PIXMA TR4520
TR4520 BL
As low as
$99.99
Out Of Stock
- Wireless 4-in-1 (Print | Copy | Scan | Fax)
- 8.8 / 4.4 ipm Print Speed
- 100 Sheet Capacity
- Auto 2-Sided Printing
- ENERGY STAR®
- 1 Year Warranty
Need to order more than 10?
Learn More
Need help making a purchase? Contact a Sales Expert at 800-385-2155>
Return Policy
Main Unit Spec
Printer
Print Speed (up to)
4" x 6" Photo: Approx. 70.0 Seconds (Borderless)11
Black:ESAT Approx. 8.8 ipm11
Color:ESAT Approx. 4.4 ipm11
Number of Nozzles
Color: 960 / Pigment Black: 320 / Total: 1,280
Print Resolution (Up to)
Up to 4800 x 1200 dpi12
Ink Compatibility
INK TYPE
PG-245/PG-243 Pigment Black Ink
CL-246/CL-244 Dye Based Inks
INK TANK & FILL VOLUME
PG-245 Black 8.9 ml (Std.) | 12.0 ml (XL)
CL-246 Color 9.0 ml (Std.) | 13.0 ml (XL)
PG-243 Black 5.6 ml
CL-244 Color 6.2 ml
Shop Compatible Ink
PG-243 Black 5.6 ml
CL-244 Color 6.2 ml
Shop Compatible Ink
Paper Sizes
4" x 6", 5" x 7", 8" x 10", Letter, Legal, U.S. #10 Envelopes
Paper Compatibility
Plain: Plain Paper, Canon High Resolution Paper;
Super High Gloss: Photo Paper Pro Platinum;
Matte: Matte Photo Paper
Other: Greeting Cards,U.S. #10 Envelopes
Printer Features
AirPrint2, Mopria® Print Service5, Auto 2-Sided (Duplex) Printing, Borderless Printing 4, Canon PRINT app3, Document Printing, Easy-PhotoPrint Editor Software/app8, Greeting Cards, Photo Printing, PIXMA Cloud Link3, Template Print, Wireless Printing1
Paper Handling
Front Paper Cassette: 100 Sheets of Plain Paper OR 20 Sheets of 4" x 6" / 10 Sheets of 5" x 7" Photo Paper
Copier
Copy Speed (up to)
FCOT (Color): Approx. 27 seconds 12
Document Feeder
Capacity: 20 Sheets of Plain Paper / 5 Sheets of Legal Size Paper
Copy Features
4-on-1/2-on-1 Copy, Auto Document Feeder (ADF), Auto Exposure (AE) Copy, Borderless Copy, Collated Copy (ADF Only), Document Removal Reminder, Fit-to-Page, Frame Erase Copy (Flatbed Only), ID Card Copy, Multiple Copy (Up To 99 Pages), Preset Copy Ratio, Reduction/Enlargement (25% - 400%), Standard Copy, Two Sided Copy
Scanner
Scanner Type
Flatbed & ADF (Auto Document Feeder)
Scanning Element
Contact Image Sensor (CIS)
Max. Resolutions
Optical:Flatbed: 600 x 1200 dpi (Optical)14
ADF: 600 x 600 dpi (Optical)14
Scanner Features
Auto Document Feeder (ADF), Auto Scan Mode13, Document Removal Reminder, Save to PC, Scan to Canon PRINT App3, Multi-Page PDF, Wireless Scanning1
Color Depth
16-bit Internal (Per RGB Channel)
8-bit External (Per RGB Channel)
Max. Document Size
Flatbed: 8.5" x 11.7" (Letter/A4)
ADF: 8.5" x 14.0" (Legal)
Fax
Modem Speed
Up to 33.6 Kbps (Super G3 Color Fax)15
Transmission Speed (approx.)
Black: Approx. 3 Seconds per Page16
Color: Approx. 60 Seconds (1 Minute) per Page16
Memory Capacity
Approx. 50 Pages15
Group Dialing
19 Locations
Fax Features
Answering Machine Connectivity, Caller Rejection, Check RX Fax Info., Dial Search, Double Sided Printing (Fax Images), Extra Fine Mode, Fax Reception Reject, Fax Number Re-Entry, Memory Transmission, Redial, Remote Reception
General
Other Features
Full Dot Matrix LCD, Auto Power On/Off, Canon PRINT app3, Document Removal Reminder, ENERGY STAR® Certified, FINE (Full-photolithography Inkjet Nozzle Engineering) Cartridge, Hybrid Ink System, PIXMA Cloud Link3, Quiet Mode,Wireless Connect6
OS Compatibility
Windows:20 Windows® 10, Windows 8.1, Windows 7 SP1
Mac:21 Mac OS® X v10.10.5 - macOS v10.13 (High Sierra)
Mobile Operating Systems:22 iOS®, Android™, Windows 10 Mobile, and Fire OS (Amazon Fire) devices23
Standard Interface
Hi-Speed USB
Wi-Fi® (802.11b/g/n wireless networking, 2.4 GHz)1
Software Included
(WINDOWS20/MAC21)
PIXMA TR4520 Wireless Office All-In-One Printer Driver
Scan Utility (Win/Mac) / Scan Utility Lite (Mac Only)
Easy-PhotoPrint Editor Software8
Master Setup
My Printer (Windows Only)
Quick Menu
Master Setup
Quick Menu
Dimension (W x D x H)
(Closed) 17.2" (W) x 11.7" (D) x 7.5" (H)
17.2" (W) x 16.2" (D) x 7.5" (H)
Weight
13.0 lbs.
Warranty
1-Year Limited Warranty with InstantExchange Program.24
SMART ASSISTANT & AUTOMATION SUPPORT
Amazon Alexaâ„¢ (Native Support)19
Reviews
Product Disclaimer
- Wireless printing and scanning requires a working network with wireless 82.11b/g/n capability, operating at 2.4GHz. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
- AirPrint functionality requires a compatible iPad, iPhone, or iPod Touch device running iOS 7. or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported.
- Requires an Internet connection and the Canon PRINT Inkjet/SELPHY app, available for free on the App Store and at Google Play. Compatible with iPad, iPhone 3GS or later, and iPod touch 3rd generation or later devices running iOS 7. or later, and Android mobile devices running Android 2.3.3 or later. Your device must be connected to the same working network with wireless 82.11 b/g/n/ac/ad capability as your printer. Requires a compatible social media account and is subject to that social media accounts Terms of Service. Certain exceptions may apply.
- Paper types NOT supported for borderless printing are as follows: Envelope, High Resolution Paper, T-Shirt Transfer and Photo Stickers. The maximum borderless printing size is 8.5x11.
- Requires Android mobile device with Android 4.4 operating system or later with the Mopria Print Service pre-loaded with that device and the compatible PIXMA printer on the same wireless network. The Mopria experience is also available on Android 4.4 mobile devices with a download of the Mopria Print Service from Google Play.
- Requires a smart device with the Canon PRINT Inkjet/SELPHY app installed and connected to the desired active wireless network to complete cableless setup.
- Requires an active IFTTT account, the printer to be actively connected with permission to the Canon Inkjet Cloud Printing Center, and an IFTTT ?applet installed/enabled and required active account/service linked to the printer.
- The Easy-PhotoPrint Editor software requires an Internet connection and is compatible with the following operating systems; Microsoft Windows 1 (64-bit/32-bit), Microsoft Windows 8.1 (64-bit/32-bit),Microsoft Windows 7 SP1 (64-bit/32-bit), macOS High Sierra v1.13, macOS Sierra v1.12, Mac OS X El Capitan v1.11 and Mac OS X El Capitan v1.1.5. Minimum Windows and macOS/Mac OS X requirements are: 2GB of RAM and a monitor with 124x768 resolution. The Easy-PhotoPrint Editor mobile application requires an Internet connection and the Easy-PhotoPrint Editor app v1.1., available for free on the App Store and at Google Play. Compatible with iPad Air2 (2nd Generation), iPad Mini 4 and iPhone 6s or later devices running iOS 1 or later, and Android mobile devices running Android 5.x or later. Certain exceptions may apply. The following file formats are supported: JPEG, PNG, HEIF (devices running iOS 11 and mac OS v1.13 or later), DLP save data, Poster Artist export data, EasyPhoto+ export data, Easy-PhotoPrint Editor export data.
- Requires an Internet connection and Google account. Subject to Google Terms of Service. Certain exceptions may apply.
- Requires an Internet connection and the Message In Print app (Version 1.1), available for free on the App Store and at Google Play. Compatible with iPad and iPhone 6 or later devices running iOS 1 or later, and Android mobile devices running Android 5.1 or later. Your device must be connected to the same working network with wireless 82.11 b/g/n/ac/ad capability as your printer. Requires original content to be created using the Message In Print app/service, then printed on a compatible Canon Printer released in August 29 or later and delivered to recipient, who views image and content through the compatible Message In Print app on their compatible device. Compatible paper sizes include 3.5x x3.5, 4 x 4 Square, 4 x 6 and 5 x 5 Square only, and compatible media types include Genuine Canon Photo Paper Glossy, Photo Paper Semi-Gloss, Photo Paper Luster and Photo Paper Matte only. Certain exceptions may apply.
- Document print speeds are the averages of ESAT in Office Category Test for the default simplex mode, ISO/IEC 24734. Photo print speed is based on the default setting using ISO/JIS-SCID N2 on Photo Paper Plus Glossy II and does not take into account data processing time on host computer. Print speed may vary depending on system configuration, interface, software, document complexity, print mode, page coverage, type of paper used etc. Copy speeds are the average of sFCOT and sESAT, ISO/IEC 29183. Copy speed may vary depending on document complexity, copy mode, page coverage, type of paper used etc. and does not take into account warming up time. See www.usa.canon.com/ipm for additional details.
- Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/48 inch at minimum.
- Auto Scan Mode is only available when scanning using a computer using the IJ Scan Utility or IJ Scan Utility Lite software.
- Optical resolution is a measure of maximum hardware sampling resolution, based on ISO 14473 standard.
- The Public Switched Telephone Network currently supports fax modem speeds of 28.8 Kbps or lower, depending on telephone line conditions. Sending and receiving fax machines need to conform to ITU-T v.34guidelines.
- Black & white document fax transmission speed is based on default setting using ITU-T No.1 chart. Color document fax transmission speed is based on default setting using Canon Color Fax Test Sheet. Actual speed varies depending on document complexity, fax setting at receiving end, and line conditions etc.
- Page count is based on ITU-T No.1 chart or Canon FAX Standard Chart No.1. The number of pages able to be kept in memory will vary based on remaining memory capacity and document complexity.
- Requires an active smart assistant account linked and accompanying app enabled, the smart device and printer to be actively connected with permission to the Canon Inkjet Cloud Printing Center, and the required action(s), skill(s), or applet(s) available/enabled to the compatible printer. Voice commands can not be displayed as text on Amazon smart devices with screens.
- Operation can only be guaranteed on a PC with pre-installed Windows 1, Windows 8.1, Windows 7 SP1.
- Internet Connection required during software installation. For full compatibility macOS v1.12.1 or later is recommended.
- Some functions may not be available with these Operating Systems. Please refer to the manual or website for details.
- Requires Canon Print Plug-in available for free from the Amazon Appstore and an Amazon Fire Phone, Amazon Kindle Fire HD6 or HDX7 device or later running Fire OS 4. or later.
- Warranty programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details.
- Product box dimensions measured in vertical box configuration.
