plotWAVE T30/T35
As low as $0.00
Out Of Stock
  • Low-to-mid demand technical document printing, scanning & copying system
  • Embedded Set of Security Features
  • POWERsync+ controller running Windows® 10 IoT LTSC 2021
  • Instant Productivity with Radiant Fusing technology
  • EPEAT® Silver and Energy Star® Registered
Show more
The Scanner Express R:
Precision, Reliability, and Speed with Advanced Editing Capabilities.
Click here to learn more!
STANDARD SYSTEM CONFIGURATION
1-roll (standard) or 2-roll printing system
Productive large format monochrome printer with ClearConnect multitouch user panel.
Stacking system
Integrated Top Delivery Tray. Up to 100 sheets E-size/A0.
Tilt and Swivel ClearConnect multitouch user interface
Consistent look and feel from every angle of your workflow, standard, including Smart Inbox, SmartAccess, and Live Preview.
Roll media switching
Fully automated roll media switch to guide the media to the Top Delivery Tray or back output depending on the user application.
ClearConnect workflow software
Drivers: Driver Select for Microsoft Windows, Driver Express PostScript 3 driver.
Publishers: Publisher Mobile for IOS and Android, Publisher Express, PRISMA Tech Suite.
Starter kit included
1 bottle toner 500 g, 1 bottle developer 1750 g, 1 roll 36 inch 20 lb. bond paper (75 g/m2).
Earthquake provision1
Help secure the printer against moving or tilting during an earthquake. This provision enables the user to secure the printer to a sturdy connection of the building.
OPTIONAL SYSTEM CONFIGURATIONS
Office space saving scanning system
Scanner Express with Image Logic technology, integrated scanner positioned on top of the printer to save office space.
Stacking systems
Stacker Select, 400-sheet capacity
Roll media capacity upgrade
2-roll option doubles media capacity from 1,950 to 3,900 sq. ft. (182 to 365 m2).
Removable hard disk
For secure environments, hard disk can easily be removed from the printer system to help secure data integrity.
TECHNOLOGY
Imaging technology
Electrophotography (LED) with Organic photoconductor (OPC).
Radiant Fusing Technology with instant warm-up. Clean toner refill system.
Virtually no ozone emission.
Fusing technology
Instant warm-up, contactless fusing, low power consumption (heating on-demand).
Toner/type
Black toner: 1,000 g per toner kit (500 g per toner bottle).
PRODUCTIVITY
Speed (print and copy)
plotWAVE T30: 4-D/A1-sizes2 per minute 2-E/A0 sizes3 per minute
plotWAVE T35: 6-D/A1-sizes2 per minute 3-E/A0 sizes3 per minute
First print out time4
<40 seconds
First copy out time5
<40 seconds
1 Excluding cable/chain and mounting material.
2 D-size (34"" x 22"") / A1 size (841 x 594 mm).
3 E-size (36"" x 48"") / A0 Size (841 x 1189 mm).
4 One A1 landscape print made from the smart inbox, on 64 g media, back output, lines, and text mode.
5 One copy made with A1 original in landscape on 64 g media, back output, background compensation off, custom width 841 mm, custom length 594 mm.
QUALITY
Print resolution
600 x 1200 dpi
Minimum line width (ISO/IEC 13660:2001E)
0.00236" (0.06 mm)
1:1 Line accuracy
< 0.3%
SIZE AND WEIGHT
Size main engine (WxDxH)
61.6" x 31.7" x 59.2" (1563 mm x 803 mm x 1503 mm) (Height of 59.2" includes Top Delivery Tray)
Shipping dimensions (WxDxH)
58 " x 34 " x 50 " (1470 x 850 x 1280 mm)
Weight main engine
485 lb. (220 kg)
Shipping weight main engine
597 lb. (271 kg)
MEDIA HANDLING
Media capacity
1 or 2 rolls; manual feed of cutsheet media
Paper cutting
Cutter included in the drawer for fast and easy roll media switching.
Maximum media capacity
1 roll (650' L x 36" W): 1,950 sq. ft. If 2 rolls: 3,900 sq. ft.
Media sizes roll
ARCH: B, C, D, E, E1, 30"", 21"", 15"" ANSI: B, C, D, E
ISO: A3, A2, A1, A0, B1, B2, B1_700, B2_700
Media sizes Cutsheet tray
Short-edge feed (portrait): A3, B4, A, B, A+, B+, Carto B4, 230 x 310 mm, 310 x 440 mm
Long-edge feed (landscape): A3, A2, B4, B3, B, C, B+, C+, Carto B4, Carto B3, 15"" x 21"", 310 x 440 mm, 440 x 594 mm
Media weight
Bond: 16-28 lb.(60-110g/m2). Film: 3.5 mil.
Roll length
Up to 650' (200 m)
Roll width
11"-36"
(11",12",15",17",18",21",22",24",30",34",36")
(279-914mm)
Minimum printed length
16.5" (420 mm)
Maximum printed length
650' (200 m)
Roll media type
Paper: Engineering Bond, Vellum, Recycled Bond, Tinted Bond Xtreme #27 Bond Film: Polyester 3.5 mil
Cutsheet media type
Paper: Engineering Bond, Recycled Bond, Tinted Bond Xtreme #27 Bond
Automatic roll media handling
Automatic width detection Automatic roll media selection for optimized productivity and media saving, based on drawing size, media type, roll width, and finishing.
Automatic roll switching when end of roll is reached.
USER INTERFACE
Description
Size (WxDxH)
11.8" x 8.7" x 1.6" (300 x 220 x 40 mm), 10.4" (diag.) color LCD
Resolution
800 x 600 pixels (SVGA)
Technology
Projective capacitive touch
Operation
3 hard buttons: [Wake-up], [Stop, interrupt, abort], [Home] Multitouch functions: tap, double tap, pinch, 2-finger pinch, swipe, flick, and spread.
Interface design
Distinctive user interface with intuitive navigation and clearly defined levels of operation.
Features
View optimization: Tilt ClearConnect (-4 to +45 degrees) and swivel (-45 to +180 degrees). Status light (red, orange, green). USB 2.0 interface with indication light. Switch instantly between 2 languages, select from 21 languages.
CONTROLLER
Description
High performance POWERsync+ controller with Windows® 10 iOT LTSC21
Processor
Dual Core, Dual Thread Celeron® G4900 at 3.10GHz
Memory
2 8 GB DDR4, for a total of 16 GB of memory
Video
Intel UHD Graphics 630, 1,1GHz
Hard disk
500 GB, 7200 rpm (standard)
TPM
TPM2.0
Client operating system support
Windows 7 / Windows 7 64 bits / Windows 8.1 / Windows 8.1 64 bits / Windows 10 / Windows 10 64 bits / Windows 11 / Windows Server 2008 R2 64 bits / Windows Server 2012 64 bits / Windows Server 2012 R2 64 bits/Mac OS 10.10 / Mac OS 10.11 / Mac OS 10.12 (PostScript 3 driver support only for Mac OS )
Interface
2x Ethernet 100 Mbits/s, 1Gbit/s TCP/IP: DHCP, IPv4, IPv6, HTTPS Discovery: APIPA, WS-Discovery, SNMPv3
Page description language
TIFF, JPEG, HPGL, HPGL2, DWF, C4, Calcomp 906/907/951, CALS, NIRS, NIFF, PS/PDF (optional)
Printing protocol
LPR, FTP, WebDav, WSD print FTP Pull from SMB, FTP
Pull from cloud (retrieve from WebDAV based clouds) HTTP/HTTPS (used by Publisher Express)
Print from home folder via optional access management
Backchannel protocol
SNMPv3, Wave interface, WS-Discovery
SECURITY
New Set of Security Features
E-shredding, IPSec, IP filtering/Access Control Lists, HTTPS, SNMPv3, audit logging, AES256 Disk Encryption, 802.1x Authentication, network protocol enable/disable, LDAP integration, Active Directory Integration, User authentication on local ClearConnect user panel and via Express WebTools (LDAP/Active Directory credentials, smart card) for scan/copy/print. Configure HTTPS Certificates. Allow disabling TLS1.0 and 1.1 protocols (no response to network scan) and enable TLS 1.2 with stronger cipher. Embedded FIPS 140-2 Certified Trusted Platform Module (TPM) and BitLocker 256 AES hard disk encryption, hard disk wipe, Configurable CA certificate, Disable Network Ports and Protocols, Security Event Logging, Single Sign-on. Options: Removable hard disk, McAfee antivirus, McAfee Application control (whitelisting).
Access management
Help provide secure access to device by users keying in password on the ClearConnect multitouch operator panel or get access with a Smart Card by connecting a card reader (including contactless). Authorization is managed by using Active Directory.
Cloud support
Unlimited user and/or Administrator authenticated cloud support via WebDAV and/or third-party provider: e.g. Microsoft SharePoint, Dropbox, Box.com, box.net, Google Drive, Microsoft OneDrive, Amazon Cloud Drive, Cloudsafe, MyDisk. The cloud user authentication can either be preconfigured by the administrator or done by the user at the time of accessing the specific cloud.
Transformations
Scaling (scale-to-fit page, reduce when image too large to avoid clipping or to custom factor, scale page size to standard size), Rotation, Shift (automatic or user defined), Adding/removing trailing/leading edge, Mirror, Black intensity in poster mode, Print optimization (standard, lines/text, poster). Color Highlight and Dark Original. Area to erase (area of interest).
Scanner Express IV or Scanner Express R (OPTIONAL)
Description
Integrated Contact Image Sensor (CIS) Color scanner with Image Logic technology
Scan resolution
600 x 600 dpi
Scan speed
Monochrome Scanning: Up to 10 inches/second
Copying: Up to 6 inches/second
Color Scanning: Up to 3 inches/second
Scan formats
TIFF, PDF, PDF/A, JPEG, CALS, multipage PDF, multipage PDF/A and multipage TIFF
Scan templates
Extensive number of scan templates to standardize common scan settings and destinations
Scan protocol
FTP, SMB, scan to cloud (push to WebDAV based clouds)
Scan destination
Local USB flash drive, FTP, SMB, Smart Inbox on Controller, Optional Local Home folder (LDAP), mobile device via Mobile WebTools, WebDAV Clouds.
Scan naming
Preset naming with auto numbering for productive scanning or file name on the ClearConnect user panel
Original width
8.2"-36" (208-914 mm), automatic width detection
Original length
8.2"-52.5" (208 mm-16 m), auto length detection
Original thickness
Maximum 0.03" (0.8 mm) non-rigid documents
Zoom (copy)
1:1, Scale to media size, Scale to standard format. Custom: 10-1,000%
Original type presets
Lines & Text standard, Folded Lines & Text, Lines & Text draft, Dark Original, Colored Original, Photo, Blueprint, Map, Artwork
Scanner size (WxDx H)
43" x 12" x 5.5" (1,097 x 308 x 140 mm)
Scanner weight
55 lb. (25 kg)
ENVIRONMENTAL
Acoustic sound power
Standby and sleep: less than 26 dB. Print mode: less than 52 dB
Ozone concentration
< 0.001 mg/m3, < 0.000473 PPM (0.05% of permitted limit value)
Heat emission
Ready: 66 W; Active: 1.5 kW
Power requirements
100-240 V; 50/60Hz
Power consumption
Sleep mode: <2 W Ready mode: 66 W Active mode: 1.7 kW
Safety/EMC marks and environmental labels
CE, TUV GS, CETECOM, Energy Star 3.0, FEMP, Rohs, CCC, VCCI TÜV GS, c-UL-US, CB, RCM, EAC, FCC Class A, VCCI Class A
Recyclables
Printer: made of steel or highly recyclable plastics: up to 95% of the engine can either be upcycled or recycled. Remaining 5% are nontoxic waste.
Prints: very good deinkability when recycled.
Toner: bottles made of highly recyclable HDPE (High Density Polyethylene)
CLEARCONNECT WORKFLOW SOFTWARE
Job submission
The ClearConnect software suite consists of a variety of applications with the same user interface. Create, retrieve, and/or send jobs from drivers (Driver select for Microsoft Windows, Driver Express for Adobe PostScript 3 for Microsoft Windows or Apple OS), external locations (SMB, FTP, LPR, WebDAV), Mobile devices via Express WebTools and Publisher Mobile, USB flash drive, Cloud services, and optional Home folder (LDAP).
1-click printing from USB, 1-click printing from previous sent jobs via Print SmartAccess on ClearConnect user panel. The Smart Inbox on the ClearConnect user panel enables the job preview: swipe between your jobs for print selection and preview. Pan to view the image in detail (zoom).
With the template-oriented Publisher Select 3 submitting multiple files in batches is supported. Print multiple times and sort by page or set. Media saving automatically rotates print files to optimize media usage.
Smart inbox
Personalized Smart Inbox: History, Manage Queue, Manage History, Express WebTools, Secured Controller Access
Queue management
Spool memory provides a queuing system for print and copy jobs. This enables multiple users to send print and copy jobs at the same time. Customize priority settings for copy and print jobs in the queue.
The Job Queue overview gives access to job names, owners, and status including required media. Jobs can be paused, deleted, and placed on top of the queue.
Print management and accounting
View the counter history at preferred time periods, per job or total overview in Express WebTools. View, create, edit, and delete stamp templates.
Optional uniFLOW support, log in with your personal uniFLOW Queue on the ClearConnect User interface. Supports manual authentication, card readers, and contactless card readers.
Device management
Express WebTools provide administrators the tools to manage the device remotely via the web: e.g. check printer status; define settings for print, copy, and scan; define access; security; accounting; remote shutdown; software update and restart; power on/off timer; system behavior; queue management; license management; view, create, edit, and delete stamp templates; etc.
Scan to color inkjet
Scan directly to select imagePROGRAF series models via Publisher Select 3 (hotfolder)
STACKER SELECT
Description
Integrated productive stacker with high capacity and tray full sensor
Capacity
400 pages
Resources
File Name
Canon plotWAVE T series brochure
Date
04.17.26
File Size
27.7 MB
File Name
Canon Scanner Express R
Date
08.27.26
File Size
0.5 MB
File Name
Canon plotWAVE T30 and 35 Series Spec Sheet
Date
04.17.26
File Size
1.5 MB
