Add to Cart
SELPHY CP1500
CP1500_SWATCH
As low as $139.99
In Stock
  • The sleek and modern design of the SELPHY CP1500 is reflected in how easy it is to use even with powerful features such as Wi-Fi1 and smartphone connectivity.2
  • Thanks to a small footprint, the SELPHY CP1500 is incredibly portable, and with the optional battery pack, you can print and share your memories from just about anyplace that you go.
  • Not only will your photos look great, they will also be instantly dry and water resistant, and continue to look great for up to 100 years.3
  • Enjoy the flexibility of Wi-Fi, USB, and memory card4 connections for your SELPHY CP1500 to connect to just about anything and print from devices like your smartphone to your computer, camera, memory cards, and even USB flash drives.
  • A large built-in 3.5” display allows you to view, edit, and add filter effects like sepia, or B/W to the images you want to print.
  • The SELPHY Photo Layout smartphone app has been updated to v3.0 adding many features such as spool printing, a built-in printer manual, and even support for the Siri shortcut app (iOS only)
  • The SELPHY CP1500 allows you to add a QR code to the image to direct people to a web link, great for getting people to an event or wedding website.
Return Policy
View Full Technical Specs PDF
Printer
Printer Type
Compact Photo Printer
Printing Method
Dye-sublimation thermal transfer
Print Resolution
300x300 dpi, Cyan, Magenta, Yellow Film 256 levels/color (16.8 million colors)
Features
Print Features
Borderless/Bordered Printing, Bookmark Printing, 2-up fixed size print, Index Print, Reprint, QR Code Print, overcoat pattern printing, Shuffle Print
Hardware Features
3.5" LCD Screen, Wireless Printing, Anti-theft wire lock slot, 18 language support
OS Compatibility
macOS, Windows 111
App support
Canon PRINT Inkjet/SELPHY, SELPHY Photo Layout v3.02
Print Longevity
100 years3
Print Finishes
Glossy / Semi-Gloss / Satin (user selectable)
Connectivity
WiFi
compatible with 802.11 b/g (2.4 GHz), AirPrint4,5
USB
USB 2.0 Type C (USB charging not supported) for computer and flash drive
Card Slots
Direct: SD, SDHC, or SDXC
With adapter: miniSD, miniSDHC, microSD, microSDHC, micro SDXC
Power
AC Compact power adapter
Included
USB-C charging
Not Supported
Battery Pack (optional)
NB-CP2LH (sold separately) Up to 54 prints on a full charge
Dimensions, Weight
Maximum Outer Diameter x Length
Approx. 7.2" (W) x 2.3" (H) x 5.2" (D)
Weight
Approx. 1.9 Lbs
Paper and paper trays
PCPL-CP400
Postcard and L size paper cassette (Included)
PCC-CP400
Card size paper cassette (for card size printing)
Supported Paper Sizes
Postcard (4.0 x 6.0)
L Size (3.5 x 4.7)
Card Size (2.1 x 3.4)
Square Label (2.1 x 2.1)
Output tray capacity
up tp 18 sheets
Disclaimers
1. Operation can only be guaranteed on a PC with pre-installed Windows 11, latest version of macOS recommended.
2. Requires an Internet connection and the Canon PRINT Inkjet/SELPHY app or SELPHY Layout app, available for free on the App Store and at Google Play. Your device must be connected to the same working network with wireless 802.11 b/g capability as your printer.
3. Based on accelerated testing by Canon in dark storage under controlled temperature, humidity and gas conditions, simulating storage in an album with plastic sleeves. Canon cannot guarantee the longevity of prints; results may vary depending on printed image, display/storage conditions, and environmental factors.
4. Wireless printing requires a working network with wireless 802.11b/g 2.4ghz compatibility. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
5. AirPrint functionality requires an iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported.
Reviews
Product Disclaimer
1. Wireless printing requires a working network with wireless 802.11b/g 2.4ghz compatibility. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
2. AirPrint functionality requires an iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported.
3. Requires an Internet connection and the Canon PRINT Inkjet/SELPHY app or SELPHY Layout app, available for free on the App Store and at Google Play. Your device must be connected to the same working network with wireless 802.11 b/g capability as your printer.
 4. Compatible memory cards include SD™ Card, SDHC™ Card. The following can be used with the addition of a special adapter sold separately: miniSD™ Card, miniSDHC™ Card, microSD™ Card, microSDHC™ Card, microSDXC™ Card.
5. Based on accelerated testing by Canon in dark storage under controlled temperature, humidity and gas conditions, simulating storage in an album with plastic sleeves. Canon cannot guarantee the longevity of prints; results may vary depending on printed image, display/storage conditions, and environmental factors.
