RF100-400mm F5.6-8 IS USM
RF100-400
As low as $699.99 Regular Price $749.99
4 interest free payments of $175.00 with
klarna Pay Later
Paypal Pay Later
In Stock
  • Compact, lightweight and high-image quality RF tele zoom lens, with a versatile zoom range of 100-400mm
  • Optical Image Stabilizer with up to 5.5 StopsFootnote1 of shake correction
  • High speed, smooth and quiet autofocus with Canon’s Nano USM
  • 9-blade circular aperture for beautiful bokeh
  • Control Ring for direct setting changes
Show more
Overview
Perfect for Wildlife, Sports, Travel and More
The RF100-400mm F5.6-8 IS USM is a compact, lightweight telephoto lens for EOS R Series cameras, offering a versatile zoom range that brings subjects closer with ease. The RF100-400mm F5.6-8 IS USM is similar in size to the EF 70-300mm F4.5-5.6 IS II USM lens, and not only reaches to 400mm, but also has fast Nano USM focusing and up to 6 stops of Coordinated IS when used in combination with an EOS R series camera featuring In-body Image Stabilization, like the EOS R5 and EOS R6, or 5.5 stops with an EOS R/RP camera. Using a single Ultra Low Dispersion lens element towards the front of the lens group corrects chromatic aberration throughout the entire zoom range, making your images look crisp and colorful with minimal color blur.
rf100-400mm f5.6-8 is usm
The travel-friendly size and weight (similar in size to the EF 70-300mm F4.5-5.6 IS II USM lens but a bit lighter) of this lens makes it easier for it to be attached with a camera around your neck while walking around for an extended time and also allows room for more lenses in a camera backpack.
landscape image
Because RF lenses are designed specifically for the RF Mount found on EOS R series cameras, the lens and camera combine to share Image Stabilization data, helping to dramatically reduce the effect of camera shake that can occur when working handheld. This applies when capturing both stills and video with up to 5.5 stops of stabilizationFootnote1 for accurate and clear content.
duclking in water
Up to 6 stops of shake correctionFootnote2 when paired with EOS R series cameras featuring In-Body Image Stabilizer (IBIS)
This IS enabled lens can provide even more steadiness when shooting, up to 6 stops of coordinated IS, if paired with an EOS R Series camera featuring In-Body Image Stabilization, such as the EOS R5 and EOS R6, to further help you capture impressively clear results with slower shutter speeds.
running water
Minimum focusing distance of 2.89 feet at 200mm and maximum magnification of 0.41x at 400mm
With a minimum focusing distance of 2.89 feet at 200mm, the RF100-400mm F5.6-8 IS USM lens is capable of capturing sharp and detailed images from various distances. Especially noteworthy is the lens’s close-up capabilities at the 400mm zoom setting — at its minimum focus distance, at 400mm, you can fill the frame with a subject about the size of a credit card providing outstanding versatility and strikingly sharp images.
close up of flowers on a tree
With any Canon EOS R-series camera, expect swift and positive autofocus. The Nano USM focus system is especially advantageous to video users, because of its combination of quiet operation and outstanding smoothness of focus changes during actual recording.
ballerina
Getting a smooth and natural looking out-of-focus background blur isn’t a problem for this lens as it has a 9-blade circular aperture which separates your subject from the background, while also providing a beautiful backdrop that's visually appealing in itself.
dog looking at camera
The RF100-400mm F5.6-8 IS USM lens incorporates a Control Ring on the lens barrel that can directly adjust numerous settings including shutter speed, aperture, ISO, exposure compensation and more. Located towards the front of the lens it effectively adds a third dial to EOS R and RP cameras, and a fourth dial to cameras such as EOS R5 and R6 cameras. With a tactile, easily distinguished surface and a clicking mechanism that provides tangible feedback for confident use while looking through the viewfinder, the control ring adds outstanding connection to any shooting scenario. For photographers and movie makers who would prefer a silent control ring, the clicking mechanism can be removed at a Canon Factory Service Center location for a fee.
eos
Compatible with optional Canon Extenders RF1.4xFootnote3 and RF2xFootnote4
To help get you even closer to the subject, attach the compatible optional Canon RF extenders to the RF100-400mm F5.6-8 IS USM and get the equivalent of 560mm focal length coverage with the Extender RF1.4x, or 800mm using the Extender RF2x. In fact, the RF100-400mm F5.6-8 IS USM is the first non-L-series Canon lens with tele extender compatibility, helping transform the lens into an incredibly powerful telephoto combination, with relatively modest additional size and weight. This added flexibility and versatility helps make the RF100-400mm F5.6-8 IS USM an amazing option for nature photography and more.
eos
Sample Images
*ISO speed is based on recommended exposure index.
View Full Technical Specs PDF
Lens
Extender RF Compatibility
Optical Design
Focusing
Image Stabilization
Exterior Design
Dimensions, Weight
Accessories
Reviews
RF100-400mm F5.6-8 IS USM Compatible Products
Cases, Bags & Straps
Product Disclaimer
  1. Based on CIPA (Camera & Imaging Products Associations) standards. Testing performed at focal length of 400mm, using the EOS R camera.
  2. Based on CIPA (Camera & Imaging Products Associations) standards. Testing performed at focal length of 400mm, using the EOS R5 camera.
  3. A focal length range of 140mm (wide) through 560mm (tele) is possible to be achieved using the Extender RF1.4x.
  4. A focal length range of 200mm (wide) through 800mm (tele) is possible to be achieved using the Extender RF2x.
