MegaTank PIXMA G2270
G2270.
Discontinued
Estimated ship date
The MegaTank PIXMA G2270 All-in-One Printer is no longer available, but you can find similar products below.
  • Print/Copy/Scan
  • Up to 2 years of ink included in the box.15
  • Print up to 6,000 black & white / 7,700 color pages using a single set of inks!6
  • Save up to $1,000 on ink
  • 1.2” Segmented LCD display (monochrome)
  • Single-sided printing
Similar models to the MegaTank PIXMA G2270
Print
Print Features
Document Printing, Photo Printing, Borderless Printing3, Business Card Printing, Greeting Card Printing, Label Printing, Square Media Printing Support, Double-sided Matte Paper Support.
Printing Capability
Single Sided (Simplex) Printing, Borderless3 Printing (3.5" x 3.5" to 8.5" x 11")
Print Speed (ESAT)
Black Document (Letter)Simplex: Approx. 11.0 ipm4
Color Document (Letter) Simplex: Approx. 6.0 ipm 4
Print Resolution
Up to 4800 x 1200 dpi5
Number of Nozzles
Color (C/M/Y): 384x3 / Pigment Black: 640 / Total: 1,792
Duty Cycle
Up to 3,000 Pages / Month
Media Handling
Rear Paper Tray
Supported Paper / Media Sizes
3.5" x 3.5" (Square), 4" x 6", 5" x 5" (Square), 5" x 7", 7" x 10", 8" x 10", Letter (8.5" x 11"), A4, A5, A6, B5, Legal (8.5" x 14"), U.S. #10 Envelopes, Card Size (91 mm x 55 mm), Custom size (width 2.1–8.5 in, length 3.5–47.2 in)
Supported Borderless Printing
3.5" x 3.5" (Square), 4" x 6", 5" x 5" (Square), 5" x 7", 7" x 10", 8" x 10", Letter (8.5" x 11"), A4, B5, Card Size (91 mm x 55 mm)3
Canon Paper / Media Compatibility
Plain: Plain Paper, Canon High Resolution Paper; Glossy: Photo Paper Plus Glossy II, Photo Paper Glossy; Semi-Gloss: Photo Paper Plus Semi-Gloss, Photo Paper Pro Luster; Matte: Matte Photo Paper, Double-sided Matte Paper; Other (Canon): Magnetic Photo Paper, Restickable Photo Paper, Iron-On Transfers; Other (non-Canon): Cardstock, Greeting Card, U.S. #10 Envelopes, Recycled paper and Chlorine-free paper can be used
Paper Capacity
Rear Paper Tray: 100 Sheets of Plain Paper OR 20 Sheets 4" x 6"
Supported Media Thickness / Weight
Rear Paper Tray: Plain Paper: 64-105 gsm2 OR Canon Paper: Max. approx. 265 gsm (Canon PP-301 Media)
Copy
Copy Features
4-on-1 / 2-on-1 Copy, Borderless8 Copy, Document Copy, Fit-to-Page, Frame Erase Copy (Flatbed Only), ID Card Copy, Auto Exposure Copy, Multiple Copy (Up To 20 Pages), Photo Copy, Preset Copy Ratios, Reduction / Zoom Copy (25% - 400%), Standard Copy
Maximum Document Size
8.5" x 11.7" (A4 / Letter)
Scan
Scan Features
Document Scanning, Photo Scanning.
Scanning Capability
Single Sided (Simplex) Scanning
Scanner Type
Flatbed
Scanning Method
Contact Image Sensor (CIS)
Scanning Resolution
600 x 1200 dpi (Optical)
Maximum Color Scanning Bit Depth
Grayscale: 16-bit / 8-bit
Color: 16-bit / 8-bit Per Color
Flatbed: 8.5" x 11.7" (A4 / Letter)
Ink Information
Ink System & Information
4-Color Continuous Ink Supply System (CISS), FINE Print Heads, Hybrid Ink System, Integrated Ink Tanks, ‘Squeeze-Free’ Ink Bottles For Easy & Mess Free Ink Filling, Unique Color Bottle Tip Shape for Correct Filling Every Time
Ink Type
GI-21 Pigment-Based Black Ink Bottle
GI-21 Dye-Based Color Ink Bottles (Cyan, Magenta, Yellow)
Ink Tank & Fill Volume
GI-21 PGBK Ink Bottles: 135.0 ml (each)
GI-21 C, M, Y Ink Bottles: 70.0 ml (each)
High Page Yield
Default Mode:1
Up to 6,000 (Black & White) / 7,700 (Color) Pages (Per Full Ink Bottle Set)
Economy Mode:1
Up to 7,600 (Black & White) / 8,100 (Color) Pages (Per Full Ink Bottle Set)
General
Connectivity
Hi-Speed USB
Display
1.2" Segment LCD (Monochrome)
OS Compatibility
Windows:7 Windows® 11, Windows® 10, Windows® 8.1, Windows® 7 SP1; Windows Server 2008 R2 SP1, Server 2012 R2, Windows Server 2016, Windows Server 2019, Windows Server 2022
Mac:8 macOS v10.14.6 - 12
Operating Systems:9 Chromebook Compatible10
Software
(Windows7/MAC8): PIXMA G2270 Driver, Easy-PhotoPrint Editor Software11, PosterArtist Web Version Software2
General Features
Auto Power On/Off, Print/Scan/Copy, Quiet Mode, AirPrint (PC only)
Supported Languages
32 Supported Languages: Japanese, English(mm & inch), German, French, Italian, Spanish, Dutch, Portuguese, Norwegian, Swedish, Danish, Finnish, Russian, Czech, Hungarian, Polish, Slovene, Turkish, Greek, Simplified Chinese, Traditional Chinese, Korean, Indonesian, Slovakian, Estonian, Latvian, Lithuanian, Ukrainian, Romanian, Bulgarian, Croatian, Vietnamese
Power Information
Energy Efficiency: Rated EPEAT Silver, Energy Star® Certified12
Auto Power On / Off Capable: Yes
Input Voltage: AC 100 – 240 V, 50 / 60 Hz
Power Consumption: 14W (0.6W Standby / 0.1W Off)
TEC (Typical Electricity Consumption): 0.1 kWh/week
Sound Management
Quiet Mode: Available
Noise Level: Approx. 48.5 dB(A) (Plain Paper)
Operating Environment
Operating Temperature: 41° - 95° F (5° - 35° C)
Operating Humidity: 10 - 90% RH
Warranty
1-Year Limited Warranty with InstantExchange Program13
Dimensions (W x D x H)
Closed: 16.4" x 13.3" x 7.0" (WxDxH)
Trays Open: 16.4" x 21.9" x 10.6" (WxDxH)
Printer Weight
13.2 lbs.
Printer Box Dimensions
19.6" (L) x 19.5" (W) x 10.9" (H)
Printer Box Weight
22.26 lbs.
Reviews
Brochures
File Name
PIXMA G2270 Brochure
Date
03.05.25
File Size
2.6 MB
MegaTank PIXMA G2270 Compatible Products
Ink
Ink
Paper
Other Accessories
Ink
Product Disclaimer
  1. Page yield of included ink bottles used for initial setup is lower than the replacement ink bottles, as a certain amount of ink is consumed to fill into the print head during setup (charging the print head initially). Page yield is the estimated value based on Canon individual test method using the ISO/IEC 24712 chart and continuous printing simulation with the replacement ink bottles after initial setup. Page yield of color inks is an average yield of cyan, magenta and yellow inks combined. Page yield varies significantly depending on content printed, ink levels maintained in all four reservoirs, and other factors. Up to 6,000 (black)/7,700 (color) printed page yields are approximate using `default printing mode’, up to 8,300 (black)/7,700 (color) printed page yields are approximate using `economy printing mode’ via Windows/Mac OS driver or printer copy setting, based off document pages printed. A full set of MegaTank GI-21 ink bottles (pigment black, cyan, magenta, yellow) is equivalent to 30 each standard capacity Black (PG-260) and Color (CL-261, composed of cyan, magenta and yellow) ink cartridges sold individually based on print yield. Ink value savings based on MSRP (USD) of stated equivalent ink cartridges as of November 2020.
  2. PosterArtist Online Version requires a personal computer with Internet access and a compatible Canon printer. The service is not available on some operating systems or browsers. See usa.canon.com/PosterArtist for details.
  3. Paper types NOT supported for borderless printing are as follows: Envelope, High Resolution Paper, T-Shirt Transfer and Photo Stickers. The maximum borderless printing size is 8.5”x11”.
  4. Document print speeds are the averages of ESAT in Office Category Test for the default simplex mode, ISO/IEC 24734. Photo print speed is based on the default setting using ISO/JIS-SCID N2 on Photo Paper Plus Glossy II and does not take into account data processing time on host computer. Print speed may vary depending on system configuration, interface, software, document complexity, print mode, page coverage, type of paper used etc. Copy speeds are the average of sFCOT and sESAT, ISO/IEC 29183. Copy speed may vary depending on document complexity, copy mode, page coverage, type of paper used etc. and does not take into account warming up time. See www.usa.canon.com/ipm for additional details.
  5. Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
  6. Optical resolution is a measure of maximum hardware sampling resolution, based on ISO 14473 standard.
  7. Operation can only be guaranteed on a PC with pre-installed Windows 10, Windows 8.1, Windows 7 SP1.
  8. Internet Connection required during software installation. For full compatibility macOS v10.12.1 or later is recommended.
  9. Some functions may not be available with these Operating Systems. Please refer to manual or Canon website for details.
  10. Functions and features may vary by printer model. Scanning requires Chrome OS 89 or later.
  11. The Easy-PhotoPrint Editor software requires an Internet connection and is compatible with the following operating systems; Microsoft Windows 10 (64-bit/32-bit), Microsoft Windows 8.1 (64-bit/32-bit), Microsoft Windows 7 SP1 (64-bit/32-bit), macOS High Sierra v10.13, macOS Sierra v10.12, Mac OS X El Capitan v10.11 and Mac OS X El Capitan v10.10.5. Minimum Windows and macOS/Mac OS X requirements are: 2GB of RAM and a monitor with 1024x768 resolution. The Easy-PhotoPrint Editor mobile application requires an Internet connection and the Easy-PhotoPrint Editor app v1.1.0, available for free on the App Store and at Google Play. Compatible with iPad Air2 (2nd Generation), iPad Mini 4 and iPhone 6s or later devices running iOS 10 or later, and Android mobile devices running Android 5.x or later. Certain exceptions may apply. The following file formats are supported: JPEG, PNG, HEIF (devices running iOS 11 and mac OS v10.13 or later), DLP save data, Poster Artist export data, EasyPhoto+ export data, Easy- PhotoPrint Editor export data.
  12. As an ENERGY STAR® Partner, Canon U.S.A., Inc. has certified this printer as meeting the ENERGY STAR energy efficiency criteria through an EPA-recognized certification body.
  13. Warranty programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details.
  14. Product box dimensions measured in horizontal box configuration.
  15.  Claim of up to two (2) years of ink based on average monthly document print volumes of 200 pages continuous printing using 'default printing mode'
