The Canon Mk2600 cable & wire marker printer is a lightweight and portable printer designed to easily produce tube, tape, and plate strip cable makers quickly and efficiency.
Mk2600 Cable & Wire Marker Printer
- User-friendly keyboard and bright, large backlit LCD display
- Lightweight and portable
- Thermal transfer printing on tubes, labels, and plastic plate strips
- Three print speeds: 1.5, .9, .7 mm per second
- Print resolution up to 300 dpi
In the box
Return Policy
OVERVIEW
ABOUT THE Mk2600 CABLE & WIRE MARKER PRINTER
WIDE VARIETY OF USES
Engineered for speed, accuracy, and high-quality output, the Mk2600 printer is ideal to produce tube, tape, and plate labels and markers for wires and cables. It can be used on-site at locations such as construction sites, factory assembly lines, data centers, server rooms, and power plants, in industries such as construction, manufacturing, and information and communications technology, for applications including automotive / aerospace / medical device manufacturing, quality management, and equipment maintenance / overhaul.
EASY TO USE
The Mk2600 printer is very easy to use. It includes a built-in laptop-style QWERTY-layout keyboard to help ensure both comfort and efficiency, and its sturdy carry handle and light weight help make it easy to take the printer to job sites. In addition, the Mk2600 printer setup menus are displayed on the high-contrast backlit LCD display, ideal for working in dimly lit environments. Users can easily calculate the cost of media.
HIGH PERFORMANCE
The Mk2600 printer has three selectable speeds and can print up to 42 pieces per minute1, 40 mm/sec, with an internal memory of approximately 60,000 characters, and up to ten folders can be created which can hold up to 99 fi les per folder. The printer control panel and menus allow users to adjust settings such as automatic full and half cut, as well as depth and cutting speed control, convenient to help assist on large projects. It also has the ability to connect to a computer, allowing large quantities of data to be printed, and it can also read CSV-format fi les, which helps reduce the time required for keying data in the field.
OUTSTANDING PRINT QUALITY
The Mk2600 printer produces professional-looking printed materials, with up to 300 dpi resolution, making the text and characters look sharp, clear, and crisp. It can also print characters horizontally or vertically, and has fi ne pitch adjustment to help improve output accuracy. The printer also uses thermal transfer ribbon printing for accurate output.
CUSTOMER CARE
For investment protection, eCarePAK extended service plan options are available beyond the initial two-year advanced exchange limited warranty period. An eCarePAK can help save on costs associated with post-purchase maintenance and help maximize uptime throughout the product life.
Main Unit Spec
Reviews
Brochures
Canon_Mk2600_Cable&WireMarkerPrinter_Brochure_082123.indd
11.29.22
0.2 MB
Canon Mk2600 Service and Support Brochure
11.29.22
3.5 MB
Canon_Mk2600_Cable&WireMarkerPrinter_Brochure_102522.indd
09.14.22
0.3 MB
Product Disclaimer
*1 Printing on 20 mm tubes, 5 full-size characters, consecutive print mode, half-cutting.
