Miller Weldmaster T300 Extreme Edge
$0.10
  • Designed for Large Production
  • Perfect for welding over 80 Banners per Month
  • Create Rope Hems, Pole Pockets, Webbing and More
Main Unit Specs
Material Compatibility
Vinyl, Polyurethane, Polypropylene, Polyethylene, Thermoplastic Rubber, Polyester, Webbing
Throat Width
34.5" (0.88m)
Seam Width
0.5" - 2" (10mm to 50mm)
Welding Cycle
Up to 100 ft/min (30 m/min)
Power Requirements
208-240 Volts - Single Phase -25 Amp., 380-400 Volts - Single Phase -16 Amp.
Air Requirements
5cfm @ 120psi
Power Consumption
Approx. 6kW
Maximum Temperature
Hot Air
1,346°F (730°C)
Hot Wedge
842°F (450°C)
Dimensions
Width
23" (0.6m)
Length
59" (1.5m)
Height
59" (1.5m)
Weight
510lb (231kg)
