MK3000 Cable & Wire Marker Printer
5058C008
Special Price $599.00 Regular Price $799.00
4 interest free payments of $149.75 with
klarna Pay Later
Paypal Pay Later
In Stock
  • Lightweight and portable
  • Thermal transfer printing on tubes, labels, and tape
  • Backlit LCD display for easy viewing
  • Two print speeds: 25, 18.5 mm per second
  • Print resolution up to 300 dpi
Show more
Add an eCarePAK Extended Service Plan for added coverage. Learn More
Where to Buy
Overview
The Canon MK3000 cable & wire marker printer is designed for portability and productivity. With fast print speeds, broad media support, and dual power supply support, the MK3000 off ers increased flexibility for easy use at work site locations.
MK3000 Banner
Wide Variety of Uses
Engineered to deliver high print performance and exceptional accuracy, the MK3000 printer is ideal for precise character printing onto a wide range of media including tubes (such as heat shrink and flat tubes), and label tapes. It is designed to be used on-site at locations such as construction sites, factory assembly lines, electrical facilities, data centers, server rooms, and power plants, in industries such as construction, manufacturing, and information and communications technology, for applications including automotive / aerospace / medical device manufacturing, quality management, network cable wiring and equipment maintenance / overhaul.
Portable and Easy to Use
The MK3000 printer is very easy to use. It includes a built-in laptop-style QWERTY-layout rubber keyboard to help ensure both comfort and efficiency, and its sturdy carry handle and light weight help make it easy to take the printer to job sites. In addition, the Panasonic eneloop rechargeable batteriesFootnote3 allow you to keep the printer running when field conditions limit the availability of AC power. The MK3000 printer setup menus are also displayed on a large backlit LCD display, ideal for working in dimly lit environments.
High Productivity
The MK3000 printer has two selectable speeds and can print up to 35 pieces per minuteFootnote1, or up to 25-mm/sec. Instead of typing characters and printing on the fly, you can use the internal memory to store character sets and folders to print easily in the field, helping to increase productivity. The serial printing feature also allows for automatic sequential number or letter printing and the printer control panel and menus allow users to adjust settings such as automatic full and half cut, as well as depth and cutting speed control, convenient to help assist on large projects.
Outstanding Print Quality & Media Support
The MK3000 printer is designed to produce professional-looking printed materials, with up to 300 dpi resolution, making the text and characters look sharp, clear, and crisp. It can also print characters horizontally or vertically, and uses thermal transfer ribbon printing, in black or white, for accurate output. The MK3000 printer also supports up to 10mm diameter rounded and flat tube media, as well as labels.
Customer Care
For investment protectionFootnote2, optional eCarePAK extended service plans are available beyond the initial two-year advanced exchange limited warranty period. An eCarePAK can help save on costs associated with post-purchase maintenance and can help maximize uptime throughout the product life.
Main Unit Spec
Type
Replaces
Successor model for Mk1500
Print Method
Thermal Transfer
Ink Ribbon
Cassette for tube and label: (black, white) Length - black: 150m, 40m white: 85m
Print Resolution
300 dpi
Print Speed
Tube and Label: High speed- 25 mm/sec , Low speed- 18.5 mm/sec
Output Rate
High speed approx. 35 pcs/min Low speed approx. 30 pcs/minFootnote1
Character sizes
1.3mm (full width only) 2 mm, 2.6 mm, 3 mm, 4 mm, 6 mm (full width, half width)
Input Modes
Alphanumeric, Symbol input
Display
LCD Graphic (160 x 64 dots) with back light
Display Capacity
10 characters / line x 2 lines (full width)
Built In Memory
Print data: Approx 5,000 characters Files: Approx 250,000 characters, up to 10 folders (each can save 99 files)
Media Cutting Function
Automatic full-cutting, Automatic half-cutting
Power Supply
AC Adapter (input voltage: AC 100V-240V 50/60 Hz, 0.74A) or Panasonic eneloop 1.2V AA rechargeable batteries (model: BK-3MCCE)Footnote2
Power Consumption
Maximum 24 W
PC Interface
USB 2.0, PC Connection Kit included
Operating Environment Temperature
59° - 90.5°F (15° - 32.5°C)
Storage Environment Temperature
41° - 90.5°F (5° - 32.5°C)
Operating Environment Humidity
10 - 85% RH
Storage Environment Humidity
10 - 85% RH
Warranty
2 YearsFootnote3
Dimensions
10.7” (W) x 12.5” (D) x 3.8” (H)
Weight
6.0 lbs.
Reviews
Brochures
File Name
Canon MK3000 Cable & Wire Marker Printer Brochure
Date
01.19.23
File Size
0.4 MB
File Name
Canon MK3000 Cable & Wire Marker Printer Consumables Accessories Brochure
Date
08.14.23
File Size
0.2 MB
Product Disclaimer
  1. Printing 20 mm tubes, 5 full- size characters, consecutive print mode, half-cutting
  2. Batteries are not included with the printer. Only Panasonic eneloop rechargeable batteries (model: BK-3MCCA) should be used to avoid printer safety and warranty issues. "Panasonic" and "eneloop" are registered trademarks of Panasonic Group.
  3. Warranty and support programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details.
  4. Optional plate and flat tube attachment required for printing on plate or flat tube
