Refurbished EF 24–105mm f/4L IS II USM
1380C010
As low as $1,304.00
Buy now and pay later with
klarna Pay Later
Paypal Pay Later
In Stock
  • All-new optical design with improvements in peripheral brightness.
  • High-performance standard zoom lens with constant f/4L aperture and a broad angle of view covering wide-angle to mid-telephoto.
  • Air Sphere Coating (ASC) helps to significantly reduce flare and ghosting.
  • Image Stabilizer performance at up to 4 stopsFootnote1 of shake correction helps capture sharp images.
  • Circular aperture (10 blades) helps deliver beautiful, soft backgrounds.
  • Fluorine coating on front and rear lens surfaces helps reduce smears and fingerprints.
Show more
View Full Technical Specs PDF
Main Unit Spec
Refurbished EF 24–105mm f/4L IS II USM Compatible Products
Cases, Bags & Straps
Product Disclaimer
  1. Based on CIPA (Camera & Imaging Products Association) standards. Testing performed using the EOS-1D X digital SLR camera at a focal length of 105mm. The number of stops may vary based on the camera model used.
