PIXMA MX532
MX532
As low as $149.99
Out Of Stock
  • Wireless 4-in-1 (Print | Copy | Scan | Fax)
    • 9.7 / 5.5 ipm Print Speed
    • 100 Sheet Capacity
    • Auto 2-Sided Printing
    • ADF
    • 1 Year Warranty
Return Policy
View Full Technical Specs PDF
Main Unit Spec
Printer
Print Speed (up to)
4" x 6" Borderless Photo: Approx. 46 seconds4,5
Print Speed (Approx)
Black:ESAT: Approx. 9.7 ipm4,5
Color:ESAT: Approx. 5.5 ipm4,5
Number of Nozzles
Black: 1,152
Color: 640
Total: 1,792
Picoliter Size (color)
2 and 5
Print Resolution (Up to)
Color:Up to 4800 x 1200 dpi3
Black:Up to 600 x 600 dpi3
Ink Compatibility
Ink Compatibility
PG-240XXL XXL Black Ink Cartridge
PG-240XL XL Black Ink Cartridge
PG-240 Black Ink Cartridge
CL-241XL XL Color Ink Cartridge
CL-241 Color Ink Cartridge
Shop Compatible Ink
Paper Sizes
4" x 6", 5" x 7", 8" x 10", Letter, Legal, U.S. #10 Envelopes
Automatic Sheet Feeder
100 Sheets
ADF:30 Sheets
Paper Compatibility
Plain: Plain Paper, High Resolution Paper;
Super High Gloss: Photo Paper Pro Platinum;
Matte: Matte Photo Paper;
Envelope: U.S. #10 Envelope
Printer Features
Auto Document Feeder, AirPrint10, Auto Duplex Print, Borderless Printing13, Document Printing, Full HD Movie Print14, Special Filters, Photo Printing, Canon Print App2, Wireless Printing1
Copier
Copy Speed (up to)
ESAT: Color: 4.7 ipm4
Reduction / Enlargement
25% - 400%
Copy Features
Auto Document Feeder (ADF), AE (Auto Exposure) Copy, Borderless, Fit-to-Page, Preset Copy Ratios, Frame Erase Copy, Zoom
Scanner
Scanning Element
Contact Image Sensor (CIS)
Max. Resolutions
Optical: 1200 x 2400 dpi16
Interpolated: 19,200 x 19,200 dpi16
ADF: 600 x 600 dpi (Optical)16
Scanner Features
Auto Scan Mode9, Network Scan, Push Scan, Scan to Memory (USB)
Color Depth
48-bit internal/24-bit external
Max. Document Size
Flatbed: 8x5" x 11.7"
ADF: 8.5" x 14"
Fax
Modem Speed
33.6 Kbps (Super G3 color FAX)15
Transmission Speed (approx.)
Black: Approx. 3 sec per page16
Color: Approx. 1 min per page16
Memory Capacity
Approx. 50 Pages17
Group Dialing
19
Fax Features
Answering Machine Connectivity, Caller Rejection, Check RX Fax Info., Fax Reception Reject, Fax Number Re-Entry, Memory Transmission, Redial, Remote Reception
Other Features
2-Line LCD, Dual Color Gamut Processing Technology, Fully Integrated Auto Document Feeder (ADF), PIXMA Cloud Link12, Wireless Printing1
General
Other Features
AirPrint10
Wireless Printing1
2-Line LCD Display
Full HD Movie Print6
Fully-Integrated Auto Document Feeder
PictBridge
FastFront
Quick Start
OS Compatibility
Computer Operating Systems:
Windows® 8, Windows 8.1, Windows 7,19
Windows 7 SP1, Window Vista SP1, Vista SP2, Windows XP SP3 32-bit19
Mac OS X v10.6.8- v10.919Mobile Operating Systems:
iOS, Android, Windows RT19
Standard Interface
Wireless LAN (IEEE 802.11b/g/n)1
Hi-Speed USB
USB Flash Memory
Bluetooth® v2.0 (Optional)18
Dimension (W x D x H)
18.1" (W) x 15.2" (D) x 7.9" (H)
Weight
18.7 lbs
Warranty
1-Year limited warranty with InstantExchange Program. 1-Year toll-free technical phone support.21
Reviews
Product Disclaimer
  1. Wireless printing requires a working network with wireless 802.11b/g or n capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
  2. Requires an Internet connection and the Canon PRINT Inkjet/SELPHY app, available for free on the App Store and at Google Play. Compatible with iPad, iPhone 3GS or later, and iPod touch 3rd generation or later devices running iOS 7.0 or later, and Android mobile devices running Android 2.3.3 or later. Your device must be connected to the same working network with wireless 802.11 b/g/n capability as your printer. For users of compatible Apple mobile devices, document printing requires Apple AirPrint, which requires an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported.
  3. Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
  4. "ISO/IEC 24734, 24735 define the default print and copy speed measurement methods. Print speeds are the averages of ESAT in Office Category Test for the default simplex mode, ISO/IEC 24734, excluding time to print the first set. Copy speed is the average of FCOT, ISO/IEC 24735 Annex D. ADF copy speed is the average of ESAT in General Performance Test for the default simplex mode, ISO/IEC 24735, excluding time to copy the first set. See our https://www.usa.canon.com/printers/iso-productivity-standards for additional details."
  5. Photo print speeds are based on the standard mode driver setting using photo test pattern(s) and select Canon Photo Paper. Print speed is measured as soon as first page begins to feed into printer and will vary depending on system configuration, interface, software, document complexity, print mode, types of paper used, and page coverage. See for additional information.
  6. Optical resolution is a measure of maximum hardware sampling resolution, based on ISO 14473 standard.
  7. To install using Windows® OS, .NET Framework 4 is required. Compatible still image formats are PDF (created using Canon PDF Creator only), JPEG (Exif), TIFF, and PNG. Compatible video formats are MOV (from select Canon digital cameras only) and MP4 (from select Canon digital camcorders only).
  8. CREATIVE PARK PREMIUM is a premium content service available exclusively to users only when all of the colors of genuine Canon inks and all of the software that came with the printer are properly installed.
  9. For network users, Auto Scan Mode is available only when scanning at a computer using MP Navigator EX software and selecting the 1-click feature then Save to PC.
  10. AirPrint functionality requires an iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported.
  11. Requires an Internet connection and Google account. Subject to Google Terms of Service. Certain exceptions may apply.
  12. Requires smartphone or tablet and with compatible Canon PRINT app and internet connection.
  13. Envelopes and High Resolution Paper are NOT supported for borderless printing.
  14. "Full HD Movie Print" is available from "MOV" and "MP4" movie files created by select Canon EOS Digital SLRs, PowerShot, and VIXIA digital cameras and camcorders. Requires PC or Mac with Intel® processor and Canon ZoomBrowser EX 6.5 or later or Canon ImageBrowser 6.5 or later for "MOV" files, or Canon ImageBrowser EX 1.0 or later for "MOV" or "MP4" files. Print quality is determined by the video resolution. Function does not upscale video resolution.
  15. The Public Switched Telephone Network currently supports fax modem speeds of 28.8 Kbps or lower, depending on telephone line conditions. Sending and receiving fax machines need to conform to ITU-T v.34 guidelines.
  16. Black & white document fax transmission speed is based on default setting using ITU-T No.1 chart. Color document fax transmission speed is based on default setting using Canon Color Fax Test Sheet. Actual transmission speed vary depending on document complexity, fax setting at receiving end, and line conditions etc.
  17. Page count is based on ITU-T No.1 chart or Canon FAX Standard Chart No.1.
  18. Requires mobile phone (or other device) equipped with Bluetooth v2.0 technology and optional Canon Bluetooth Unit BU-30. Bluetooth operation depends on the device and software version used. Operating distance is approx. 10 meters but may vary due to obstacles, radio signals, locations where radio interference occurs, magnetic fields from microwave ovens, device sensitivity and/or antenna performance.
  19. System requirements vary by application. For Mac OS, an Internet connection is required during software installation. For Windows OS, .NET Framework 4 is required to install My Image Garden, Quick Menu, and Easy-WebPrint EX software.
  20. Easy-WebPrint EX requires Internet Explorer 7 or 8 for Windows, Internet Explorer 9 for Windows Vista SP2 (or later) or Windows 7, or Safari 4.0 - 5.0 for Mac OS X v10.5 - 10.6.x.
  21. Warranty programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details.
