PIXMA TS202
TS202
As low as $53.99
4 interest free payments of $13.50 with
klarna Pay Later
Paypal Pay Later
Out Of Stock
  • Wired Single Function (Print Only)
    • 7.7 / 4 ipm Print Speed
    • 60 Sheet Capacity
    • USB Connect Only
    • ENERGY STAR®
    • 1 Year Warranty
Show more
Overview
SIMPLE, AFFORDABLE PRINTING
Meet the Canon PIXMA TS202 - your simple printing solution. With a Rear Paper Tray and a Fine Hybrid Ink System, the PIXMA TS202 is a great, compact printing solution for all your documents. The PIXMA TS202 is also compatible with XL ink cartridges - which can help save you money, print more when you need to, and extend the time between replacing ink cartridges.
  • Quickly refill paper with the dedicated REAR PAPER TRAY.
  • FINE HYBRID INK SYSTEM for detailed documents and photos.
  • With AUTO POWER ON/OFF your printer will turn on when you need it and off when you don't!
  • Use QUIET MODE to reduce printer noise when you are worried about disturbing others.
  • Print quickly and easily with HIGH SPEED USB.
  • Print 4"x6" BORDERLESS PHOTOS with ease.Footnote1
  • With a great COMPACT SIZE, the PIXMA TS202 fits almost anywhere.
  • The PIXMA TS202 is an ENERGY STAR® certified printer.
Compatible Inks
Main Unit Spec
Printer
Print Speed (up to)
4" x 6" Photo: Approx. 70 seconds (Borderless) Footnote2
Black:ESAT: Approx. 7.7 ipm Footnote2
Color:ESAT: Approx. 4.0 ipm Footnote2
Number of Nozzles
Color: 960 / Pigment Black: 320 / Total: 1,280
Print Resolution (Up to)
Up to 4800 x 1200 dpi Footnote3
Ink Compatibility
Ink Type
PG-245/PG-243 Pigment Black Ink
CL-246/CL-244 Dye Based Inks
Ink Tank & Fill Volume
PGI-246 Black: 8.9 ml (Std.) , 12.0 ml (XL)
CLI-246 Color : 9.0 ml (Std.) , 13.0 ml (XL)
PGI-243 Black: 5.6 ml (Std.)
CLI-244 Color 6.2 ml (Std.)
Shop Compatible Ink
Paper Sizes
4" x 6"
5" x 7"
Letter
Paper Compatibility
Plain: Plain Paper
Printer Features
Borderless Printing (Up to 4"x6") Footnote1 , Document Printing, Photo Printing, Single Sided Printing
Output Tray Capacity
Rear Paper Tray: 60 Sheets of Plain Paper OR 20 Sheets of 4" x 6" / 10 Sheets of 5" x 7" Photo Paper
General
Other Features
Auto Power On/Off, FINE (Full-photolithography Inkjet Nozzle Engineering) Hybrid Ink System, ENERGY STAR® Certified, Quiet Mode
OS Compatibility
Windows: Footnote4 Windows ® 10, Windows 8.1, Windows 7 SP1
Mac: Footnote5 Mac OS ® X v10.10.5 - macOS v10.12 (Sierra)
Standard Interface
Hi-Speed USB
Software Included
(WINDOWS/MAC)
PIXMA TS202 Inkjet Printer Driver
Master Setup
My Printer (Windows Only)
Network Tool
Dimension (W x D x H)
16.8" (L) x 8.5" (W) x 4.9" (H)
Weight
6.4 lbs.
Warranty
1-Year limited warranty with InstantExchange Program. 1-Year toll-free technical phone support. Footnote8
Reviews
PIXMA TS202 Compatible Products
Ink
Ink
Product Disclaimer
  1. Paper types NOT supported for borderless printing are as follows: Envelope, High Resolution Paper, T-Shirt Transfer and Photo Stickers. The maximum borderless printing size is 4"x6".
  2. Document print speeds are the averages of ESAT in Office Category Test for the default simplex mode, ISO/IEC 24734. Photo print speed is based on the default setting using ISO/JIS-SCID N2 on Photo Paper Plus Glossy II and does not take into account data processing time on host computer. Print speed may vary depending on system configuration, interface, software, document complexity, print mode, page coverage, type of paper used etc.
  3. Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
  4. Operation can only be guaranteed on a PC with pre-installed Windows 10, Windows 8.1, Windows 7 SP1.
  5. Internet Connection required during software installation. For full compatibility macOS v10.12.1 or later is recommended.
  6. To install using Windows® OS, .NET Framework 4 is required. Compatible still image formats are PDF (created using Canon PDF Creator only), JPEG (Exif), TIFF, and PNG. Compatible video formats are MOV (from select Canon digital cameras only) and MP4 (from select Canon digital camcorders only).
  7. "Full HD Movie Print" is available from "MOV" and "MP4" movie files created by select Canon EOS Digital SLRs, PowerShot, and VIXIA digital cameras and camcorders. Requires PC or Mac with Intel® processor and Canon ZoomBrowser EX 6.5 or later or Canon ImageBrowser 6.5 or later for "MOV" files, or Canon ImageBrowser EX 1.0 or later for "MOV" or "MP4" files. Print quality is determined by the video resolution. Function does not upscale video resolution.
  8. Warranty programs are subject to certain conditions and restrictions. See https://www.usa.canon.com/support for details.
  9. Product box dimensions measured in vertical box configuration.
