SELPHY QX20
SELPHY_QX20_color_swatch
As low as $189.99
4 interest free payments of $47.50 with
klarna Pay Later
Paypal Pay Later
In Stock
  • Compact and portable photo printer with built-in battery and integrated paper tray.
  • Prints on Canon’s new XC-20L (2.1” x 3.4”) Card-size sticker paper as well as with the existing XS-20L (2.7” x 2.7”) Square sticker paper.
  • Connect and print directly from Android and iOS devices via easy-to-use QR code Wi-Fi connection.
  • High image quality using Dye Sublimation prints like the SELPHY QX10 including pattern overlay.
  • When printing is complete, your photos will be instantly dry, marker-ready, water resistant, and will continue to look great for up to 100 years.Footnote1
  • Charge easily and conveniently by USB-C.
  • New borderless printing optionsFootnote2.
  • The updated print engine allows for faster printing over previous models, producing a print in approximately 40 seconds.
  • Style and personalize your prints with fun filters, stickers and more using the Canon SELPHY Photo Layout v4.0 AppFootnote3.
Show more
Overview
Introducing the second generation SELPHY QX Series Square Printer, the QX20 Wireless Compact Photo Printer.  We have expanded the capability of this printer to add a new Card size sticker paper format (2.1” x 3.4”) in addition to the popular square size sticker paper  (2.7” x 2.7”) option.  This updated version maintains the compact size and 1lb weight, but in a new streamlined design, and can now print borderless on three sides, leaving an area for writing something special at the bottom.
SELPHY QX20 - On a Table with Photo Albums with Breakfast
Features
Take it With You
First and foremost, this is a compact printer, about the size of a clutch bag, and weighing around a pound, it’s easy to bring this printer along with you, and you’ll want to because printing and sharing images amongst friends with the QX20 is where it shines!  But, don’t worry, you don’t always have to be social, sitting at home working on a crafting project can be just as satisfying.
SELPHY QX20 - Person Using a Phone to Print Photos for an Album
New Printing Options!
Square shaped photo stickers are a great shape and size to share your uniqueness, but tastes and times have changed, and people are now enjoying Card-size stickers more and more, so instead of coming out with a new printer that just does Card-size printing, we updated our current printer to do both!  Wouldn’t you rather be able to decide which size you use on the spot, instead of carrying two printers?  On top of that, we added the option to print borderless on three sides (for both Square and Card-size sticker), leaving an area at the bottom for notes, captions, dates, or even autographs.
Photo Album on a Table with a Hat
Instantly Dry and Marker Ready
Thanks to the dye-sublimation printing process, the prints exit the printer completely dry and ready to handle, and with the final overcoat layer, they are even water-resistant!  That means they are also marker ready in case you want to write a personal message on your photo.  Prints produced with this technology can last up to 100 yearsFootnote1!
Flowers in a Vase Next to a Photo Collage
SELPHY QX20 - Battery Hatch Open
Print From Your Phone
The SELPHY QX20 works exclusively with the SELPHY Photo Layout (v4.0) for iOS and Android available for free on the App store or Google Play. Setup couldn’t be easier! Once you download the app, it will ask you to scan the QR code found inside the ink cassette door, and you are all set up and ready to print! Up to six devices can connect to the QX20 at a time.
High-Quality
One of the best features of dye-sublimation printing is the quality and longevity of the prints. Color gradations like you would see in the sky or skin tones are smooth as can be, and colors are more accurate than other portable printing methods.  Just because your prints are small does not mean they shouldn’t look good!
SELPHY QX20 - Printing a Photo
SELPHY QX20 - Different Print Mediums
Customize!
Let’s face it, this printer is about showing off your personality, and what better way to do that than to dress up your images? With the SELPHY Photo Layout software v4.0 you have a ton of creative options from adding Stamps, Frames, and Overlays to your photos to creating collages! You can even create works of art that you can send directly to your friends if they want to print their own copy.
USB-C Charging
The QX20 has a built-in battery that is easily recharged via a standard USB-C charging port
(USB-C cable provided, charger not included).
SELPHY QX20 - Charging Port
View Full Technical Specs PDF
Printer
Printer Type
Printing Method
Dye-sublimation thermal transfer
Print Resolution
287x287 dpi, Cyan, Magenta, Yellow Film 256 shades/color (16.8 million colors)
Features
Print Features
Square Size (2.7" x 2.7") and Card Size (2.1x3.4) Paper Options, Borderless (on 3 sides)/Bordered Printing, Pattern Overlay
Hardware Features
Built-in rechargable battery, integrated paper try, USB-C charging
App support
SELPHY Photo Layout v4.0 or later Footnote1
Print Longevity
100 years Footnote2
Compatible Paper and Ink Sets
XS-20L
Square Format Sticker Paper
(20 sheets. Two packs of 10 sheets of paper / one ink cassette)
XC-20L
Card Format Sticker Paper
XC-60L
Card Format Sticker Paper Bulk Pack
(60 sheets. Six packs of 10 sheets of paper / Three ink cassettes)
Connectivity
WiFi3
Compatible with 802.11 b/g (2.4 GHz), Direct Connection
OS Compatibility
iOS, Android
USB Terminal
Provided - USB Type C Port (for charging only)
Card Slots
Not Supported
Power
USB-C charging
Supported*
Battery
Built-in (Not user replaceable)
Charging Cable
Provided USB Type C (C to C)
Power Adapter
Not Included
Dimensions, Weight
Maximum Outer Diameter x Length
Approx. 4.0" (W) x 1.3" (H) x 5.7" (D)
Weight
Approx. 16 oz. / 1.0 lb
Reviews
SELPHY QX20 Compatible Products
Paper
Paper
Product Disclaimer
  1. Based on accelerated testing by Canon in dark storage under controlled temperature, humidity and gas conditions, simulating storage in an album with plastic sleeves. Canon cannot guarantee the longevity of prints; results may vary depending on printed image, display/storage conditions, and environmental factors.
  2. Borderless refers to the border on three sides.
  3. Requires an Internet connection and the Canon SELPHY Photo Layout app, available for free on the App Store and at Google Play.
