Mk1500 Cable & Wire Marker Printer
As low as $674.00
Out Of Stock
  • Lightweight and portable
  • Thermal transfer printing on tubes, labels, and tape
  • Three print speeds: 25, 18.5, 12.5 mm per second
  • Print resolution up to 300 dpi
Show more
OVERVIEW
The Canon Mk1500 cable & wire marker printer is a lightweight and portable printer that offers smooth and easy printing from start to finish on a wide range of media.
LX-D5500
ABOUT THE Mk1500 CABLE & WIRE MARKER PRINTER
WIDE VARIETY OF USES
Engineered for speed, accuracy, and ease of use, the Mk1500 printer is ideal to quickly print precise characters onto a wide range of media including tubes, label/wrap-around tapes, and strips, and also offers thermal printing durability. It can be used on-site at locations such as construction sites, factory assembly lines, data centers, server rooms, and power plants, in industries such as construction, manufacturing, and information and communications technology, for applications including automotive / aerospace / medical device manufacturing, quality management, and equipment maintenance / overhaul.
EASY TO USE
The Mk1500 printer is very easy to use. It includes a built-in laptop-style QWERTY-layout rubber keyboard to help ensure both comfort and effi ciency, and its sturdy carry handle and light weight help make it easy to take the printer to job sites. In addition, the Mk1500 printer setup menus are displayed on a large backlit LCD display, ideal for working in dimly lit environments.
HIGH PERFORMANCE
The Mk1500 printer has three selectable speeds and can print up to 35 pieces per minute1, 25 mm/sec, with an internal memory of approximately 7,500 characters, or 25 files. The printer control panel and menus allow users to adjust settings such as automatic full and half cut, as well as depth and cutting speed control, convenient to help assist on large projects.
OUTSTANDING PRINT QUALITY
The Mk1500 printer produces professional-looking printed materials, with up to 300 dpi resolution, making the text and characters look sharp, clear, and crisp. It can also print characters horizontally or vertically, and uses thermal transfer ribbon printing for accurate output.
CUSTOMER CARE
For investment protection, eCarePAK extended service plan options are available beyond the initial two-year advanced exchange limited warranty period. An eCarePAK can help save on costs associated with post-purchase maintenance and help maximize uptime throughout the product life.
Main Unit Spec
Printing Method
Thermal Transfer Method
Resolution
300 dpi
Printing Speed
Tube:
High speed mode: 25 mm/sec
Standard speed mode: 18.5 mm/sec
Low speed mode: 12.5 mm/sec
Label:
Standard/Low speed mode: 12.5 mm/sec
Processing Speed
High speed mode: about 35 pieces/min
Standard speed mode: about 30 pieces/min
Low speed mode: about 21 pieces/min
Conditions for printing and cutting - tube cut length: 20 mm, number of characters: 5 (two-byte characters of 3 mm wide), half cutting: on, cut strength: standard
Ink Ribbon
Ribbon IC cassette (black, white)
Length - black: 100 m, white: 85 m
Size of Characters
2 mm (Kanji characters not supported for this size), 3 mm, 6 mm (both one-byte and two-byte characters supported)
Types of Characters
JIS First-Level Kanji, JIS Second-Level Kanji, symbols
Data Entering
Rubber keyboard, alphanumeric input, area code input, symbol input
Vocabulary of Dictionary
About 5,000 words
Display
LCD graphic display (160 x 64 dots)
Number of Characters Displayed
Input data: 10 characters × 2 lines (two-byte characters), or 20 characters x 2 lines (one-byte characters)
Memory Capacity
Storage for character data: about 2,500 characters*2 Storage for files: about 7,500 characters*2 Folder hierarchy: none
Cutting Method
Automatic half cut, automatic full cut
Power
AC adapter (100 VAC - 240 VAC, 50/60 Hz)
Interface
Operating Environment
Temperature: 15°C to 32.5°C, Humidity: 10% to 85%
Maximum Power Consumption
12.5 W
Storage Environment
Temperature: 5°C to 35°C, Humidity: 10% to 90%
Main Body Dimensions
Width: 250 mm x Depth: 300 mm x Height: 85 mm
Main Body Weight
2 kg
Media Types
Tube:
Commercially available PVC round tube*3
(Inner diameter: 2.5 mm to 5.2 mm, thickness: 0.5 mm)
Label Tape
Cassette (white, yellow, silver) - width: 6 mm, 9 mm, 12 mm, length: 30 m (27 m for silver)*4
Adjustable range of cut length: 8 mm to 150 mm*4
Wrap Around Tape:
Cassette (white in the areas to be printed, transparent in other areas)
Winding length: 8 m, length: 33 mm, width: 8 mm to 150 mm (adjustable by the cut length setting)
Brochures
File Name
Canon Mk1500 Cable & Wire Marker Printer Consumables Accessories Brochure
Date
11.29.22
File Size
0.2 MB
File Name
Canon Mk1500 Service and Support Brochure
Date
11.29.22
File Size
3.5 MB
File Name
Canon Mk1500 Cable & Wire Marker Printer Brochure
Date
11.30.22
File Size
0.2 MB
