RF50mm F1.4 L VCM
6908C002
Special Price $1,449.00 Regular Price $1,549.00
Buy now and pay later with
klarna Pay Later
Paypal Pay Later
In Stock
  • New 50mm L-Series hybrid lens featuring an iris ring for manual iris control.
  • A Nano USM is used for floating focus and a Voice Coil Motor (VCM) for rear focus, great for video.
  • L-Series level durability and weather-resistant construction for use in harsh environments helps ensure reliability and dependability.
  • Incredibly minimal focus breathing - within 2.5% of the entire range in the lens alone! Further electronic breathing correction brings it to within 1.0% of the entire range.
  • Air Sphere Coating (ASC) helps to significantly reduce lens ghosting and flare.
  • This lens features 1 UD elements to minimize chromatic aberration, and 2 aspheric lenses for incredible quality from edge-to-edge.
  • 14 Elements in 11 groups.
  • 11-blade aperture.
  • 15.7” (0.4m) Minimum Focus Distance with 0.15x maximum magnification.
  • Equipped with a user-programmable lens function button.
  • Accepts ø67mm front screw on filters.
Show more
Where to Buy
Overview
The RF50mm F1.4 L VCM is part of the expanding Hybrid lens series, targeting a wide range of still-image and video shooters, with a combination of wide-angle coverage, a fast f/1.4 maximum aperture, and excellent image quality. On a full frame camera this lens gives you a Standard-angle look which has for decades been the most "all-purpose" focal length for photos and videos. On the video side, this lens really shines with a dedicated manual Iris ring, and a linear focus motor called a VCM (Voice Coil Motor) that is virtually silent.  The VCM works in tandem with a Nano USM (Ultrasonic Motor) on the floating focus unit for incredibly fast autofocus.  And finally, focus breathing is barely noticeable on this incredibly versatile lens , minimizing distractions for your viewer, and keeping your imagery and story as the priority.
RF50mm F1.4 L VCM - Front View
Features
Incredible Feature Set From an Incredible Lens
This lens has a lot going for it. You already know about the VCM and Iris control ring, but there is so much more. You can attach filters to this lens in two ways, a front 67mm screw thread allows for screw-on filters, and in the back of the lens is a cut gel filter holder (bundled). You also have a control ring and a control button both of which you can assign functions to. This lens is also dust and weather resistant, has two aspheric lenses, and ASC (Air Sphere Coating), SSC (Super Spectra Coating), and Fluorine Coating to significantly reduce ghosting and flare.
Excellent Image Quality
Again, thanks to the Canon RF lens mount, the RF50mm F1.4 L VCM lens offers great optical quality. Its optical design includes two UD lenses and one aspherical lens as well as Air Sphere Coating (ASC), and Super Spectra Coating (SSC) to reduce ghosting, and Fluorine coating on the front and rear lens surfaces to help mitigate smudges. On top of that, this lens features the same dust- and water-resistance found on every L-series lens with seals around the Control ring, focus ring, zoom ring, operation panel, and lens mount.
Carve Stone Art on a Wall
It’s Showtime!
This lens is part of a new family of “hybrid” lenses that focus on video creation as much as still photography. To that end, this lens features a manual iris control ring so you can smoothly change the aperture from f/1.4 to f/16 during video capture. Thanks to advancements in lens design, focus breathing on this lens is extremely minimal, and backlit images are sharp. Combine all of these features, and you’ve got a great video lens in your hands.
Camera Taking Picture of a Bar
Let’s Focus
The RF50mm F1.4 L VCM is part of a series of “hybrid” lenses that focus on video performance as much as still photography. One of these new features is a change to how the focus system works. There is a Nano USM that controls the floating focus unit, and a VCM (Voice Coil Motor) that powers the rear focus unit. These focus motors work in tandem for incredible speed in near silence. One important note about the VCM is that it requires power to hold its position, so when the camera is off, or the lens is not attached to a camera, you may hear and feel slight movement. This is normal, and there is extra cushioning inside the lens to help prevent damage in this situation.
VCM Motor
Sandwich on a Table
Get Close
With a minimum focus distance of just 9.4 inches, and an f/1.4 aperture you can capture some really compelling imagery that is unlike anything else.
Decoration on a Shelf
This product emits low level magnetic flux
. If you use an implantable cardiac pacemaker or other medical device and feel abnormalities, please keep away from this product and consult your doctor.
Sample Image Gallery by Lara Jade
Videos
Sort By:
Untitle Video
In Lost Woods, Ben Hagarty, Canon Co-Lab Ambassador, makes his first mark in narrative storytelling, bringing to life the highs, lows, and raw emotions of a band’s return to their roots. This highly anticipated short film stars Kyla Burke, Jacob Pauli, and the band Salt Fox, offering a reflective dive into the balance of dreams, love, and ambition.
Untitle Video
Join Canon U.S.A.‘s Brandon Chin as he introduces the RF24mm F1.4 L VCM & RF50mm F1.4 L VCM lenses expanding the line of hybrid primes.
Untitle Video
Learn about the Canon RF50mm F1.4 L VCM lens and see how this hybrid lens will transform what you can do with your camera. A versatile standard-angle lens that is lightweight and packed with still and video shooting features, including the durability and quality you expect with a Canon “L-Series” lens.
View Full Technical Specs PDF
Lens
Optical Design
Focusing
Exterior Design
Dimensions, Weight
Accessories
Reviews
RF50mm F1.4 L VCM Compatible Products
Lens Caps
Lens Caps
