the included ink bottle set.Footnote5
PIXMA G3272 - Front View in Front of Many Stacks of Printed Flyers
Versatility For What You Need
Print on envelopes, photos, high resolution paper, and more! Up to paper size 8.5” x 47”.
PIXMA G3272 - Person Holding Printed Paper
Easy to Fill & View Ink Levels
Easy to fill with keyed nozzles for each color to only fit the correct ink tank.
PIXMA G3272 - Refilling Ink
Compact Size
Not only is the PIXMA G3272 packed with features, it’s also designed to fit in your home or workspace.
PIXMA G3272 - Dimensions
Reliable
Get the work done during those busy months with a monthly duty cycle of up to 3,000 pages.
PIXMA G3272 - Printer in an Office
1.35” Square LCD Screen
Get the job done with an intuitive and easy to use 1.35” Square LCD Screen.
PIXMA G3272 - LCD Screen
Easy Maintenance
No need to call for support. Print heads and maintenance cartridge are easily customer replaceable.
PIXMA G3272 - Inserting Maintenance Cartridge
Sharp Text, Crisp Color
Print both documents and photos on a variety of paper types using a hybrid ink system with pigment black for sharp black text and dye-based colors for vivid borderless photos up to 8.5” x 11”.
PIXMA G3272 - Printing Report
Fast Print Speeds
Get the job done quickly with print speeds of up to 11 ipm black and 6 ipm color.Footnote9
PIXMA G3272 - Printing Flyer
100-Sheet Rear Paper Tray
Easily load plain paper, envelopes, labels, high resolution paper, and more in the rear tray.
PIXMA G3272 - Paper Being Feed Into Printer
PosterArtist Banner
Get Creative With Your Printer
Create professional posters and flyers with PosterArtist online. Easy-to-use, free, template-driven poster creation application.
PIXMA G3272 - Person Printing from Mobile Phone
Mobile Connectivity
Print and scan on the go using your compatible mobile device using the Canon PRINT app, Apple AirPrint, and Mopria® Print Service.
Print
Print Functions
Print, Copy, Scan
Print Features
Document Printing, Photo Printing, Wireless PrintingFootnote2, Mobile Device Printing, Borderless PrintingFootnote7, Business Card Printing, Greeting Card Printing, Label Printing, Camera Direct Photo Printing, Square Media Printing Support, Double-sided Matte Paper Support.
Printing Capability
Single Sided (Simplex) Printing, BorderlessFootnote7 Printing (3.5” x 3.5” to 8.5” x 11”)
Print Speed (ESAT)
Black Document (Letter) Simplex: Approx. 11.0 ipmFootnote9
Color Document (Letter) Simplex: Approx. 6.0 ipmFootnote9
Print Resolution
Up to 4800 x 1200 dpiFootnote10
Number of Nozzles
Color (C/M/Y): 384x3 / Pigment Black: 640 / Total: 1,792
Media Handling
Rear Paper Tray:100 Sheets of Plain Paper OR 20 Sheets 4” x 6”
Supported Paper / Media Sizes
3.5” x 3.5” (Square), 4” x 6”, 5” x 5” (Square), 5” x 7”, 7” x 10”, 8” x 10”, Letter (8.5” x 11”), A4, A5, A6, B5, Legal (8.5” x 14”), U.S. #10 Envelopes, Card Size (91 mm x 55 mm), Custom size (width 2.1–8.5 in, length 3.5–47.2 in)
Supported Borderless Printing
3.5” x 3.5” (Square), 4” x 6”, 5” x 5” (Square), 5” x 7”, 7” x 10”, 8” x 10”, Letter (8.5” x 11”), A4, B5, Card Size (91 mm x 55 mm)Footnote7
Canon Paper / Media Compatibility
Plain: Plain Paper, Canon High Resolution Paper; Glossy: Photo Paper Plus Glossy II, Photo Paper Glossy; Semi-Gloss: Photo Paper Plus Semi-Gloss, Photo Paper Pro Luster; Matte: Matte Photo Paper, Double-sided Matte Paper; Other (Canon): Magnetic Photo Paper, Restickable Photo Paper, Iron-On Transfers; Other (non-Canon): Cardstock, Greeting Card, U.S. #10 Envelopes, Recycled paper and Chlorine-free paper can be used
Supported Media Thickness / Weight
Rear Paper Tray:Plain Paper: 64-105 gsm2 OR Canon Paper: Max. approx. 265 gsm (Canon PP-301 Media)
Copy
Copy Features
4-on-1 / 2-on-1 Copy, BorderlessFootnote7 Copy, Document Copy, Fit-to-Page, Frame Erase Copy (Flatbed Only), ID Card Copy, Auto Exposure Copy, Multiple Copy (Up To 99 Pages), Photo Copy, Preset Copy Ratios, Reduction / Zoom Copy (25% - 400%), Standard Copy
Copy Speed (ESAT)
3.2 ipmFootnote9
FCOT: Approx. 23 SecondsFootnote9
Maximum Document Size
8.5” x 11.7” (A4 / Letter)
Scan
Scan Features
Document Scanning, Photo Scanning, Wireless ScanningFootnote2, Scan to Canon PRINT appFootnote1, Attach to Email, Scan Multi-Page PDF, Save to PC
Scanner Type
Single Sided (Simplex) Scanning
Scanning Method
Flatbed
Scanning Resolution
600 x 1200 dpi (Optical)Footnote11
Maximum Color Scanning Bit Depth
Grayscale: 16-bit / 8-bit
Color: 16-bit / 8-bit Per Color
Flatbed: 8.5" x 11.7" (A4 / Letter)
Ink Information
Ink Type
GI-21 Pigment-Based Black Ink Bottle
GI-21 Dye-Based Color Ink Bottles (Cyan, Magenta, Yellow)
Ink Cartridges & Fill Volume
GI-21 PGBK Ink Bottles: 135.0 ml (each)
GI-21 C, M, Y Ink Bottles: 70.0 ml (each)
Page Yield
Default Mode: Up to 6,000 (Black & White) / 7,700 (Color) Pages (Per Full Ink Bottle Set)Footnote5
Economy Mode: Up to 7,600 (Black & White) / 8,100 (Color) Pages (Per Full Ink Bottle Set)Footnote5
Connectivity & Software/Apps
Connectivity Options
Hi-Speed USB
Wi-Fi® (Wireless LAN, 2.4/5 GHz, IIEEE 802.11b/g/n/a/ac)Footnote2
Wireless Information
Standard: IEEE 802.11b/g/n/a/ac
Security: WPA-PSK (TKIP/AES), WPA2-PSK (TKIP/AES), WPA3-SAE (AES)
Wireless LAN Frequency Band(s): 2.4 GHz / 5 GHz
Wireless Direct Connection Capable/ Wireless ConnectFootnote1 Capable: Yes
OS Compatibility
WindowsFootnote12 Windows® 11, Windows® 10, Windows® 8.1, Windows® 7 SP1; Windows Server 2008 R2 SP1, Server 2012 R2, Windows Server 2016, Windows Server 2019, Windows Server 2022
MacFootnote13 macOS v10.14.6 - 12
Mobile Operating SystemsFootnote14 iOS®, iPadOS, Android™
Chromebook CompatibleFootnote15 Yes
Smart Assistant Support No
General
General Features
5-Color Individual Ink System, Auto Power On/Off, Auto Print Head Alignment, Canon PRINT appFootnote2, Document Removal Reminder, Energy Star® CertifiedFootnote18, Hybrid Ink System, Quiet Mode, Wireless ConnectFootnote1
Display
Backlight 1.35” Square LCD Screen Display
Supported Languages
33 Supported Languages: Japanese, English (mm & inch), German, French, Italian, Spanish, Portuguese, Dutch, Danish, Norwegian, Swedish, Finnish, Russian, Ukrainian, Polish, Czech, Slovenian, Hungarian, Slovakian, Croatian, Romanian, Bulgarian, Turkey, Greek, Estonian, Latvian, Lithuanian, Simplified Chinese, Korean, Traditional Chinese, Thai, Indonesia, Vietnamese
Mobile Printing Solutions & Apps (iOS®/AndroidTM)
AirPrint®Footnote3, Mopria® Print ServiceFootnote4, Canon PRINT appFootnote2, Easy PhotoPrint Editor AppFootnote16, Canon Print ServiceFootnote17 (Android Only)
Software
Software (WindowsFootnote12 / MacFootnote13)
PIXMA G3272 Driver, Easy-PhotoPrint Editor SoftwareFootnote15, PosterArtist Web Version SoftwareFootnote6
Power Information
Energy Efficiency: Rated EPEAT Silver, Energy Star® CertifiedFootnote18
Auto Power On / Off Capable: Yes
Input Voltage: AC 100 – 240 V, 50 / 60 Hz
Power Consumption: 16W (0.6W Standby / 0.1W Off)
TEC (Typical Electricity Consumption): 0.15kWh/week
Sound Management
Quiet Mode: Available
Noise Level: Approx. 48.0 dB(A) (Plain Paper)
Operating Environment
Operating Temperature: 41° - 95° F (5° - 35° C)
Operating Humidity: 10 - 90% RH
Printer Dimensions (Closed)
16.4” (L) x 13.3” (W) x 7” (H)
Printer Dimensions (Trays open)
16.4” (L) x 21.9” (W) x 10.6” (H)
Printer Weight
13.2 lbs.
Printer Box Dimensions
19.6” (L) x 19.5” (W) x 10.9” (H)Footnote19
Printer Box Weight
22.26 lbs.
Note
Specifications are subject to change without notice. All viewscreen and output images are simulated.
Brochures
File Name
PIXMA G3272 Brochure
Date
03.05.25
File Size
4.8 MB
MegaTank PIXMA G3272 Wireless All-in-One Printer Compatible Products
Ink
Ink
Product Disclaimer
  1. Requires a smart device with the Canon PRINT app installed and connected to the desired active wireless network to complete cableless setup
  2. Requires an Internet connection and the Canon PRINT app, available for free on the App Store and at Google Play. Compatible with iPad, iPhone 3GS or later, and iPod touch 3rd generation or later devices running iOS 12.0 or later, and Android™ mobile devices running Android 4.4 or later. Your device must be connected to the same working network with wireless 802.11 b/g/n capability as your printer. Requires a compatible social media account and is subject to that social media account’s Terms of Service. Certain exceptions may apply.
  3. AirPrint functionality requires a compatible iPad, iPhone, or iPod Touch device running iOS 7.0 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported.
  4. Requires AndroidTM mobile device with Android 4.4 operating system or later with the Mopria® Print Service pre-loaded with that device and the compatible PIXMA printer on the same wireless network. The Mopria® experience is also available on Android 4.4 or later mobile devices with a download of the Mopria® Print Service from Google Play. Learn more.
  5. Page yield of included ink bottles used for initial setup is lower than the replacement ink bottles, as a certain amount of ink is consumed to fill into the print head during setup (charging the print head initially). Page yield is the estimated value based on Canon individual test method using the ISO/IEC 24712 chart and continuous printing simulation with the replacement ink bottles after initial setup. Page yield of color inks is an average yield of cyan, magenta and yellow inks combined. Page yield varies significantly depending on content printed, ink levels maintained in all four reservoirs, and other factors. Up to 6,000 (black)/7,700 (color) printed page yields are approximate using `default printing mode’, up to 8,300 (black)/7,700 (color) printed page yields are approximate using `economy printing mode’ via Windows/Mac OS driver or printer copy setting, based off document pages printed. A full set of MegaTank GI-21 ink bottles (pigment black, cyan, magenta, yellow) is equivalent to 30 each standard capacity Black (PG-260) and Color (CL-261, composed of cyan, magenta and yellow) ink cartridges sold individually based on print yield. Ink value savings based on MSRP (USD) of stated equivalent ink cartridges as of November 2020.
  6. The online version of PosterArtist requires a personal computer with Internet access and a compatible Canon printer. The service is not available on some operating systems or browsers. See www.usa.canon.com/PosterArtist for details.
  7. Paper types NOT supported for borderless printing are as follows: Envelope, High Resolution Paper, T-Shirt Transfer and Photo Stickers. The maximum borderless printing size is 8.5”x11”.
  8. Warranty programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details
  9. Document print speeds are the averages of ESAT in Office Category Test for the default simplex mode, ISO/IEC 24734. Photo print speed is based on the default setting using ISO/JIS-SCID N2 on Photo Paper Plus Glossy II and does not take into account data processing time on host computer. Print speed may vary depending on system configuration, interface, software, document complexity, print mode, page coverage, type of paper used etc. Copy speeds are the average of sFCOT and sESAT, ISO/IEC 29183. Copy speed may vary depending on document complexity, copy mode, page coverage, type of paper used etc. and does not take into account warming up time. See www.usa.canon.com/ipm for additional details.
  10. Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
  11. Optical resolution is a measure of maximum hardware sampling resolution, based on ISO 14473 standard.
  12. Operation can only be guaranteed on a PC with pre-installed Windows 10, Windows 8.1, Windows 7 SP1.
  13. Internet Connection required during software installation. For full compatibility macOS v10.12.1 or later is recommended.
  14. Some functions may not be available with these Operating Systems. Please refer to manual or Canon website for details.
  15. Functions and features may vary by printer model. Scanning requires Chrome OS 89 or later.
  16. The Easy-PhotoPrint Editor software requires an Internet connection and is compatible with the following operating systems; Microsoft Windows 10 (64-bit/32-bit), Microsoft Windows 8.1 (64-bit/32-bit), Microsoft Windows 7 SP1 (64-bit/32-bit), macOS High Sierra v10.13, macOS Sierra v10.12, Mac OS X El Capitan v10.11 and Mac OS X El Capitan v10.10.5. Minimum Windows and macOS/Mac OS X requirements are: 2GB of RAM and a monitor with 1024x768 resolution. The Easy-PhotoPrint Editor mobile application requires an Internet connection and the Easy-PhotoPrint Editor app v1.1.0, available for free on the App Store and at Google Play. Compatible with iPad Air2 (2nd Generation), iPad Mini 4 and iPhone 6s or later devices running iOS 10 or later, and Android mobile devices running Android 5.x or later. Certain exceptions may apply. The following file formats are supported: JPEG, PNG, HEIF (devices running iOS 11 and mac OS v10.13 or later), DLP save data, Poster Artist export data, EasyPhoto+ export data, Easy- PhotoPrint Editor export data.
  17. Canon Print Service is a print plug-in for Android smart devices, which enables printing from Android v4.4 - v5.0 devices to many Canon printers via a Wi-Fi network. The plug-in does not work as a standalone app. Available for free at Google Play.
  18. As an ENERGY STAR® Partner, Canon U.S.A., Inc. has certified this printer as meeting the ENERGY STAR energy efficiency criteria through an EPA-recognized certification body.
  19. Product box dimensions measured in horizontal box configuration.
  20.  Claim of up to two (2) years of ink based on average monthly document print volumes of 200 pages continuous printing using 'default printing mode'
