Speedlite EL-1 Ver. 2
7288C002
Special Price $1,049.00 Regular Price $1,249.00
Buy now and pay later with
klarna Pay Later
Paypal Pay Later
In Stock
  • Maximum Guide Number of 190 Ft./58m at ISO 100 Zoom Flash Head with Wide Range of 24-200mm.
  • Rechargeable Li-Ion Battery Utilizing LC-E6 Battery Charger.
  • Improved Recycling Time (0.9 Sec.)Footnote1 and Number Of Flashes (340 Times)Footnote2
  • Active Cooling System Enabling Longer Operation and Improved Thermal Management.Footnote3
  • More Versatility with Minimal Power Output Range 1/8192
  • Simple User Interface with New Joystick, Display and Control Layout
Show more
Where to Buy
Overview
The Next Generation All-Purpose Flash.
The Speedlite EL-1 (ver. 2) is the next generation, all-purpose flash that professionals and advanced amateurs have been seeking, providing durability, reliability and a range of power that opens up a number of possibilities. The new Xenon flash tube offers increased stability for flash output and 14 f-stops of total flash exposure range allowing you to shoot anywhere from a bright 1/1 to a dim, low power 1/8192 to precisely sculpt your scene with light.
As part of the EOS VR System — this lens paired with the EOS R5 updated with firmware 1.5.0 or higher and one of Canon's VR software solutions - you can create immersive 3D that can be experienced when viewed on compatible head mount displays including the Oculus Quest 2 and more.* Viewers will be able to take in the scene with a vivid, wide degree field of view by simply moving their head. This is the world's first digital interchangeable lens that can capture stereoscopic 3D 180° VR imagery to a single image sensor.*^ Now, creators can go from traditional stills or video shooting to stereoscopic 3D capture with a simple lens swap. The pairing of this lens and the EOS R5 camera brings high resolution video recording at up to 8K DCI 30p and 4K DCI 60p. With a beautifully engineered folded optical design, the dual high-performance L-series fisheye lenses combine imagery onto a single image sensor delivering impressive results to a single file. This can help simplify your workflow by eliminating the need to sync and stitch multiple video files. An integral part of the EOS VR System, Canon's EOS VR Utility software can easily convert footage to your choice of editing software. For Adobe® Premiere Pro® users, the EOS VR Plug-in software can help streamline your editing process. Both paid subscription-based software solutions (currently in development with availability and details to follow on or about early 2022) allow for convenient post-production.
With this lens paired with an EOS R5 camera, creatives, industry professionals and newcomers to VR can create an immersive experience, capturing dynamic scenes for entertainment, tourism, training & education, real estate, storytelling or anywhere you want to bring your audience to.
Speedlite EL-1 on a black background
The Speedlite EL-1 (ver. 2) has a maximum guide number of 190 ft. (58m) at ISO 100 to provide you the versatile lighting you desire for flash photography in a variety of situations, such as outdoor weddings, portraits, and low light scenarios during indoor events. It offers a wide range of 24mm to 200mm flash coverage to match popular 24-105mm, and 70-200mm lenses, and can even be used with lenses as wide as 14mm with use of the extendable 14mm wide-panel. To maximize power, and make the flash user-friendly, the Speedlite EL-1 (ver. 2) automatically zooms with the focal length of your lens from 24-200mm in accordance with your camera's sensor (Full-frame or APS-C) , or a manual setting can be selected for manual control.
portrait of a couple in front of city skyline
New Rechargeable Li-Ion Battery Utilizing LC-E6 Battery Charger
Improved performance and convenience are the results of the new compact and rechargeable Li-ion Battery Pack LP-EL. It delivers the power and reliability needed when shooting any situation, especially weddings or photojournalism opportunities when a moment can be once-in-a-lifetime, so you can feel confident in the flash recycle performance when shooting a series of images for extended periods of time. You can even view the remaining battery level in the top right display of the Speedlite EL-1 (ver. 2), letting you know just how long you can go or when it's time to recharge with the LC-E6 battery charger.
Improved Recycling Time (0.9 Sec.) and Number Of Flashes (340 Times)
Additional benefits of the new rechargeable Li-ion Battery in the Speedlite EL-1 (ver. 2) is the speed at which the flash recycles so you can utilize it back to back repetitively, one flash after another. With an approx. recycle time of 0.9 sec. (approx. 6x faster than the 600EX II-RT when the 600EX II-RT is used with AA/LR6 alkaline batteries) you will find improved consistency and less underexposed black frames, when the opportunity presents itself. The improved power of the rechargeable Li-ion Battery is also evidenced by the number of times you can fire the flash when fully charged, up to 340 times (approx. 3x longer than the 600EX II-RT when the 600EX II-RT is used with AA/LR6 alkaline batteries) before having to recharge or simply swapping out for another LP-EL battery.
bride and groom
New Active Cooling System Enabling Longer Operation
An active cooling system helps circulate air throughout the flash head to keep it cool when firing continuously for longer periods of time, using a fan and glass panel to improve heat resistance. This cooling system lets you keep firing the flash for approx. 170 continuous shotsFootnote3, while also not impairing the dust- and water-resistance of the Speedlite EL-1 (ver. 2).
cooling system diagram
A high-durability Xenon-filled glass flash tube helps the Speedlite EL-1 (ver. 2) fire more effectively and efficiently.
portrait of a woman in a red dress at night
The Speedlite EL-1 (ver. 2) has a wide 14-stop exposure range from 1/1 to 1/8192 to greatly expand the levels of versatility in flash output from brightest to dimmest. This means you're better equipped to capture all sorts of expression whether it's at close range like portraits, further away, or even balancing flash with dimly lit scenes where many existing flashes are too bright to obtain proper exposure.
portrait of a woman at night
Improved User Interface with New Joystick, Display and Control Layout
Equipped with an intuitive button layout and dial, the Speedlite EL-1 (ver. 2) also features a joystick that allows you to cycle through and select various settings, and work more effectively and quickly. When working under pressure or in dimly lit situations, the Speedlite EL-1 (ver. 2) also has an illuminated display to show relevant shooting information at a glance – both when the flash is in use or on standby, for fast and easy reference. Additionally, you can control your Speedlite quickly by setting your flash menu to a button, and with the FE memory function, you can even have the Speedlite EL-1 (ver. 2) take note of flash settings for specific scenes so you can easily recall the configurations if shooting the same scene or similar scene repeatedly, or after taking a prolonged break and re-visiting, without having to manually set everything all over again.
back of the speedlite el-1
LED Modeling Lamp with Adjustable Brightness and Color Temperature
When setting up your shots, you can utilize the two color LED modeling lamps on the Speedlite EL-1 (ver. 2). These two lamps can help you ascertain the coverage and direction of light to get the results you want prior to shooting, and are also adjustable in brightness and color temperature when working in a dark studio. Each modeling lamp automatically turns off during release.
close-up of the speedlite el-1
Same Dust- and Water-Resistance as EOS-1D Series and a New High-Durability Glass Flash Tube
The Speedlite EL-1 (ver. 2) is designed to maintain the high standard of dust- and water-resistant performance found on Canon's EOS-1D series of cameras. Its exterior seams are sealed to help maintain airtightness, while a dust- and water-resistant adapter mounted to the bottom of the flash surrounds and locks around the camera's hot shoe for a nearly impenetrable seal. By maintaining the overall weather-resistant surface of the EOS-1D series, the Speedlite EL-1 (ver. 2) can bring flash photography to more places, in more environments, without compromise.
speedlite el-1 with water droplets on it
Support of RT Series Flash Products and Wireless Second-Curtain Sync
Radio wireless transmission means the Speedlite EL-1 (ver. 2) can be used to support off-camera shooting in a number of ways, including multiple flash shooting, with the use of up to 15 RT Series receiver Speedlites to produce light freely even when not attached to the camera. It also has Second-Curtain Sync for those amazing ambient light trails following your subject for even more creative possibilities.
The following flashes support radio transmission wireless second-curtain sync as receivers: 600EX II-RT, 600EX-RT, 430EX III-RT.
portrait of a bride in a church
Full Swivel 180° with Bounce Up To 120°, Built-in Catch Light Panel and Wide Panel
The Speedlite EL-1 (ver. 2)'s flash head is designed for easy bounce flash, in any direction. The head can now be angled 120° up, 7° down and can rotate 180° left and right. A bounce lock with release button helps things stay in place. Additionally, the Speedlite EL-1 (ver. 2) features a catchlight panel to create catchlights in the eyes of the subject for a more expressive look.
speedlite el-1 on black background
Bounce Adapter and Two Color Filters Included
The Speedlite EL-1 (ver. 2) is bundled with key accessories designed to help position, diffuse and tone its output for optimal results. The Bounce Adapter SBA-EL widens and diffuses bounce lighting, achieving a soft effect especially in shadow areas. The SCF color hard-type filter sets include the Color Filter SCF-ELOR1, which is effective in merging ambient incandescent light with the flash's bluish output to create a warm mood, and the Color Filter SCF- ELOR2, useful for balancing the flash output with incandescent lighting found in interior lighting, for more natural, realistic light. Both filters attach and detach with ease for quick and smooth set-up. The Speedlite EL-1 (ver. 2) is also bundled with a soft case that is designed not only to hold all its flash accessories, but can also store the flash unit with the filter attached and has a belt loop for speedy access on the go.
speedlite el-1 accessories
CP-E4N Battery Pack Compatible and Optional Accessories
Additional external power sources are supported with the Speedlite EL-1 (ver. 2), such as the optional Compact Battery Pack CP-E4N. When used, the CP-E4N battery pack can help reduce the recharge time to 0.6 sec. (with AA/LR6 alkaline batteries), or 0.4 sec. (with AA/LR6 Ni-MH batteries) when shooting 1/1 full power consecutively, and increases the maximum flash count to approx. 560 times (with AA/LR6 alkaline batteries) and 680 times (with AA/LR6 Ni-MH batteries) based on Canon testing.
View Full Technical Specs PDF
Flash
Modeling Lamp
Wireless Functions for Radio Transmission
Wireless functions for Optical Transmission
Linked Shootting via Radio Transmission
Information Display
General
Functions
Product Disclaimer
  1. 0.9 sec: recycling time when flash is set to Manual Mode, 1/1, Full-power flash.
  2. 340 cycles when flash is set to Manual Mode, 1/1 Full-power flash.
  3. At 73°F, with the fan set to ON, and before reaching flash firing restriction Level 1, with no flash adapters fitted (bursts up to 160 full power flashes with the flash zoomed from 150-200mm).
