PIXMA MG2525
MG2525 BK
Discontinued
The PIXMA MG2525
is no longer available, but you can find similar products below.
- Wired 3-in-1 (Print | Copy | Scan)
- 8 / 4 ipm Print Speed
- 60 Sheet Capacity
- USB connect only
- 1 Year Warranty
Similar models to the PIXMA MG2525
View Full Technical Specs PDF
Techs. Specs. Detailed PDF
Main Unit Spec
Printer
Print Speed (up to)
Black:ESAT (Black): Approx. 8.0 ipm
2
Color:ESAT (Color): Approx. 4.0 ipm 2
Number of Nozzles
Color: 960 / Pigment Black: 320 / Total: 1,280
Picoliter Size (color)
2 and 5 Picoliters
Print Resolution (Up to)
Color:Color: Up to 4800 x 600 dpi
3
Black:Pigment Black: Up to 600 x 600 dpi 3
Ink Compatibility
PG-245/PG-243: Pigment Black Ink
CL-246 /CL-244: Dye Based Color Ink
FINE INK CARTRIDGE & FILL VOLUME
PG-245 PGBK 8.0 ml (Std) / 12.0 ml (XL)
CL-246 Color 9.0 ml (Std) / 13.0 ml (XL)
PG-243 PGBK 5.6 ml
CL-244 Color 6.2 ml
Shop Compatible Ink
PG-243 PGBK 5.6 ml
CL-244 Color 6.2 ml
Shop Compatible Ink
Paper Sizes
4" x 6", 5" x 7", Letter, Legal, U.S. #10 Envelopes
Paper Compatibility
Plain: Plain Paper
Other: U.S. #10 Envelopes
Printer Features
Document Printing, My Image Garden1, Photo Printing, Quiet Mode, Red-Eye Correction, Special Filters
Output Tray Capacity
Rear Paper Tray: 60 Sheets of Plain Paper OR 20 Sheets of 4" x 6" Glossy Photo Paper
Copier
Copy Speed (up to)
FCOT (Color): Approx. 31 seconds
2
Copy Features
Standard Copy
Scanner
Scanner Type
Flatbed
Scanning Element
Contact Image Sensor (CIS)
Max. Resolutions
Optical:600 x 1200 dpi (Optical)
5
Interpolated:19,200 x 19,200 dpi (Interpolated) 5
Color Depth
48-bit Internal / 24-bit External
Max. Document Size
8.5" x 11.7"
General
Other Features
Hybrid Ink System, 4-Color Cartridge System, Auto Power On, Quiet Mode
OS Compatibility
Windows:
7
Windows
10, Windows 8, Windows 8.1, Windows 7, Windows 7 SP1, Windows Vista
SP1, Vista SP2, Windows XP SP3 32-bit
Mac: 8 Mac OS ® X v10.7.5 - 10.11
Standard Interface
Hi-Speed USB
Software Included
WINDOWS
7
/MAC
8
PIXMA MG2525 Printer Driver & Setup Software
Scan Utility
Scan Utility
Warranty
1-Year limited warranty with InstantExchange Program. 1-Year toll-free technical phone support.
10
Reviews
PIXMA MG2525 Compatible Products
Ink
Ink
Paper
Ink
Product Disclaimer
- To install using Windows® OS, .NET Framework 4 is required. Compatible still image formats are PDF (created using Canon PDF Creator only), JPEG (Exif), TIFF, and PNG. Compatible video formats are MOV (from select Canon digital cameras only) and MP4 (from select Canon digital camcorders only).
- Document print speeds are the averages of ESAT in Office Category Test for the default simplex mode, ISO/IEC 24734. Photo print speed is based on the default setting using ISO/JIS-SCID N2 on Photo Paper Plus Glossy II and does not take into account data processing time on host computer. Print speed may vary depending on system configuration, interface, software, document complexity, print mode, page coverage, type of paper used etc. Copy speeds are the average of sFCOT and sESAT, ISO/IEC 29183.Copy speed may vary depending on document complexity, copy mode, page coverage, type of paper used etc. and does not take into account warming up time. See https://www.usa.canon.com/printers/iso-productivity-standards for additional details.
- Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/600 inch at minimum.
- The fastest speed in Hi-speed USB on Windows PC. Transfer time to computer not included.
- Optical resolution is a measure of maximum hardware sampling resolution, based on ISO 14473 standard.
- CREATIVE PARK PREMIUM is a premium content service available exclusively to users only when all of the colors of genuine Canon inks and all of the software that came with the printer are properly installed.
- Operation can only be guaranteed on a PC with pre-installed Windows 10, Windows 8.1, Windows 8, Windows 7, Vista or XP.
- Internet Connection required during software installation.
- "Full HD Movie Print" is available from "MOV" and "MP4" movie files created by select Canon EOS Digital SLRs, PowerShot, and VIXIA digital cameras and camcorders. Requires PC or Mac with Intel® processor and Canon ZoomBrowser EX 6.5 or later or Canon ImageBrowser 6.5 or later for "MOV" files, or Canon ImageBrowser EX 1.0 or later for "MOV" or "MP4" files. Print quality is determined by the video resolution. Function does not upscale video resolution.
- Warranty programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details.
