Refurbished EOS 6D Mark II Body
1897C040
As low as $1,259.00
Buy now and pay later with
klarna Pay Later
Paypal Pay Later
Out Of Stock
  • 26.2 Megapixel Full-frame CMOS Sensor.
  • Optical Viewfinder with a 45-point All Cross-type AF System*.
  • Dual Pixel CMOS AF with Phase-Detection & Full HD 60p.
  • DIGIC 7 Image Processor, ISO 100-40000.
Show more
Where to Buy
Use as a High-Quality Webcam
You can use this camera with EOS Webcam Utility Software.
Learn More and Start Streaming
View Full Technical Specs PDF
Type
Image Sensor
Recording System
White Balance
Viewfinder
Autofocus
Exposure Control
Shutter
External Speedlite
Drive System
Live View Functions
Video Shooting
LCD Monitor
Playback
Quick Control Function
Image Protection and Erase
Direct Printing
DPOF: Digital Print Order Format
Wi-Fi®
NFC
Bluetooth®
GPS Functions
Customization
Interface
Power Source
Dimensions and Weight
Operating Environment
SDK / API Compatibility
Product Disclaimer
* The number of AF points, cross-type AF points and Dual cross-type AF points vary depending on the lens used.
** Compatible with iOS® versions 8.4/9.3/10.2, Android™ smartphone and tablet versions 4.1/4.2/4.3/4.4/5.0/5.1/6.0/7.0/7.1. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
*** Compatible with Android™ smartphone and tablet versions 4.1/4.2/4.3/4.4/5.0/5.1/6.0/7.0/7.1.
^ Compatible with select smartphone and tablet devices (Android#8482; version 5.0 or later and the following iOS#174; devices: iPhone 4s or later, iPad 3rd gen. or later, iPod Touch 5th gen. or later) equipped with Bluetooth® version 4.0 or later and the Camera Connect App Ver. 2.0.40. This application is not guaranteed to operate on all listed devices, even if minimum requirements are met.
^^ In certain countries and regions, the use of GPS may be restricted. Therefore, be sure to use GPS in accordance with the laws and regulations of your country or region. Be particularly careful when traveling outside your home country. As a signal is received from GPS satellites, take sufficient measures when using in locations where the use of electronics is regulated.
^^^ Continuous shooting speed may vary depending on the shutter speed, the aperture, the lens being used, the battery charge and various camera settings.
