RF85mm F1.2 L USM
RF85/1.2LUSM
As low as $3,099.00
Buy now and pay later with
klarna Pay Later
Paypal Pay Later
In Stock
  • High Image Quality and Bright f/1.2 Aperture L Lens for EOS R System Cameras.
  • Blue Spectrum Refractive Optics (BR) Reduces Chromatic Aberration.
  • Minimum Focusing Distance of 2.79 ft./0.85m.
  • Control Ring for Direct Setting Changes.
  • One Aspherical Element and One UD Lens.
  • 12 pin Communication System.
Show more
Overview
With its fixed 85mm focal length and wide f/1.2 maximum aperture, the RF 85mm F1.2 L USM lens is ideal for photographing portraits, weddings, fashion and more, and great for low-light situations and producing beautiful, soft backgrounds. It gives you fast autofocus speed, and works great with the Eye Detection AF feature found in the EOS R and EOS RP cameras to provide impressive focus on a subject’s eye. All this and more, including Blue Spectrum Refractive Optics (BR) to help reduce chromatic aberration and Air Sphere Coating to help minimize flaring and ghosting, combine to give you a lens you’ll want among your favorites.
Features
An incredibly bright fixed focal length lens, the RF 85mm F1.2 L USM distinguishes itself by maintaining incredibly high image quality, edge to edge, even wide open at its f/1.2 maximum aperture. With 13 elements in 9 groups and a 9-blade aperture system, it can deliver sharp and detailed images with gorgeous background blur and remarkable consistency.
rf85
Thanks to our BR optics (Blue Spectrum Refractive Optics), the RF 85mm F1.2 L USM helps capture beautiful detailed photos with minimal chromatic aberration, while also providing stunning resolution.
rf85
With a minimum focusing distance of 2.79 ft./0.85m and a maximum magnification of approx. 0.12x, the RF 85mm F1.2 L USM is capable of capturing sharp and detailed images from various distances. Whether you're shooting portraits, still life or close ups, the RF 85mm F1.2 L USM can easily provide sharp images with minimal distortion.
rf85
The RF 85mm F1.2 L USM lens incorporates a control ring on the lens barrel that can directly adjust numerous settings including shutter speed, aperture, exposure compensation and more. Located towards the front of the lens and effectively adding a third dial to the EOS R series cameras' main dial and quick control dial, the control ring has a tactile, easily distinguished surface and features a clicking mechanism that provides tangible feedback for confident use while looking through the viewfinder. For photographers and moviemakers who would prefer a silent control ring, the clicking mechanism can be removed by a Canon service provider for a fee.
rf85
Taking advantage of the RF mount, the RF 85mm F1.2 L USM lens offers incredible optical quality and an exceedingly bright f/1.2 maximum aperture. It features a large diameter Aspherical element for high image quality from center to corner and an Ultra-low Dispersion (UD) glass element that helps reduce aberrations for minimized distortion throughout the image plane.
rf85
Designed to quickly process data, the RF 85mm F1.2 L USM features the 12 pin communication system inherent in all RF lenses. This accelerates AF, Image Stabilization, the Digital Lens Optimizer and more, helping to simplify complex operations and provide a quick and reliable user experience.
rf85
Lens Information Display
As part of the EOS R system, the RF 85mm F1.2 L USM lens works with an EOS R series camera so that its lens information is displayed right in the viewfinder, making it easy to confirm the lens's focal length without looking away from the subject at hand.
In-camera Digital Lens Optimizer
The EOS R system's 12 pin communication system enables the Digital Lens Optimizer, which works in-camera to combat aberrations and image deterioration, especially in the edges of the image frame when shooting at a large aperture. Data from the RF 85mm F1.2 L USM lens is transferred automatically to the camera body, facilitating near immediate correction for clear, detailed images.
Dust- and Weather-resistant with Fluorine Coating.
For reliable performance even when weather conditions get difficult, the RF 85mm F1.2 L USM DS lens features dust- and weather-resistant construction in the lens mount, switch panel and all rings. Sealing is applied to lens joining sections, and switch panels to help prevent water and dust from entering into the lens.
rf85
High Reliability and Durability for Professional Use
Like all L series lenses, the RF 85mm F1.2 L USM DS lens is built to endure the rigors of professional use. Constructed to be rugged, refined and precise, it can be operated intuitively so concentration can remain on the subject at hand.
Vibration Shock Resistance
Engineered to accommodate its optical system, the RF 85mm F1.2 L USM DS lens features L series level vibration shock resistance in the lens barrel, helping to maintain focus and settings even in turbulent situations.
Fluorine Coating
The RF 85mm F1.2 L USM DS lens features fluorine coatings on the front and rearmost surfaces to help prevent dirt and dust from sticking to the lens, making it easy to clean off smudges and fingerprints.
Air Sphere Coating (ASC) Minimizes Lens Flare and Ghosting
The RF 85mm F1.2 L USM lens features our Air Sphere Coating (ASC), which significantly reduces the occurrence of lens flare and ghosting regardless of focal length or the angle of light. This helps provide clean results with minimal distractions and aberrations.
View Full Technical Specs PDF
Main Unit Spec
Reviews
RF85mm F1.2 L USM Compatible Products
Cases, Bags & Straps
