RF24-105mm F4-7.1 IS STM
RF24105STM
As low as $459.99
4 interest free payments of $115.00 with
klarna Pay Later
Paypal Pay Later
Out Of Stock
  • Compact, Lightweight and High-Quality RF Lens with a Versatile Zoom Range of 24-105mmFootnote1
  • Maximum Magnification of 0.4x and Minimum Focusing Distance of 0.66 ft. in Auto Focus.
  • Maximum Magnification of 0.5x and Minimum Focusing Distance of 0.43 ft. when using Center Focus Macro.
  • Optical Image Stabilization at up to 5 StopsFootnote2 of Shake Correction.
  • Leadscrew-type STM enables Smooth Autofocusing for Still-image and Video Shooting.
  • Control Ring for Direct Setting ChangesFootnote3.
Show more
Overview
Perfect for Landscapes, Portraits, Travel and More.
The RF24-105mm F4-7.1 IS STM is a compact, lightweight lens for EOS R Series cameras, offering a versatile zoom range1 that captures different subjects with ease. For macro enthusiasts, the RF24-105mm F4-7.1 IS STM is particularly advantageous, featuring an impressive maximum magnification of 0.5x using Center Macro Focus — helping you snap photos from as close as one inch away.
VERSATILE
ZOOM
RANGE
VERSATILE
ZOOM
RANGE
Image Alt Text
Explore the New RF24-105mm F4-7.1 IS STM Lens with Jon Lorentz
Add versatility to your gear bag with the new RF24-105mm F4-7.1 IS STM lens. Designed for EOS R series cameras, this compact and lightweight lens offers a flexible zoom range, excellent close-up focusing — including 0.5x maximum magnification — and smooth autofocusing, thanks to a leadscrew-type STM motor. Explore these key features and more with Canon USA’s Technical Advisor, Jon Lorentz.
rf24-105mm 4-7.1 is stm
Compact and Lightweight
A dramatically compact lens, the RF24-105mm F4-7.1 IS STM packs a broad zoom range and a bright maximum aperture into a well-balanced, refined design that balances comfortably on EOS R series cameras. The RF24-105mm F4-7.1 IS STM lens makes for a lightweight and comfortable, all-day lens
girl holding camera
Ideal Zoom Range for All-day Photography
With a zoom range covering macro-like, wide angle, normal and telephoto, the RF24-105mm F4-7.1 IS STM excels in a variety of shooting situations, offering amazing versatility with the turn of a zoom ring. For example, with the RF24-105mm F4-7.1 IS STM, the EOS R series cameras can go from shooting landscapes to portraits without a single lens change.
With a minimum focusing distance of 0.66 ft./0.20m and a maximum magnification of approx. 0.4x, the RF24-105mm F4-7.1 IS STM lens is capable of capturing detailed images from various distances. Whether you're shooting portraits or still-life, the RF24-105mm F4-7.1 IS STM lens can easily provide sharp images with minimal distortion.
The RF24-105mm F4-7.1 IS STM lens is ideal for capturing a variety of subjects at a close ratio. With its maximum magnification ratio of 0.5x - using Center Macro Focus. Simply switch the focus mode to "MF" (Manual Focus) on any EOS R series camera, set the focus/control ring switch to "FOCUS" and enjoy snapping shots from as close as one inch away.
red flower
The RF24-105mm F4-7.1 IS STM lens is designed to work in conjunction with EOS R series cameras, with both the camera and the lens sharing data to dramatically reduce camera-shake blur, regardless of the situation, whether shooting video or stills. With up to 5 stopsFootnote2 of stabilization, it delivers impressively clear results.
two pianos
Capture fast-moving subjects without missing a moment by combining the leadscrew-type STM with the EOS R series' Dual Pixel autofocus system to achieve high-speed, high-precision focus.
The RF24-105mm F4-7.1 IS STM lens incorporates a control ring on the lens barrel that can directly adjust numerous settings including shutter speed, aperture, exposure compensation and more. Located towards the front of the lens, the control ring has a tactile, easily distinguished surface that provides tangible feedback for confident use while looking through the viewfinder.
control ring lens
High-speed Communication with an EOS R Series Camera
Designed to quickly process data, the RF24-105mm F4-7.1 IS STM features a 12 pin communication system that is the fastest yet for a Canon lens/camera combination. This accelerates AF, Image Stabilization, the Digital Lens Optimizer and more, helping to simplify complex operations and provide a quick and reliable user experience.
Lens Information Display
Another helpful feature, the EOS R series cameras can display lens information right in the viewfinder, making it easy to confirm the lens's focal length without looking away from the subject at hand.
In-camera Digital Lens Optimizer
The EOS R system's 12 pin communication system enables the Digital Lens Optimizer, which works in-camera to combat aberrations and image deterioration, especially in the edges of the image frame when shooting at a large aperture. Data from the RF24-105mm F4-7.1 IS STM lens is transferred automatically to the camera body, facilitating near immediate correction for clear, detailed images.
12 pin system
View Full Technical Specs PDF
Lens
Reviews
RF24-105mm F4-7.1 IS STM Compatible Products
Lens Caps
Lens Caps
Product Disclaimer
  1. In order to use this lens with the EOS R or EOS RP, you must download and install the latest camera firmware from the Canon website.
  2. Based on CIPA (Camera & Imaging Products Association) standards. Testing performed at a focal length of 105mm using the EOS R camera.
  3. The Control ring is the same as the Focusing ring.
