RF7-14mm F2.8-3.5 L Fisheye STM
7343C002
As low as $1,899.00
Buy now and pay later with
klarna Pay Later
Paypal Pay Later
In Stock
  • Introducing the new Canon ultra wide-angle zoom (7-14mm) lens – the ultimate creative tool for extreme close-up action imagery with unique distortion, and extraordinary perspectives.
  • World’s firstFootnote1 fisheye zoom lens that covers a 190-degree angle of view.
  • Can achieve both “circular” fisheye imagery (at 7mm Wide position) and “full frame” diagonal fisheye (at 14mm Tele position) imagery.
  • Variable aperture lens support f/2.8 at the widest angle and f/3.5 at the telephoto setting.
  • Built-in support for use of EF-to-EOS R mount adapter drop-in filters (Clear, CPL, V-ND).
Show more
Where to Buy
Overview
Introducing the ultimate creative tool for wide-angle photography: This new ultra wide-angle zoom lens delivers an extraordinary perspective with circular fisheye coverage of 190º at 7mm and a diagonal fisheye view of 180º at 14mm. Designed for photographers and videographers who crave bold, immersive visuals, it offers a unique wide-angle experience that transforms ordinary scenes into dynamic, eye-catching compositions with fisheye distortion. Perfect for extreme close-up action and dramatic angles, this lens opens up a world of creative possibilities, letting you capture every detail and up to 190º around you with stunning depth and curvature.
An ultra wide-angle lens opens up a world of boundless unique options across countless shooting scenarios. Its expansive field of view makes it ideal for capturing the intensity of action sports, where every twist and turn can be framed with dramatic perspective. For extreme close-up action, the lens brings subjects into sharp focus while showcasing their surroundings in a bold, immersive way. Mounted on remote cameras, it delivers dynamic coverage from unique vantage points, and when paired with a compatible underwater housing, it can transform your underwater photography into breathtaking imagery of aquatic compositions. From sweeping landscapes and dazzling starscapes to timelapse and video, this lens excels at creating depth and drama. It’s also a great option for monoscopic virtual reality content, offering the ultra wide perspective needed to craft fully immersive experiences. Wherever creativity takes you, this lens ensures your vision is captured with impact and originality.
Fisheye View of Skateboarder
Normal View of Skateboarder
Fisheye Skateboarder
Fisheye Skateboard Wheel
Normal View of Skateboard Wheel
Features
Zoom Range
Go from a fully circular 190º image at 7mm to a frame filling 180º image at 14mm on a full frame camera.
Zoom Range
Zoom Range
Zoom Range
Fisheye Demo - Two Trees in a Field - 7mm
Fisheye Demo - Two Trees in a Field - 9mm
Fisheye Demo - Two Trees in a Field - 11mm
Fisheye Demo - Two Trees in a Field - 14mm
Build Quality
This lens is equipped with advanced technologies such as dust and weather resistance, fluorine coating, Air Sphere Coating, and premium L-Series optics featuring two replica aspherical lenses and five UD elements delivers exceptional performance and reliability for demanding creators. Its dust and weather resistant construction ensures dependable operation in harsh environments, while the fluorine coating helps repel moisture, oils, and fingerprints for easier maintenance and clearer imagery. Canon’s Air Sphere Coating effectively minimizes flare and ghosting, preserving contrast and color accuracy even when shooting toward strong light sources. The combination of precision aspherical elements and UD glass within the L-Series optical design provides outstanding sharpness, reduced chromatic aberration, and consistent image quality from edge to edge. Together, these features give photographers a rugged, high-performance tool engineered for both artistic exploration and professional grade results.
Cross Section of the Lens
Diagram of Seals Inside the Lens
Tame the Light with Filters
Adding a filter to the front of this lens is nearly impossible due to the lens curvature. However, since balancing your exposure is so important with this lens it has the ability to use the same drop-in filters (Clear, CPL, V-ND) that are used with the EF-to-EOS R mount adapter so you can achieve the looks you’re looking for.
Top Improvements vs. Previous Canon EF-Mount Fisheye Zoom Lenses
A new optical design in the RF-mount 7-14mm fisheye zoom lens. Five UD (Ultra-low Dispersion) glass elements, two Aspheric elements, and extensive application of Canon’s specialized ASC (Air Sphere Coating) mean not just sharp images, but reduced color fringing — especially at the outer edges of images and video — and less lens flare, when it’s aimed at the sun or other bright light sources. Image Quality is a strong reason to consider this 7-14mm fisheye zoom lens.
Wider coverage than any competitive AF fisheye zoom for full-frame cameras, at the 7mm circular fisheye zoom setting.Footnote2 Whether being used for creative imagery, astro photography, or anything else, circular fisheye users will have the world’s widest (190°) circular fisheye coverage available.
Since fisheye lenses can’t accept ordinary screw-in filters at the front of the lens, the RF7-14mm fisheye zoom lens offers a slot on the rear of the barrel for drop-in filters. The standard clear filter can be easily switched with an optional accessory variable neutral density (ND) filter, or a user-adjustable circular polarizing drop-in filter. Either adds to the lens’s flexibility for still or video imagery. And, they offer both durability and ability for quick filter changes. These are the same drop-in filters as previously used in Canon’s Drop-in Filter Lens Mount Adapter EF–EOS R.
This sounds like an expected feature in modern lenses, but many third-party fisheye lenses for Canon offer manual exposure and aperture operation only. The RF7-14mm fisheye zoom, however, can be used in the same way users would work with more conventional RF-mount lenses, and any exposure mode can be used as desired.
Close-up imagery becomes potentially even more powerful with the 7-14mm fisheye zoom lens. It focuses down to 5.9 inches (0.15m), at the full diagonal fisheye setting (14mm zoom setting). This can mean even stronger imagery, when the lens can be positioned close to the primary subject. And keep in mind: like all official specs for minimum focus distance, this is measured from the actual image sensor to the subject, not from the front of the lens itself.
We’ve already discussed the option for drop-in filters — especially important for video users is the availability of a variable ND filters, to get precise video exposure and shutter speeds in bright light conditions. Another video-centric feature is reduced focus breathing, designed-in to the optical system of the 7-14mm fisheye zoom lens. As the lens is focused, out-of-focus areas remain consistent in size, foreground and background. And, as mentioned, autofocus remains completely available during video as well as still operation.
Yet another customizable button, to join those on most EOS R-series camera bodies. Set your camera up for instant access to many possible features, when the lens’s AF-stop button is pressed. It’s in a handy location on the side of a lens barrel, making it easy to make quick function changes — or, as originally intended, to lock Servo AF whenever the user presses the button.
Get Closer
With a minimum focus distance of just 5.9 inches, photographers can get dramatically close to their subjects while still capturing the sweeping 180°/190° perspective these lenses are made for. Being able to focus this near creates striking, immersive images where foreground details appear exaggerated and incredibly sharp, while the background curves away in a signature fisheye distortion. This ultra‑close capability is especially useful for creative storytelling—whether highlighting textures, emphasizing scale, or crafting dynamic compositions in tight spaces. It also enables unique macro‑style wide‑angle shots, giving photographers more freedom to experiment with perspective, depth, and visual impact.
Fisheye View of Skateboard Wheel
Control Freak
This new lens puts intuitive control right at your fingertips, empowering creators to work faster and with greater precision. A customizable Lens Function Button lets you instantly access your preferred settings, giving you quick command over key shooting tools without taking your eye from the viewfinder. The Zoom Limit/Lock switch provides added versatility—allowing you to set a zoom range for consistent framing or lock the lens in place to prevent unwanted movement during transport or shooting. Rounding out the experience, the programmable Control Ring offers tactile, customizable adjustment of settings like aperture, ISO, or exposure compensation, delivering a seamless, professional workflow that adapts to your creative style.
RF7-14mm F2.8-3.5 L Fisheye STM - Button View
Virtually There
The extreme wide-angle nature of this lens perfectly lends itself to the creation of 2D Monoscopic VR content and has support built-in for the Canon EOS VR System application to create such content.
EOS VR Utility Demo - Sheep in a Field
Focus Breathing
By using a rear focus design that minimizes focus breathing—preventing the angle of view from shifting as you refocus—the lens delivers remarkably stable framing. This gives filmmakers smooth, professional looking results in every shot despite the lack of support for in-camera focus breathing compensation.
Stay in Focus
An incredibly unique feature for this kind of ultra wide-angle lens the ability to autofocus, which this lens has. Just because you choose to capture your images with a unique and expressive angle, does not mean you should have to give anything up, especially something as important as autofocus when shooting fast action like sports.
Powered by a lead‑screw type STM and the same advanced position‑detecting sensor used in Canon’s Nano USM technology, this lens delivers impressively quick start‑up and instant responsiveness. The STM system provides smooth, precise control with effortless start‑and‑stop performance, all within a streamlined, reliable mechanical design. The result is fast, accurate autofocus for still photography and beautifully smooth, whisper‑quiet AF for video—giving creators the confidence to capture every moment with professional polish.
Lead Screw Type Focus Systeme
MTF Chart Comparison
Compared to the Previous Canon EF 8-15mm f/4L Fisheye USM Lens
Sample Image Gallery
Sample Image Gallery by Dustin Snipes
Videos
Sort By:
Untitle Video
Discover the power of ultra wide creativity with the Canon RF7–14mm F2.8–3.5 L FISHEYE lens. Join Rudy Winston as he showcases how this groundbreaking lens delivers stunning, unconventional perspectives—capturing a 190° circular field of view at 7mm and a 180° fullframe image at 14mm. From closeup sports action to expansive landscapes and bold architectural shots, this fisheye lens opens the door to entirely new visual possibilities. Whether you're pushing creative boundaries or exploring fresh storytelling angles, this RF lens is built to inspire.
Untitle Video
Join advertising and editorial sports photographer Dustin Snipes as he takes the Canon RF7-14mm F2.8-3.5 L FISHEYE lens ring and court side to push the limits of his field of view. Photographing sumo and basketball opened up new angles that he was not able to achieve before.
View Full Technical Specs PDF
Lens
Optical design
AF
Exterior design
Dimensions, weight
Accessories
RF7-14mm F2.8-3.5 L Fisheye STM Compatible Products
Lens Caps
Lens Caps
Product Disclaimer
  1. As of 1/1/2026
  2. Based on Canon Inc. research, as of January 1, 2026, among autofocus circular fisheye lenses for full-frame cameras.
