Out Of Stock
REALiS 4K501ST Pro AV
4K501ST
As low as $33,299.00
Out Of Stock
  • Native 4K Resolution (4096 x 2400) Provides Immersive, Highly Detailed Images
  • Up to 5000 Lumens* and 3000:1 Contrast Ratio Delivers Bright, Engaging Images
  • Compact and Lightweight Design with 1.0-1.3:1 Shorter Throw Ratio for Application Flexibility
  • LCOS Technology with AISYS-enhancement Offers Seamless Images with Exceptional Color Reproduction
  • Specialized Genuine Canon Optics Provide Exceptional Image Quality with Minimal Image Distortion and Consistent Brightness Throughout the 1.3x Zoom Range
  • Dual Image Engines Execute Highly Complex Image Processing for Uncompressed 4K 60p Playback and Upscaling of Non-4K Content
Return Policy
Main Unit Spec
Projector Specifications
Imaging Device
0.76", LCOS Panel x3
Aspect Ratio
17:10 Approx. (128:75)
Native Resolution
4096 x 2400
Brightness
5000/3750 Lumens (*2)
Uniformity
88%
Contrast Ratio
3000:1 (Native)
Digital Keystone
V:±20°, H:±20°
Image Size
40 - 600"
Optics
F Number, Focal Length
F2.6, f=17.2 - 22.3mm
Zoom
1.3x
Focus
Powered
Throw Ratio
1.02:1 - 1.32:1
Image Adjustments
Image Modes
Standard / Presentation / Dynamic / Photo/sRGB / Video / DICOM SIM / User 1 / User 2 / User 3
Color Adjustment
Color Level, Color Balance, Color Temperature, Gain (R,G,B), Offset (R,G,B)
Screen Color Correction
Normal / Greenboard / Adjust (custom)
Mounting
Front, Rear, Ceiling, Upward, Downward
Lens Shift
V: ±60%, H: ±10%
Adjustable Feet
Four Locations at bottom. Extension length = .47"
Image Signals
Scanning Frequency
H: 18.000kHz - 149.096kHz, V: 23.956Hz - 60.000Hz
HDMI (Single)
640 x 480, 720 x 480, 720 x 576, 800 x 600, 1280 x 720, 1024 x 768, 1366 x 768, 1440 x 900, 1280 x 1024, 1920 x 1080, 2048 x 1080, 2560 x 1080, 1920 x 1200, 2048 x 1200, 2560 x 1440, 2560 x 1600, 3840 x 2160 , 4096 x 2160
HDMI (1 x 2)
1280 x 480, 1440 x 480, 1440 x 576, 2560 x 720, 3840 x 1080, 2560 x1600, 3540 x 2160, 4096 x 2160, 3200 x 2400(*5), 3840 x 2400(*4)(*5)
DVI (Single)
640 x 480, 800 x 600, 1280 x 720, 1024 x 768, 1366 x 768, 1440 x 900, 1280 x 1024, 1920 x 1080, 2048 x 1080, 2560 x 1080, 1920 x 1200, 2048 x 1200, 2560 x1440, 3840 x 2160(*3), 4096 x 2160(*3)(*4)
DVI (1 x 2)
2560 x 1080, 2560 x 1440, 2560 x 1600, 3840 x 2160(*3), 4096 x 2160(*3)
DVI (2 x 2)
3840 x 2160, 4096 x 2160, 4096 x 2304(*5), 3200 x 2400(*5), 3840 x 2400(*5), 4096 x 2400(*5)
DVI (1 x 4)
3840 x 2160, 4096 x 2160, 4096 x 2304(*5), 3840 x 2400(*5), 4096 x 2400(*5)
Dot Clock
594.00 MHz (Maximum) (*7)
Terminals
DVI-D
Digital PC Input (x4)
HDMI
Digital PC /Digital Video Input (x2)
Mini Jack
Audio Input (x1), Audio Output (x1)
Wired Remote Control Connection
Dsub9
RS-232C
USB Type A
USB Connection
RJ-45
Network Connection (1000BASE-T / 100BASE-TX / 10BASE-T)
Remote Control
Wireless Remote
Yes
Built-In Sound
Internal Amplifier
5W, Monaural
Lamp
Type
Super High Pressure Lamp
Life
3000 / 4000 Hours (*2)
Power
400 / 300W (*2)
Ratings
Fan Noise
39/34dB (*2)
Power Consumption
600/475W (*2)
Standby Power Consumption
0.8/0.4W (*3)
Heat Dissipation
Up to 2,048 BTU/h
Power Voltage
AC100 - 240V : 50/60 Hz
Operating Temperature
32°F - 104°F, 20%RH - 85%RH
Storage Temperature
-4°F - 140°F
Weight
39.6 lbs.
Dimensions (W x H x D)
W:18.5" x H:6.9" x D:21"
Notes
1* Calculated value for 70" image
2* Lamp mode is Full power/Power Saver. Brightness in Power saver mode is only a calculated value, and is not guaranteed as specification
3* Only low frequencies (24 - 30Hz) are supported
4* EDID is not supported
5* Supported when "Panel drive mode" is set to "4096 x 2400"
6* Network "ON" (Low-power) / "OFF"
7* Supported via single HDMI only
Product Disclaimer
*1 When in Presentation Mode and lamp is set to Full Power Mode.
*2 When motion blur reduction is activated, brightness will be affected.
*3 When standing the projector straight up or down, lamp life may be shortened.
*4 The REALiS 4K501ST includes a DICOM Simulation Mode. It has not been cleared or approved for medical diagnosis and should not be used for these purposes.
*5 Y (6G): Signal processed with HDMI 2.0. Requires an IC that supports HDMI 2.0 6G.
*6 Not all supported resolutions are shown. Please refer to the manual for a complete list of supported resolutions.
*7 Programs and service offerings subject to change without notice. For complete details, including terms and conditions for each program, or to learn more about Service and Support offerings for Canon professional projectors, please contact a Canon sales rep or call 1-800-OK-CANON.
