RF50mm F1.2 L USM
RF50/1.2LUSM
As low as $2,399.00 Regular Price $2,599.00
Buy now and pay later with
klarna Pay Later
Paypal Pay Later
In Stock
  • Fixed Focal Length Lens with High Image Quality and Bright f/1.2 Aperture for the EOS R System.
  • Minimum Focusing Distance of 1.31 ft./0.40m.
  • Control Ring for Direct Setting Changes.
  • Three Aspherical Elements and One UD Element0
  • 12 pin Communication System.
  • Dust- and Water-resistant with Fluorine Coating.
Show more
Overview
RF50mm F1.2 L USM
Bright and sharp, the RF50mm F1.2 L USM lens delivers consistent, impressive performance and shallow depth of field for gorgeous images in a large variety of situations. Its f/1.2 aperture means amazing performance in low light and beautiful, detailed images with evocative background blur.
Image Alt Text
Large 54mm Diameter
RF lenses work together with a large 54mm diameter mount for remarkable sharpness from edge to edge.
lens diameter
12 pin Connection
The fast 12 pin communication system accelerates AF, IS and more for a reliable user experience.
digic 8
Lens Information
The EOS R Series cameras can display lens information in the viewfinder to confirm focal length.
sunset through lens
Control Ring
A control ring on the lens barrel helps directly adjust numerous settings for easy operation.
Control Ring
Fixed Focal Length Lens with Bright f/1.2 Aperture
An incredibly bright fixed focal length lens, the RF50mm F1.2 L USM delivers sharp images with gorgeous background blur, maintaining high image quality even wide open at its f/1.2 maximum aperture.
Lens
A minimum focusing distance of 1.31 ft./0.40m with a maximum magnification of approx. 0.19x means sharp and detailed images from nearly any distance. Whether you’re shooting portraits, still life or close ups, the RF50mm F1.2 L USM can provide sharp images with minimal distortion.
ornamental Whiskey glass
Resists Vibration Shock
Vibration shock resistance helps maintain focus and settings even in turbulent situations.
Photographer wearing a vest
Dust- and water-resistant construction means uninterrupted performance even in difficult weather.
Fluorine Coating
Fluorine coatings help minimize dirt and dust, making it easy to clean smudges and fingerprints off.
Fluorine Coating
Air Sphere Coating
The RF50mm F1.2 L USM lens features Canon’s Air Sphere Coating (ASC), which significantly reduces the occurrence of lens flare and ghosting regardless of focal length or the angle of light. This helps provide clean results with minimal distractions and aberrations.
Image Alt Text
View Full Technical Specs PDF
Main Unit Spec
Reviews
RF50mm F1.2 L USM Compatible Products
Lens Caps
Lens Caps
