Raman Plastic Analyzer TR-A100
- High-Speed Multi-Sample Analysis: Scans 100 samples in as little as 60 seconds to maximize inspection throughput.
- Reliable Black Plastic Identification: Accurately detects 12 plastic types regardless of pigments, including materials that evade traditional sensors.
- Easy 3-Step Workflow: Simple "Load, Capture, Analyze" process streamlines operations with minimal training required.
- Integrated Reporting: Export data directly to Excel for effortless analysis of material composition and contamination levels.
Overview
The TR-A100 is a high-speed plastic analyzer powered by advanced Raman spectroscopy, specifically engineered to address the "black plastic" hurdle. Historically, these materials have been difficult to identify, often evading traditional sorting processes due to their light-absorbing properties.
By fusing Canon’s high-precision optical technology with innovative laser control, the TR-A100 delivers reliable identification of black plastics with speed—scanning up to 100 samples in as little as 60 seconds. Designed for rigorous research and quality control, this system significantly reduces hands-on inspection time and manual effort for batch testing. The TR-A100 empowers teams to extract maximum value from previously overlooked materials, supporting a more resource-efficient and sustainable industrial pathway.
Features
Maximize inspection throughput with Canon’s advanced laser scanning technology. Analyze up to 100 samples in as little as 60 secondsFootnote2, significantly reducing manual handling and hands-on inspection time.
Accurately identify 12 common plastic types regardless of pigments. Thanks to Canon’s high-precision optical technology, the system excels at detecting black plastics that typically evade traditional sensors.
Identifiable Plastics: ABS, PP, PS, PE, PC, PCABS, PET, POM, PMMA, PA, PBT, PVC
Easy 3-Step Analysis
Load
Place samples on the tray
Capture
The system automatically takes a photo
Analyze
Click the start button to scan and display identification result
Streamlined Software & Reporting
Accelerate your workflow with integrated data aggregation and Microsoft Excel export. Rapidly analyze material composition ratios or contamination levels to generate quality reports effortlessly.
Dimensions
Unit: mm / inch
Front door open and sample tray extended
Please allow at least 100 mm /3.9” of clearance at the sides and rear for ventilation.
| Item | Specifications |
| Measurement Area | Approx. 400 mm × 300 mm / 15.7" x 11.8" |
| Sample Size | Size: 5 × 5 mm or larger / 0.2" x 0.2" or larger Thickness: 10 mm or less / 0.4" or less (based on Canon standard samples) |
| Identifiable Plastics | 12 types of plastics (including black plastics): ABS, PP, PS, PE, PC, PCABS, PET, POM, PMMA, PA, PBT, PVC |
| Identification Accuracy | Over 99% (based on Canon standard samples) |
| Measurement Time | Approx. 100 sec / 100 pcs (at 250 msec laser irradiation setting) Approx. 60 sec / 100 pcs (at 50 msec laser irradiation setting) |
| Laser Class | Class 1 |
| Operating Environment | Temperature: 25 ± 10°C / 77 ± 18℉ Humidity: 30 – 80% RH (no condensation) |
| Power Supply | Voltage: 100 – 240 V AC Power Consumption: 300 W (Rated) |
| Dimensions | 980 (W) × 790 (D) × 645 (H) mm / 38.6" (W) x 31.1" (D) x 25.4" (H) |
| Weight | 115 kg / 253.5 lb. |
Windows PC is required (Please contact us for specifications)
