RP10 Thermal Receipt Printer
RP10 PRINTER
As low as $427.00
Out Of Stock
  • Space-Saving Design
  • Cost-Effective Thermal Printing
  • Customer Care
  • Environmentally Conscious
  • Country of Origin: Japan
  • TAA Compliant Device
Show more
RP-10 Thermal Printer
TYPEReceipt printer
PRINT METHOD Thermal Line-dot Printing
PRINTING DIRECTION1 Unidirectional with friction feed
DOT DENSITY 8 dot/mm
PAPER FEEDING PITCH 0.125 mm
CUTTER METHOD Full cut/ Partial cut
MAX PRINT WIDTH About 2.8” (72 mm)
PRINT SPEED Up to 5.9in/sec (150 mm/sec)
INTERFACE USB 2.0 full speed (12Mbps)
OPERATING TEMPERATURE 0-40oC (32-104 oF)
OPERATING HUMIDITY 30 to 85% RH (no dew condensation)
STORAGE TEMPERATURE -30 to 50oC (-21 to 122 oF)
STORAGE HUMMIDITY 10 to 90% RH (no dew condensation)
DIMENSIONS 5.3”(H) x 6.7”(W) x 11” (D)
WEIGHT 4.08 lb
POWER SUPPLY AC 100-240V 50/60Hz
POWER CONSUMPTION Printing: Maximum 55W
Sleep mode 0.7W
With power switch OFF: 0.4W
