Out Of Stock
Refurbished EF-M 18-150mm f/3.5-6.3 IS STM Lens Graphite
1375C008
$399.99
Out Of Stock
Free Standard Shipping & Handling on Camera & Lens Products
  • Canon's first EF-M high zoom power lens covering a broad range of shooting scenes with a high zoom ratio of up to 8.3x (29-240mm equivalent).
  • Compact and lightweight design allows for easy portability.
  • Optical design helps provide excellent image quality across a broad zoom range comparable to the EF-S 18–135mm f/3.5–5.6 IS USM lens.
  • Maximum magnification of 0.31x at focal length 150mm.
  • Image Stabilizer effect at up to 4* stops of shake correction helps capture sharp images.
  • Combination IS is achieved when used with the EOS M5 digital camera for maximum image stabilization when shooting video.
Add a CarePAK for Accidental Damage Protection. Learn More:None
In the box
Return Policy
View Full Technical Specs PDF
Main Unit Spec
Product Disclaimer
* Measured at the focal length of 150mm (35mm equivalent of 360mm), using the EOS M3 digital camera based upon CIPA (Camera & Imaging Products Association) standards.
