MegaTank PIXMA G1230
G1230.
Discontinued
The MegaTank PIXMA G1230 Inkjet Printer is no longer available, but you can find similar products below.
  • Wireless Single Function (Print Only)
  • Up to 2 years of ink included in the boxFootnote14
  • Print up to 6,000 black & white / 7,700 color pages using a single set of inks!Footnote6
  • Save up to $1,000 on ink
  • Single-sided printing
Show more
PIXMA G1230 Intro
PIXMA G1230 Video
Maximize Productivity
MegaTank Means Savings
Versatility For What You Need
Compact Size
Easy to Fill & View Ink Levels
Reliable
Operating Panel
Easy Maintenance
Sharp Text, Crisp Color
Fast Print Speeds
100-sheet Rear Paper Tray
PosterArtist and Printing Connectivity
Print
Print Features
Document Printing, Photo Printing, Borderless PrintingFootnote3, Business Card Printing, Greeting Card Printing, Label Printing, Double-sided Matte Paper Support
Printing Capability
Single Sided (Simplex) Printing, BorderlessFootnote3 Printing (4"x6" and 8.5" x 11")
Print Speed (ESAT)
Black Document (Letter)Simplex: Approx. 11.0 ipmFootnote4
Color Document (Letter) Simplex: Approx. 6.0 ipmFootnote4
Print Resolution
Up to 4800 x 1200 dpiFootnote5
Number of Nozzles
Color (C/M/Y): 384x3 / Pigment Black: 640 / Total: 1,792
Duty Cycle
Up to 3,000 Pages / Month
Media Handling
Rear Paper Tray
Supported Paper/Media Sizes
3.5" x 3.5" (Square), 4" x 6", 5" x 5" (Square), 5" x 7", 7" x 10", 8" x 10", Letter (8.5" x 11"), A4, A5, A6, B5, Legal (8.5" x 14"), U.S. #10 Envelopes, Card Size (91 mm x 55 mm), Custom size (width 2.1–8.5 in, length 3.5–47.2 in)
Supported Borderless Printing
3.5" x 3.5" (Square), 4" x 6", 5" x 5" (Square), 5" x 7", 7" x 10", 8" x 10", Letter (8.5" x 11"), A4, B5, Card Size (91 mm x 55 mm)Footnote3
Canon Paper / Media Compatibility
Plain: Plain Paper, Canon High Resolution Paper; Glossy: Photo Paper Plus Glossy II, Photo Paper Glossy; Semi-Gloss: Photo Paper Plus Semi-Gloss, Photo Paper Pro Luster; Matte: Matte Photo Paper, Double-sided Matte Paper; Other (Canon): Magnetic Photo Paper, Restickable Photo Paper, Iron-On Transfers; Other (non- Canon): Cardstock, Greeting Card, U.S. #10 Envelopes, Recycled paper and Chlorine-free paper can be used
Paper Compatibility
Rear Paper Tray: 100 Sheets of Plain Paper OR 20 Sheets 4" x 6"
Supported Media Thickness / Weight
Rear Paper Tray: Plain Paper: 64-105 gsm2 OR Canon Paper: Max. approx. 265 gsm (Canon PP-301 Media)
Ink Information
INK SYSTEM & INFORMATION
4-Color Continuous Ink Supply System (CISS), FINE Print Heads, Hybrid Ink System, Integrated Ink Tanks, ‘Squeeze-Free’ Ink Bottles For Easy & Mess Free Ink Filling, Unique Color Bottle Tip Shape for Correct Filling Every Time
INK TYPE
GI-21 Pigment-Based Black Ink Bottle
GI-21 Dye-Based Color Ink Bottles (Cyan, Magenta, Yellow)
INK TANK & FILL VOLUME
GI-21 PGBK Ink Bottles: 135.0 ml (each)
GI-21 C, M, Y Ink Bottles: 70.0 ml (each)
HIGH PAGE YIELD
Default Mode:Footnote1
Up to 6,000 (Black & White) / 7,700 (Color) Pages (Per Full Ink Bottle Set)
Economy Mode:Footnote1
Up to 7,600 (Black & White) / 8,100 (Color) Pages (Per Full Ink Bottle Set)
General
Dimensions (W x D x H)
Closed: 16.4" x 13" x 5.8" (WxDxH)
Trays Open: 16.4" x 21.9" x 10.6" (WxDxH)
Printer Weight
10.1 lbs.
Printer Box Dimensions
19.6" (L) x 19.5" (W) x 9.6" (H)Footnote13
Printer Box Weight
19.18 lbs.
Connectivity
Hi-Speed USB
OS Compatibility
Windows:Footnote6 Windows® 11, Windows® 10, Windows® 8.1, Windows® 7 SP1; Windows Server 2008 R2 SP1, Server 2012 R2, Windows Server 2016, Windows Server 2019, Windows Server 2022
Mac:Footnote7 macOS v10.14.6 - 12
Operating Systems:Footnote8 Chromebook CompatibleFootnote9
Software
(WindowsFootnote6/MACFootnote7): PIXMA G1230 Driver, Easy-PhotoPrint Editor SoftwareFootnote10, PosterArtist Web Version SoftwareFootnote2
General Features
Auto Power On/Off (PC only), Quiet Mode, AirPrint (PC only)
Supported Languages
32 Supported Languages: Japanese, English(mm & inch), German, French, Italian, Spanish, Dutch, Portuguese, Norwegian, Swedish, Danish, Finnish, Russian, Czech, Hungarian, Polish, Slovene, Turkish, Greek, Simplified Chinese, Traditional Chinese, Korean, Indonesian, Slovakian, Estonian, Latvian, Lithuanian, Ukrainian, Romanian, Bulgarian, Croatian, Vietnamese
Power Information
Energy Efficiency: Rated EPEAT Silver, Energy Star® CertifiedFootnote11
Auto Power On / Off Capable: Yes (PC only)
Input Voltage: AC 100 – 240 V, 50 / 60 Hz
Power Consumption: 14W (0.6W Standby / 0.1W Off)
TEC (Typical Electricity Consumption): 0.1 kWh/week
Sound Management
Quiet Mode: Available Noise Level: Approx. 49.0 dB(A) (Plain Paper)
Warranty
1-Year Limited Warranty with InstantExchange ProgramFootnote12
Reviews
Brochures
File Name
PIXMA G1230 Brochure
Date
03.05.25
File Size
2.6 MB
MegaTank PIXMA G1230 Compatible Products
Ink
Ink
Product Disclaimer
  1. Page yield of included ink bottles used for initial setup is lower than the replacement ink bottles, as a certain amount of ink is consumed to fill into the print head during setup (charging the print head initially). Page yield is the estimated value based on Canon individual test method using the ISO/IEC 24712 chart and continuous printing simulation with the replacement ink bottles after initial setup. Page yield of color inks is an average yield of cyan, magenta and yellow inks combined. Page yield varies significantly depending on content printed, ink levels maintained in all four reservoirs, and other factors. Up to 6,000 (black)/7,700 (color) printed page yields are approximate using `default printing mode’, up to 8,300 (black)/7,700 (color) printed page yields are approximate using `economy printing mode’ via Windows/Mac OS driver or printer copy setting, based off document pages printed. A full set of MegaTank GI-21 ink bottles (pigment black, cyan, magenta, yellow) is equivalent to 30 each standard capacity Black (PG-260) and Color (CL-261, composed of cyan, magenta and yellow) ink cartridges sold individually based on print yield. Ink value savings based on MSRP (USD) of stated equivalent ink cartridges as of November 2020.
  2. PosterArtist Online Version requires a personal computer with Internet access and a compatible Canon printer. The service is not available on some operating systems or browsers. See www.usa.canon.com/PosterArtist for details.
  3. Paper types NOT supported for borderless printing are as follows: Envelope, High Resolution Paper, T-Shirt Transfer and Photo Stickers. The maximum borderless printing size is 8.5”x11”.
  4. Document print speeds are the averages of ESAT in Office Category Test for the default simplex mode, ISO/IEC 24734. Photo print speed is based on the default setting using ISO/JIS-SCID N2 on Photo Paper Plus Glossy II and does not take into account data processing time on host computer. Print speed may vary depending on system configuration, interface, software, document complexity, print mode, page coverage, type of paper used etc. Copy speeds are the average of sFCOT and sESAT, ISO/IEC 29183. Copy speed may vary depending on document complexity, copy mode, page coverage, type of paper used etc. and does not take into account warming up time. See www.usa.canon.com/ipm for additional details.
  5. Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
  6. Operation can only be guaranteed on a PC with pre-installed Windows 10, Windows 8.1, Windows 7 SP1.
  7. Internet Connection required during software installation. For full compatibility macOS v10.12.1 or later is recommended.
  8. Some functions may not be available with these Operating Systems. Please refer to manual or Canon website for details.
  9. Functions and features may vary by printer model. Scanning requires Chrome OS 89 or later.
  10. The Easy-PhotoPrint Editor software requires an Internet connection and is compatible with the following operating systems; Microsoft Windows 10 (64-bit/32-bit), Microsoft Windows 8.1 (64-bit/32-bit), Microsoft Windows 7 SP1 (64-bit/32-bit), macOS High Sierra v10.13, macOS Sierra v10.12, Mac OS X El Capitan v10.11 and Mac OS X El Capitan v10.10.5. Minimum Windows and macOS/Mac OS X requirements are: 2GB of RAM and a monitor with 1024x768 resolution. The Easy-PhotoPrint Editor mobile application requires an Internet connection and the Easy-PhotoPrint Editor app v1.1.0, available for free on the App Store and at Google Play. Compatible with iPad Air2 (2nd Generation), iPad Mini 4 and iPhone 6s or later devices running iOS 10 or later, and Android mobile devices running Android 5.x or later. Certain exceptions may apply. The following file formats are supported: JPEG, PNG, HEIF (devices running iOS 11 and mac OS v10.13 or later), DLP save data, Poster Artist export data, EasyPhoto+ export data, Easy- PhotoPrint Editor export data.
  11. As an ENERGY STAR® Partner, Canon U.S.A., Inc. has certified this printer as meeting the ENERGY STAR energy efficiency criteria through an EPA-recognized certification body.
  12. Warranty programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details.
  13. Product box dimensions measured in horizontal box configuration.
  14.  Claim of up to two (2) years of ink based on average monthly document print volumes of 200 pages continuous printing using 'default printing mode'
