RF24-70mm F2.8L IS USM
RF2470/2.8LU
As low as $2,299.00 Regular Price $2,599.00
Backorder
$300 Instant Savings
FREE Standard Shipping
  • High Image Quality and Bright f/2.8 Aperture Standard Zoom RF L Lens
  • Optical Image Stabilization of up to 5 Stops1 of Shake Correction
  • High Speed, Smooth and Quiet Auto Focus with Nano USM
  • Minimum Focusing Distance of 0.69 ft./0.21m (wide), 1.25 ft./0.38m (tele)
  • Control Ring for Direct Setting Changes
  • 12 pin Communication System
Show more
Overview
RF24-70mm F2.8 L IS USM
Experience the possibilities with the RF24-70mm F2.8 L IS USM lens. Built for EOS R Series full-frame mirrorless cameras, this compact L-series lens combines a bright f/2.8 maximum aperture with a standard focal length zoom range, making it a versatile, all-purpose lens for your photography ventures.
Image Alt Text
Introducing the Canon RF24-70mm F2.8 L IS USM
Engineered with NANO USM technology for accurate and silent AF operation—combined with reduced focus breathing for more seamless focus transitions—the dynamic RF24-70mm F2.8 L IS USM lens helps you cover it all, from portraits and landscapes, to travel and everyday moments.
Image Alt Text
Features
Stunning, Bright Imagery
A constant f/2.8 max. aperture delivers images with gorgeous background blur, ideal for portraits.
model crossing the street
Wide Zoom Range Coverage
Capture images at nearly any length with the 0.69 ft. (wide)/1.25 ft. (telephoto) focusing distance.
train figurine
For Setting Changes
The Control Ring lets you directly adjust shutter speed, aperture, exposure compensation and more.
hand holding camera
Fast, Reliable Operation
12-pin communication between camera and lens accelerates AF, image stabilization and other functions.
12 pin communication system
For Clear, Steady Results
Up to 5 stops1 of stabilization dramatically reduces camera-shake blur, both for video and stills.
City lights at night
1 Based on CIPA (Camera & Imaging Products Association) standards, Testing performed at a focal lenght of 35mm using the EOS R camera.
Detect Even Slow Shaking
Dual Sensing IS analyzes sensor information from both the lens and the camera to correct shake.
Low frequency shake is detected and corrected from the CMOS sensor's image information, and a lens-based gyro sensor also detects shaking. The two types of information are compared and analyzed to achieve an IS effect up to 5 stops*
Dual Sensing IS
* Based on CIPA (Camera & Imaging Products Association) standards, Testing performed at a focal lenght of 35mm using the EOS R camera.
Enhanced Shake Correction
Combination IS communicates between both camera and lens IS systems for optimal shake correction.
1) Pitch Axis
2) Roll Axis
3) Yaw Axis
4) Horizontal
5) Vertical
6) Pitch Axis
7) Yaw Axis
Demo of the Different Shake Corrections
Three Aspherical Elements & Two UD Elements
Air Sphere Coating (ASC)
Fluorine Coating
Dust- & Weather-resistance
Man taking pictures in the outdoors
View Full Technical Specs PDF
Lens
Reviews
RF24-70mm F2.8L IS USM Compatible Products
Lens Caps
Lens Caps
Product Disclaimer
  1. Based on CIPA (Camera & Imaging Products Association) standards. Testing performed at a focal length of 70mm using the EOS R camera.
