SELPHY CP1500
CP1500_SWATCH
As low as $179.99
4 interest free payments of $45.00 with
klarna Pay Later
Paypal Pay Later
In Stock
  • The sleek and modern design of the SELPHY CP1500 is reflected in how easy it is to use even with powerful features such as Wi-FiFootnote1 and smartphone connectivity.Footnote2
  • Thanks to a small footprint, the SELPHY CP1500 is incredibly portable, and with the optional battery pack, you can print and share your memories from just about anyplace that you go.
  • Not only will your photos look great, they will also be instantly dry and water resistant, and continue to look great for up to 100 years.Footnote3
  • Enjoy the flexibility of Wi-Fi, USB, and memory cardFootnote4 connections for your SELPHY CP1500 to connect to just about anything and print from devices like your smartphone to your computer, camera, memory cards, and even USB flash drives.
  • A large built-in 3.5” display allows you to view, edit, and add filter effects like sepia, or B/W to the images you want to print.
  • The SELPHY Photo Layout smartphone app has been updated to v3.0 adding many features such as spool printing, a built-in printer manual, and even support for the Siri shortcut app (iOS only)
  • The SELPHY CP1500 allows you to add a QR code to the image to direct people to a web link, great for getting people to an event or wedding website.
Show more
Overview
Introducing the SELPHY CP1500 WirelessFootnote1 Compact Photo Printer, the perfect portable photo printer for printing at home and on the go. Easily print with AirPrintFootnote2, the SELPHY Layout appFootnote3, your camera memory cardFootnote4,or USB so your memories are ready to share wherever you are! Choose the right size for the right photo - from 4"x6", 2.1"x 2.1" square to mini label stickers, all made to last up to 100 yearsFootnote5 and are even water and marker resistant! Take the SELPHY CP1500 almost anywhere with the optional battery pack, and add fun effects with the updated (v3.0) SELPHY Photo Layout app, and just have a good time printing photos with your friends.
SELPHY CP1500 with Printing Tray
Take it with you
Where is the best place to print and share images of your friends? Wherever you are of course! Thanks to the optional battery NB-CP2LH which can produce up to 54 prints per charge, you can take your SELPHY CP1500 with you and print on-the-go almost anywhere!
WiFi, USB, and more, oh my!
There are so many ways to print images on the SELPHY CP1500, it’s easy to pick the one that works best for you, whether that is WiFi, AirPrint, USB (computer and USB flash drive), your camera memory card, or the SELPHY Photo Layout smartphone app.
SELPHY CP1500 Receiving Images from a Cell Phone
Instantly dry and marker ready
Thanks to the dye-sublimation printing process, the prints exit the printer completely dry and ready to handle, and with the final overcoat layer, they are even water-resistant!  That means they are also marker ready in case you want to write a personal message on your photo.  Prints produced with this technology can last up to 100 yearsFootnote4!
Picture of a Girl in a Snow Fort with "Snow Cave!" written on it
Use the free app for even more options
SELPHY Layout is the free companion app for the SELPHY printers that let you print, edit, and add fun effects right from your Smartphone.  Now updated to V3.0, the SELPHY Layout app lets you organize how you want to print your images.  You can create collages, choose which images you want to use for mini-stickers, add pattern overcoat effects, and even add QR codes to your prints to direct someone to a specific webpage.
SELPHY CP1500 Receiving Images from a Cell Phone via SELPHY Layout App
New finishing options
Most dye-sub printers can only produce glossy prints (because the final overcoat layer is glossy), but Canon has learned how to change the texture of the final print so that you can choose from glossy, semi-gloss and satin finishes.  Additionally you can Print patterns into the overcoat layer to give your images a subtle pop of texture.
3 Printed Pictures with Different Finish Options
View Full Technical Specs PDF
Printer
Printer Type
Printing Method
Dye-sublimation thermal transfer
Print Resolution
300x300 dpi, Cyan, Magenta, Yellow Film 256 levels/color (16.8 million colors)
Features
Print Features
Borderless/Bordered Printing, Bookmark Printing, 2-up fixed size print, Index Print, Reprint, QR Code Print, overcoat pattern printing, Shuffle Print
Hardware Features
3.5" LCD Screen, Wireless Printing, Anti-theft wire lock slot, 18 language support
OS Compatibility
macOS, Windows 11Footnote1
App support
Canon PRINT Inkjet/SELPHY, SELPHY Photo Layout v3.0Footnote2
Print Longevity
100 yearsFootnote3
Print Finishes
Glossy / Semi-Gloss / Satin (user selectable)
Connectivity
WiFi
compatible with 802.11 b/g (2.4 GHz), AirPrintFootnote4,Footnote5
USB
USB 2.0 Type C (USB charging not supported) for computer and flash drive
Card Slots
Direct: SD, SDHC, or SDXC
With adapter: miniSD, miniSDHC, microSD, microSDHC, micro SDXC
Power
AC Compact power adapter
Included
USB-C charging
Not Supported
Battery Pack (optional)
NB-CP2LH (sold separately) Up to 54 prints on a full charge
Dimensions, Weight
Maximum Outer Diameter x Length
Approx. 7.2" (W) x 2.3" (H) x 5.2" (D)
Weight
Approx. 1.9 Lbs
Paper and paper trays
PCPL-CP400
Postcard and L size paper cassette (Included)
PCC-CP400
Card size paper cassette (for card size printing)
Supported Paper Sizes
Postcard (4.0 x 6.0)
L Size (3.5 x 4.7)
Card Size (2.1 x 3.4)
Square Label (2.1 x 2.1)
Output tray capacity
up tp 18 sheets
Disclaimers
1. Operation can only be guaranteed on a PC with pre-installed Windows 11, latest version of macOS recommended.
2. Requires an Internet connection and the Canon PRINT Inkjet/SELPHY app or SELPHY Layout app, available for free on the App Store and at Google Play. Your device must be connected to the same working network with wireless 802.11 b/g capability as your printer.
3. Based on accelerated testing by Canon in dark storage under controlled temperature, humidity and gas conditions, simulating storage in an album with plastic sleeves. Canon cannot guarantee the longevity of prints; results may vary depending on printed image, display/storage conditions, and environmental factors.
4. Wireless printing requires a working network with wireless 802.11b/g 2.4ghz compatibility. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
5. AirPrint functionality requires an iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported.
Reviews
SELPHY CP1500 Compatible Products
Paper
Paper
Product Disclaimer
  1. Wireless printing requires a working network with wireless 802.11b/g 2.4ghz compatibility. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
  2. AirPrint functionality requires an iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported.
  3. Requires an Internet connection and the Canon PRINT Inkjet/SELPHY app or SELPHY Layout app, available for free on the App Store and at Google Play. Your device must be connected to the same working network with wireless 802.11 b/g capability as your printer.
  4. Compatible memory cards include SD™ Card, SDHC™ Card. The following can be used with the addition of a special adapter sold separately: miniSD™ Card, miniSDHC™ Card, microSD™ Card, microSDHC™ Card, microSDXC™ Card.
  5. Based on accelerated testing by Canon in dark storage under controlled temperature, humidity and gas conditions, simulating storage in an album with plastic sleeves. Canon cannot guarantee the longevity of prints; results may vary depending on printed image, display/storage conditions, and environmental factors.
