PlotWave 7500 Series
PW 7500 PRIN
As low as
$0.00
Out Of Stock
- Mid-to-high demand technical document printing, scanning & copying system.
- Embedded Set of Security Features
- POWERsync controller running Windows® 10 LTSC IoT Enterprise
- Instant Productivity with Radiant Fusing technology
- Eco-design – low energy usage, noise level, and ozone emission
Need to order more than 10?
Learn More
Need help making a purchase? Contact a Sales Expert at 800-385-2155>
Return Policy
STANDARD SYSTEM CONFIGURATION
4-roll printing system (standard)
Productive large format monochrome printer with ClearConnect multitouch user panel.
Stacking systems (standard)
Integrated Top Delivery Tray. Up to 100 sheets E-size/A0.
Rotatable ClearConnect multitouch user interface
Consistent look and feel from every angle of your workflow, standard, including Smart Inbox,
SmartAccess, and Live Preview.
Roll media switching
Fully automated roll media switch to guide the media to the Top Delivery Tray or back output depending on the user application.
Drivers: Driver Select for Microsoft Windows, Driver Express PostScript 3 driver.
ClearConnect workflow software
Publishers: Publisher Mobile for iOS and Android, Publisher Express, Publisher Select 3 for
Microsoft Windows.
Starter kit included
1 bottle toner 500 g, 1 bottle developer 1,750 g, 1 roll 36" 20 lb. bond paper (75 g/m2).
Earthquake provision1
Help secure the printer against moving or tilting during an earthquake. This provision enables the user to
secure the printer to a sturdy connection of the building.
OPTIONAL SYSTEM CONFIGURATIONS
Office space saving scanning system
Scanner Express with Image Logic technology, integrated scanner positioned on top of the printer
to save office space.
Cutsheet tray
Capacity: 250 pages; Sizes: A/A4 size-C/A2 size
Operator attention light
Provides feedback on printer status from a distance
Stacking systems
Stacker Select, 400-sheet capacity
Roll media capacity upgrade
Add roll media capacity from 4- to 6-roll system
Removable hard disk
For secure environments, hard disk can easily be removed from the printer system to help secure
data integrity.
TECHNOLOGY
Imaging technology
Electrophotography (LED) with Organic photoconductor (OPC).
Radiant Fusing Technology with instant warm-up.
Clean toner refill system.
Virtually no ozone emission.
Fusing technology
Instant warm-up, contactless fusing, low power consumption (heating on-demand).
Toner/type
Black toner: 1,000 grams per toner kit (500 grams/ bottle).
PRODUCTIVITY
Speed (print and copy)
10-D/A1-sizes2 per minute 5-E/A0 sizes3 per minute
First print out time4
<40 seconds
First copy out time5
<40 seconds
More Info.
1 Excluding cable/chain and mounting material.
2 D-size (34" x 22") / A1 size (841 x 594 mm).
3 E-size (36" x 48") / A0 size (841 x 1189 mm).
4 One A1 landscape print made from the smart inbox, on 64 g media, back output, lines, and text mode.
5 One copy made with A1 original in landscape on 64 g media, back output, background compensation off, custom width 841 mm, custom length 594 mm.
QUALITY
Print resolution
600 x 1200 dpi
Minimum line width (ISO/IEC 13660:2001E)
0.00236" (0.06 mm)
1:1 Line accuracy
< 0.3%
SIZE AND WEIGHT
Size main engine (WxDxH)
61.6" x 31.7" x 66.8" (1,563 x 803 x 1,695 mm) (Height of 66.8" includes Top Delivery Tray)
Shipping dimensions (WxDxH)
58" x 34" x 50" (1,470 x 850 x 1,280 mm)
Weight main engine
631 lb. (286 kg)
Shipping weight main engine
739 lb. (335 kg)
MEDIA HANDLING
Media capacity
4 or 6 rolls; manual feed of cutsheet media. Cutsheet tray.
Paper cutting
Cutter included in the drawer for fast and easy roll media switching.
Maximum media capacity
6 rolls (650' L x 36" W): 11,700 sq. ft. If 4 rolls: 7,800 sq. ft.
Media sizes roll
ARCH: B, C, D, E, E1, 30", 21", 15"
ANSI: B, C, D, E
ISO: A3, A2, A1, A0, B1, B2, B1_700, B2_700
ANSI: B, C, D, E
Media sizes Cutsheet tray
Short-edge feed (portrait): A3, B4, A, B, A+, B+, Carto B4, 230 x 310 mm, 310 x 440 mm
Long-edge feed (landscape): A3, A2, B4, B3, B, C, B+, C+, Carto B4, Carto B3, 15" x 21", 310 x 440 mm, 440 x 594 mm
Media weight
Bond: 16-28 lb. (60-110g/m2). Film: 3.5 mil.
Roll length
Up to 650' (200 m)
Roll width
11"-36" (11",12",15",17",18",21",22",24",30",34",36") (279-914mm)
Minimum printed length
11" (279 mm)
Maximum printed length
577' (176 m)
Roll media type
Paper: Engineering Bond, Vellum, Recycled Bond, Tinted Bond Xtreme #27 Bond
Film: Polyester 3.5 mil
Cutsheet media type
Paper: Engineering Bond, Recycled Bond, Tinted Bond Xtreme #27 Bond
Automatic width detection.
Automatic roll media handling
Automatic roll media selection for optimized productivity and media saving, based on drawing
size, media type, roll width, and finishing.
Automatic roll switching when end of roll is reached.
USER INTERFACE
Description
Size (WxDxH)
11.8" x 8.7" x 1.6" (300 x 220 x 40 mm), 10.4" (diag.) color LCD
Resolution
800 x 600 pixels (SVGA)
Technology
Projective capacitive touch
Operation
3 hard buttons: [Wake-up], [Stop, interrupt, abort], [Home]
Multitouch functions: tap, double tap, pinch, 2-finger pinch, swipe, flick, and spread.
Interface design
Distinctive user interface with intuitive navigation and clearly defined levels of operation.
View optimization: Tilt ClearConnect (-4 to +45 degrees) and swivel (-45 to +180 degrees).
Features
Status light (red, orange, green).
USB 2.0 interface with indication light.
Switch instantly between 2 languages, select from 21 languages.
CONTROLLER
Description
High performance POWERsync controller with Windows 10 LTSC IoT Enterprise, 64-bit
Processor
Dual Core, Dual Thread Celeron® G4900 at 3.10GHz
Memory
4 GB DDR4
Video
Intel HD Graphics, 1GHz
Hard disk
500 GB, 7200 rpm (standard)
TPM
TPM2.0
Client operating system support
Windows 7 / Windows 7 64 bits / Windows 8.1 / Windows 8.1 64 bits / Windows 10 / Windows 10 64
bits / Windows Server 2008 R2 64 bits / Windows Server 2012 64 bits / Windows Server 2012 R2 64 bits/Mac OS
10.10 / Mac OS 10.11 / Mac OS 10.12 (PostScript 3 driver support only for Mac OS)
Interface
2 x Ethernet 100 Mbits/s, 1Gbit/s
TCP/IP: DHCP, IPv4, IPv6, HTTPS
Discovery: APIPA, WS-Discovery, SNMPv3
Page description language
TIFF, JPEG, HPGL, HPGL2, DWF, C4, Calcomp 906/907/951, CALS, NIRS, NIFF, PS/PDF (optional)
Printing protocol
LPR, FTP, WebDav, WSD print
FTP
Pull from SMB, FTP
Pull from cloud (retrieve from WebDAV-based clouds)
HTTP/HTTPS (used by Publisher Express)
Print from home folder via access management
FTP
Pull from SMB, FTP
Backchannel protocol
SNMPv3, Wave interface, WS-Discovery
SECURITY
New Set of Security Features
E-shredding, IPSec, IP filtering/Access Control Lists, HTTPS, SNMPv3, audit logging, AES256 Disk
Encryption,
802.1x Authentication, network protocol enable/disable, LDAP integration, Active Directory Integration,
User authentication on local ClearConnect user panel and via Express WebTools (LDAP/ Active Directory
credentials, smart card) for scan/copy/print. Configure HTTPS Certificates. Allow disabling TLS1.0 and
1.1 protocols (no response to network scan) and enable TLS 1.2 with stronger cipher. Embedded FIPS 140-2
Certified Trusted Platform Module (TPM) and BitLocker 256 AES hard disk encryption, hard disk wipe,
Configurable CA certificate, Disable Network Ports and Protocols, Security Event Logging, Single
Sign-on. Options: Removable hard disk, McAfee antivirus, McAfee Application control (whitelisting).
Access management
Provide help secure access to device by users keying in password on the ClearConnect multitouch
operator panel or get access with a Smart Card by connecting a card reader (including contactless).
Authorization is managed by using Active Directory.
Cloud support
Unlimited user and/or Administrator authenticated cloud support via WebDAV and/or third party
provider: e.g. Microsoft SharePoint, Dropbox, Box.com, box.net, Google Drive, Microsoft OneDrive, Amazon
Cloud Drive, Cloudsafe, MyDisk. The cloud user authentication can either be preconfigured by the
administrator or done by the user at the time of accessing the specific cloud.
Transformations
Scaling (scale-to-fit page, reduce when image too large to avoid clipping or to custom factor,
scale page size to standard size), Rotation, Shift (automatic or user defined), Adding/removing
trailing/leading edge, Mirror, Black intensity in poster mode, Print optimization (standard, lines/text,
poster). Color Highlight and Dark Original. Area to erase (area of interest).
SCANNER EXPRESS (optional)
Description
Integrated Contact Image Sensor (CIS) Color scanner with Image Logic technology
Scan resolution
600 x 600 dpi (Selectable 100, 200, 300, 400, 600 dpi)
Scan speed
Up to 49.8 ft./min. (15.2 m/min.) Black-and-white scanning
Up to 33.1 ft./min. (10.1 m/min.) Copying
Up to 16.4 ft./min. (5.0 m/min.) Color scanning
Scan formats
TIFF, PDF, PDF/A, JPEG, CALS, multipage PDF, multipage PDF/A, and multipage TIFF
Scan templates
Extensive number of scan templates to standardize common scan settings and destinations
Scan protocol
FTP, SMB, scan to cloud (push to WebDAV-based clouds)
Scan destination
Local USB flash drive, FTP, SMB, Smart Inbox on Controller, Optional Local Home folder (LDAP),
mobile device via Mobile WebTools, WebDAV clouds
Scan naming
Preset naming with auto numbering for productive scanning or file name on the ClearConnect user
panel
Original width
8.2"-36" (208-914 mm), automatic width detection
Original length
8.2"-52.5" (208 mm-16 m), auto length detection
Original thickness
Maximum 0.03" (0.8 mm) nonrigid documents
Zoom (copy)
1:1, Scale to media size, Scale to standard format. Custom: 10-1,000%
Original type presets
Lines & Text standard, Folded Lines & Text, Lines & Text draft, Dark Original,
Colored Original, Photo, Blueprint, Map, Artwork
Scanner size (WxDxH)
43" x 12" x 5.5" (1,097 x 308 x 140 mm)
Scanner weight
55 lb. (25 kg)
ENVIRONMENTAL
Acoustic sound power
Standby and sleep: less than 26 dB; Print mode: less than 52 dB
Ozone concentration
< 0.005 mg/m3 , <0.002365 PPM (0.25% of permitted limit value)
Heat emission
Ready: 66 W; Active: 1.7 kW
Power requirements
100-240 V; 50/60Hz
Power consumption
Sleep mode: <2 W
Ready mode: 66 W
Active mode: 1.7 kW
Ready mode: 66 W
Active mode: 1.7 kW
Safety/EMC marks and environmental labels
CE, TUV GS, CETECOM, ENERGY STAR 3.0, FEMP, Rohs, CCC, VCCI TÜV GS, c-UL-US, CB, RCM,
EPEAT, EAC, FCC Class A, VCCI Class A
Recyclables
Printer: made of steel or highly recyclable plastics: up to 95% of the engine can either be
upcycled or recycled. Remaining 5% are nontoxic waste.
Prints: very good deinkability when recycled.
Toner: bottles made of highly recyclable HDPE (High Density Polyethylene).
CLEARCONNECT WORKFLOW SOFTWARE
Job submission
The ClearConnect software suite consists of a variety of applications with the same user
interface. Create,
retrieve, and/or send jobs from drivers (Driver select for Microsoft Windows, Driver Express for Adobe
PostScript 3 for Microsoft Windows or Apple OS), external locations (SMB, FTP, LPR, WebDAV), Mobile
devices via Express WebTools and Publisher Mobile, USB flash drive, Cloud services, and optional Home
folder(LDAP).
1-click printing from USB, 1-click printing from previous sent jobs via Print SmartAccess on ClearConnect user panel. The Smart Inbox on the ClearConnect user panel enables the job preview: swipe between your jobs for print selection and preview. Pan to view the image in detail (zoom).
With the template-oriented Publisher Select 3 submitting multiple files in batches is supported. Print multiple times and sort by page or set. Media saving automatically rotates print files to optimize media usage.
Smart inbox
Personalized Smart Inbox: History, Manage Queue, Manage History, Express WebTools, Secured
Controller Access
Queue management
Spool memory provides a queuing system for print and copy jobs. This enables multiple users to
send print and copy jobs at the same time. Customize priority settings for copy and print jobs in the queue.
The Job Queue overview gives access to job names, owners, and status including required media. Jobs can be
paused, deleted, and placed on top of the queue.
Print management and accounting
View the counter history at preferred time periods, per job or total overview in Express
WebTools. View, create, edit, and delete stamp templates.
Optional uniFLOW support, log in with your personal uniFLOW Queue on the ClearConnect User interface. Supports manual authentication, card readers, and contactless card readers.
Device management
Express WebTools provide administrators the tools to manage the device remotely via the web:
e.g. check printer status; define default settings for print, copy, and scan; define access; security;
accounting; remote shutdown; software update and restart; power on/off timer; system behavior; queue
management; license management; view, create, edit, and delete stamp templates; etc.
Scan to color inkjet
Scan directly to iPF 600/700/800/TX- 2000/3000/4000/5200/5300/5400 series via Publisher Select 3
(hotfolder)
STACKER SELECT
Description
Integrated productive stacker with high capacity and tray full sensor
Capacity
400 pages
