Refurbished EOS M50 Body Black
Free Standard Shipping & Handling on Camera & Lens Products - Offer valid January 19, 2023 12:00 a.m. through March 31, 2023 11:59 p.m. ET. Offer valid in U.S.A. only, and void where prohibited, taxed or restricted. Availability of certain items may be limited. Limit of ten of any one item per order, subject to availability. Order will be shipped to a street address in the 50 United States or the District of Columbia only. Dealers, distributors and other resellers are not eligible for this offer. Offer subject to Terms of Sale.
- Improved Dual Pixel CMOS AF and Eye Detection AF.
- 24.1 Megapixel (APS-C) CMOS Sensor with ISO 100–25600 (H: 51200).
- 4K UHD* 24p and HD 120p** for Slow Motion.
- Built-in OLED EVF*** with Touch and Drag AF.
Terms
Service
Eligible Products
Offers, Orders and Returns
Enrollment
Payment and Cancellation
Changes to Terms
In the box
- EOS M50 (Black) Refurbished
- Battery Pack LP-E12
- Battery Charger LC-E12
- Neck Strap EM-200DB
- Camera Cover R-F-4
Return Policy
The Canon Online Store will accept, for return or exchange, defective or unopened merchandise purchased at the Canon Online Store, subject to the exceptions and timeframe for returns listed below: All merchandise returned to the Canon Online Store must be in the original packaging with all original items (such as manuals, cables, etc.) accompanying the merchandise and a copy of the invoice/packing slip included to be eligible for return or exchange. Shipping and handling fees from your original order will not be refunded, unless the merchandise is determined by the Canon Online Store, in its sole discretion, to be defective.
See Return Policy for complete information.
Overview
The EOS M50 is a compact interchangeable lens camera for aspiring photographers looking for an easy way to boost the quality of their photos and videos. With clear, high-resolution 4K UHD 24p video, you can capture the incredible details and cinematic moments of your life at home or wherever your adventures take you. Snap vibrant, eye-catching photos with a 24.1 Megapixel (APS-C) CMOS Sensor using the built-in Electronic Viewfinder or Vari-angle Touchscreen LCD. Thanks to the fast and improved Dual Pixel CMOS Autofocus system, you can quickly lock focus on your subject to make sure you don’t miss the action. See how the EOS M50 can easily deliver the high-quality photos and videos you’ve always imagined.
View Full Technical Specs PDF
Type
Digital single-lens non-reflex AF/AE camer
SD/SDHC/SDXC memory card
* UHS-I compatible
EF-M lens (and EF/EF-S lenses when using Mount Adapter EF-EOS M)
Equivalent to approximately 1.6x the focal length indicated on a mounted lens
Image Sensor
Canon CMOS Sensor
Effective pixels: Approx. 24.1 Megapixels
Total pixels: Approx. 25.8 Megapixels
- Pixel count may decrease due to image processing.
Square pixel approx. 3.72 µm
3:2
Auto / Manual
Recording System
EXIF 2.31 (DCF2.0)
JPEG / RAW (CR3 a Canon 14-bit RAW format)
3:2 Aspect Ratio
Large: 6000 x 4000
Medium: 3984 x 2656
Small 1: 2976 x 1984
Small 2: 2400 x 1600
RAW: 6000 x 4000
C-RAW: 6000 x 4000
16:9 Aspect Ratio
Large: 6000 x 3368
Medium: 3984 x 2240
Small 1: 2976 x 1680
Small 2: 2400 x 1344
RAW: 6000 x 3368
C-RAW: 6000 x 3368
4:3 Aspect Ratio
Large: 5328 x 4000
Medium: 3552 x 2664
Small 1: 2656 x 1992
Small 2: 2112 x 1600
RAW: 5328 x 4000
C-RAW: 5328 x 4000
1:1 Aspect Ratio
Large: 4000 x 4000
Medium: 2656 x 2656
Small 1: 1984 x 1984
Small 2: 1600 x 1600
RAW: 4000 x 4000
C-RAW: 4000 x 4000
Continuous, Auto Reset, Manual Reset
Yes
Auto, Standard, Portrait, Landscape, Fine Detail, Neutral, Faithful, Monochrome, User Def. 1–3
White Balance
- Auto (Ambience priority)
- Auto (White priority)
- Daylight (Approx. 5200K)
- Shade (Approx. 7000K)
- Cloudy (Approx. 6000K)
- Tungsten light (Approx. 3200K)
- White fluorescent light (Approx. 4000K)
- Flash (Approx. 5200K)
- Custom
- Color temp. (Adjustable from 2500K to 10000K in 100K increments)
Blue/Amber: ±9 levels
Green/Magenta: ±9 levels
Viewfinder
Built-in electronic color viewfinder with 0.39-type screen size and approx. 2.36 million dots
3 types
Provided
Autofocus
Dual Pixel CMOS AF (Face+Tracking AF, Zone AF, 1-point AF)
143 / 99 points
EV -2–18 (at room temperature 73°F/23°C, ISO 100, when using EF-M 22mm f/2 STM)
- TTL Autofocus
- One-Shot AF
- Servo AF
- Continuous AF
- MF (Manual Focus)
- MF Peaking
- Electronic Manual Focus on Lens (Focus is manually adjusted after One-Shot AF operation)
Provided
Built-in LED lamp
Exposure Control
Real-time metering using the image sensor
- Evaluative metering (384 zones)
- Partial metering (6.4%)
- Spot metering (2.8%)
- Center-weighted average
EV 0–20 (at room temperature 73°F/23°C, ISO 100)
- Program AE
- Shutter-priority AE
- Aperture-priority AE
- Manual exposure
ISO Auto Range (AUTO mode): ISO 100–6400
Max. ISO Speed (P mode): ISO 25600
Max. Expanded ISO Speed (P mode): ISO 51200
- Manual: ± 3 stops in 1/3-stop increments
- AE Bracketing: ± 2 stops in 1/3-stop increments
Manual / Auto
Shutter
Electronically controlled focal-plane shutter
1/4000 sec. to 30 sec.
Highest flash-sync shutter speed: 1/200 sec.
Off, 2 sec. delay, 10 sec. delay, Custom, Remote Shooting
Time Lag (LCD Monitor On)
Approx. 1.0 sec.
Built-in Flash
Manual pop-up flash
GN approx. 5/16.4 (ISO 100 m/ft.)
Covers approx. 15mm focal length (35mm film size conversion: approx. 24mm)
±2 stops in 1/3-stop increments
External Speedlite
E-TTL II autoflash
Provided
Flash functions settable with the camera
Drive System
Single shooting, Continuous shooting (High-speed continuous shooting, low-speed continuous shooting)
Video Shooting
MP4
Video: MPEG-4 AVC / H.264
Audio: MPEG-4 AAC-LC (stereo)
Recording Sizes:
3840 x 2160 (4K UHD), 1920 x 1080 (Full HD) and 1280 x 720 (HD)
[3840 x 2160]: 23.98 fps
[1920 x 1080]: 59.94 fps / 29.97 fps / 23.98 fps
[1280 x 720]: 119.9 fps / 59.94 fps
ISO Auto Range (AUTO and Manual mode): ISO 100–6400
1920 x 1080 (Full HD), 1280 x 720 (HD)
ISO Auto Range (AUTO and Manual mode): ISO 100–12800
Expandable to ISO 25600
±3 stops in 1/3-stop increments
LCD Monitor
TFT color liquid crystal monitor
3.0 type
Approx. 1.04 million dots
Vari-angle
Electrostatic capacitance type
29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukrainian, Turkish, Arabic, Thai, Simplified Chinese, Traditional Chinese, Korean, Malay, Vietnamese, Indonesian, Hindi, Japanese)
Playback
- Single-image display
- 1 shot + information display
- Simple information
- Detailed information
- Histogram
- Lens information
- Picture Style
- Noise reduction
- Correction data
- Index display
- 4-image
- 9-image
- 36-image
- 100-image
- Image rotate
Provided
Provided
Direct Printing
PictBridge
JPEG and RAW* are printable.
*Prints JPEG images after RAW processing.
Digital Print Order Format
DCF-compliant DPOF compatible (Version 1.1)
Customization
Functions can be assigned to the following controls (set in Custom Functions):
- Shutter button
- Cross button (up, down, left, right)
- AE lock button
- M-Fn button
- Movie button
Interface
Micro USB
HDMI OUT terminal Type D
HDMI output while recording (shooting screen without sound) available
HDMI output to HDR compatible TVs* available
* Movie playback not supported. JPEG images are not displayed in HDR.
Power Source
LP-E12
Number of Still Image Shots (CIPA compliant: room temperature 73°F/23°C)
Screen On*: Approx. 235 shots
Electronic Color Viewfinder On*: Approx. 235 shots
Number of Still Image Shots (Eco Mode On)Screen On**: Approx. 370 shots
Movie Recording Time (CIPA compliant: room temperature 73°F/23°C)
Screen On: Approx. 85 min.
Electronic Color Viewfinder On: Approx. 85 min.
Movie Recording Time*** (Continuous Shooting)
Screen On: Approx. 130 min.
Electronic Color Viewfinder On: Approx. 130 min.
* Approx. 290 shots when power saving is enabled.
** Approx. 425 shots when power saving is enabled.
*** Total shooting time when shooting is performed under the following conditions: using default AUTO Mode; without using zooming and other operations; when max. recording time per movie is reached and recording stops/resumes automatically.
Approx. 4 hr.
- Time when playing back a slideshow of still images.
Dimensions and Weight
Approx. 4.6 x 3.5 x 2.3 in. (116.3 x 88.1 x 58.7mm)
- CIPA compliant.
Black
Approx. 12.4 oz. / 351g (body only)
Approx. 13.7 oz. / 387g (including battery pack, memory card)
- CIPA compliant.
Approx. 12.5 oz. / 354g (body only)
Approx. 13.8 oz. / 390g (including battery pack, memory card)
- CIPA compliant.
Operating Environment
32-104°F / 0-40°C
85% or less
Product Disclaimer
* Shooting at 23.98p is possible. Shooting takes place by cropping pixels from the center of the sensor. Contrast detection AF is used.
** AF is fixed. Playback is 1/4 slow motion playback (29.97p).
*** The EOS M50 camera's EVF does not support a display change to the vertical layout.
^ Compatible with iOS® versions 9.3/10.3/11.0, Android™ smartphone and tablet versions 4.4/5.0/5.1/6.0/7.0/7.1/8.0. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
^^ Compatible with Android™ smartphone and tablet versions 4.4/5.0/5.1/6.0/7.0/7.1/8.0.
^^^ Compatible with select smartphone and tablet devices (Android™ version 5.0 or later and the following iOS® devices: iPhone 4s or later, iPad 3rd gen. or later, iPod Touch 5th gen. or later) equipped with Bluetooth® version 4.1 or later and the Camera Connect App Ver. 2.1.20. This application is not guaranteed to operate on all listed devices, even if minimum requirements are met.
+ It is necessary to download and install Canon's Image Transfer Utility 2. Connect the camera and computer each to your home network, and only the camera must be paired with ITU2 the first time.
