RF70-200mm F4 L IS USM
RF70-200/4L
As low as $1,499.00 Regular Price $1,699.00
Buy now and pay later with
klarna Pay Later
Paypal Pay Later
In Stock
  • Canon’s Shortest and Lightest 70-200mm f/4 Interchangeable Zoom Lens
  • High Image Quality and Bright, Constant f/4 Aperture Telephoto Zoom RF L Lens
  • Optical Image Stabilizer with up to 5 Stops of Shake CorrectionFootnote1
  • Up to 7.5 stops of Shake CorrectionFootnote2 with Coordinated Optical Image Stabilizer and In-Body Image Stabilizer
  • High Speed, Smooth and Quiet Auto Focus with Dual Nano USM
  • Minimum Focusing Distance of 1.97 ft. and Maximum Magnification of 0.28xFootnote3
Show more
Overview
Designed for the EOS R System, this lens takes advantage of the large diameter mount and short back focus distance of the RF mount to maintain high image quality while being more compact and portable so you’ll be even more inclined to take it with you on your travels. Results are stunning thanks to 4 UD lenses which help correct chromatic aberration and keep colors vivid, reduced ghosting provided by Air-Sphere Coating (ASC), and Optical Image Stabilization plus coordinated Optical Image Stabilizer and In-Body Image Stabilizer for amazingly clear, crisp images at slow shutter speeds and smooth video footage. There are also dual Nano USMs contributing to a short minimum focusing distance and high-speed autofocus for still shooting and near-silent, smooth autofocus during movie shooting. These features and more, combined with the confidence to shoot in almost any condition with dust- and weather resistant seals and fluorine coating, make the RF70-200mm F4 L IS USM lens a solid performer for any situation.
Features
Canon's Shortest and Lightest 70-200mm f/4 Interchangeable Zoom Lens
Convenience is a major consideration when shooting, and the RF70-200mm F4 L IS USM lens is our most compact and lightest 70-200mm f/4 lens, making it even more appealing to use for your photo and video opportunities. As a more portable 70-200mm option than our EF version, this new RF lens is easier to fit into a messenger bag as well as a camera backpack vertically so it's always on-hand and ready to go.
RF70-200mm F4 L IS USM in camera bag
The EF 70-200mm F4 lenses provided impressive picture quality and that superb reputation has carried over and has been improved with this RF version. With L series optics and a 9 blade circular aperture for creative bokeh, this is an excellent telephoto complement to the RF24-105mm F4 L IS USM and will provide you with impressive results, even when shooting in low light situations.
portrait of female model
Optical Image Stabilization with up to 5.5 StopsFootnote1 of Shake Correction
Because RF lenses are designed specifically for the RF Mount found on EOS R series cameras, the lens and camera combine to share shooting data, helping to dramatically reduce the effect of camera shake that can occur when using handheld. This applies when capturing both stills and video with up to 5 stops of stabilizationFootnote1 for accurate and clear content.
dog running near water
When combined with an EOS R series camera equipped with In-Body Image Stabilizer, the lens' Optical Image Stabilizer teams up with the In-Body Image Stabilizer to provide coordinated IS up to 7.5 stops, further helping to alleviate shaking for photos and video, and adjusting the ratio from optical to in-body stabilization automatically throughout the zoom range so you have the best of both worlds.
bmx rider doing a trick
Like some of its predecessors such as the RF70-200mm F2.8L IS USM and RF100-500mm F4.5-7.1L IS USM lenses, the RF70-200mm F4 L IS USM is equipped with dual independent Nano USMs to help achieve high-speed and focus accuracy at any focal length or throughout its travel, and its focusing range. This helps you quickly focus and keep up with fast-moving subjects and also provides smooth and silent autofocus while shooting movies, so there is relatively no disturbance for you, the subject or in what you see visually and hear audibly during shooting and playback.
video
While the EF 70-200mm f/4L IS II USM counterpart lets you shoot at a minimum focusing distance of approx. 3.3 ft., the dual independent Nano USMs found in the RF70-200mm F4 L IS USM lets you get even closer, up to 1.97 ft. from the subject at full zoom range and at a maximum magnification of 0.28x (at 200mm), so you can get highly detailed, highly impressive images even at close range with a telephoto zoom lens.
fruit on a vine
Control Ring for Direct Setting Changes
The RF70-200mm F4 L IS USM lens has a separate, independent control ring that is located towards the front of the lens, which can be used for immediate exposure adjustments during still and video shooting. With the control ring, you can customize its dial to directly adjust settings such as shutter speed, lens aperture, exposure compensation and ISO. For photographers and moviemakers who would prefer a silent control ring, the clicking mechanism can be removed by a Canon service provider for a fee.
rf70
12-Pin Communication System
Designed to quickly process data, the 12-pin communication system inherent in all RF lenses helps accelerates AF, Image Stabilization, the Digital Lens Optimizer and more, helping to simplify complex operations and provide a quick and reliable user experience.
rf70
Dust - and Weather-resistant
Feel confident shooting in almost any weather condition, from rain to snow, thanks to dust- and weather-resistant construction in the lens mount, switch panel, lens barrel extension and all rings. Sealing is applied to lens joining sections and switch panels to help prevent water and dust from entering into the lens.
sealant diagram
Fluorine Coating
The RF70-200mm F4 L IS USM lens features fluorine coatings on the front and rearmost surfaces to help prevent water and oil from sticking to the lens, making it easy to clean off smudges and fingerprints.
Four UD Elements and Air-Sphere Coating (ASC)
Clear, high-quality images are produced with the help of four low refractive and ultra-low dispersion lenses, providing significant chromatic aberration correction through the entire zoom range. In addition, the RF70-200mm F4 L IS USM lens features our Air Sphere Coating (ASC), which helps to reduce the occurrence of lens flare and ghosting. This helps provide clean results with minimal distractions and aberrations.
boat saling under a cloudy sky
View Full Technical Specs PDF
Lens
Accessories
Reviews
RF70-200mm F4 L IS USM Compatible Products
Cases, Bags & Straps
Product Disclaimer
  1. Based on CIPA (Camera & Imaging Products Association) standards. Testing performed at a focal length of 200mm using the EOS R camera.
  2. Based on CIPA (Camera & Imaging Products Association) standards. Testing performed at a focal length of 200mm using the EOS R5 camera.
  3. At 200mm.
