UHD-DIGISUPER 111
UJ111X83B
As low as $191,000.00
Out Of Stock
  • NEW! An optical unit (sold separately) can be installed for shooting captivating images with shallow depth of field
  • 111x Optical zoom lens (925mm) with an impressive wide angle (8.3mm);
  • Advanced optical performance to support 4K cameras
  • Ideal for HDR image capture
  • Optimized for 4K production
  • Advanced image stabilization performance in 4K
  • Minimized focus breathing with Constant Angle Focus System (CAFS)
  • Support for virtual systems
Show more
Overview
The UHD-DIGISUPER 111 is an innovative HDTV studio lens that offers an important choice of studio system configuration.
Our new, 4K Premium UHD-DIGISUPER 111 (UJ111x8.3B) broadcast lens features a 111x zoom, delivering an outstanding 925mm on the telephoto end (1850mm with the built-in 2x extender), and an impressive 8.3mm wide setting making it ideal for use in a wide range of in 4K UHD outside broadcast television productions.
UHD-DIGISUPER 111
Designed to support 4K UHD systems, the 4K UHD-DIGISUPER 111 uses advanced design technologies, optical components and manufacturing processes to produce a lens with an extremely high overall optical performance that exceeds basic 4K criteria. Output video image performance is maximized when used with 4K UHD cameras. The lens embodies state of the art optomechanical and electronic advances, designed to capture HDR-compatible high-contrast 4K imagery and exceed the expectations of the world’s outside broadcast television operators.
Features
The primary technologies that form the underpinnings of Canon's larger HD studio lenses have all been preserved in this new compact UHD-DIGISUPER 111 and they include:
A new optical unit (sold separately) can be added to the UHD-DIGISUPER 111 by Canon Service. Benefits of the optical unit include:
• Beautiful fall off from foreground to background without sacrificing resolution​
• Easy focusing even in fast aperture​
• Same color balance as the current UHD-DIGISUPER 111
• Can be shot with regular broadcast system and operation​
• Switchable between 1x standard, 1x Novel Look and 2x extender in a single lens​
• Covers a long focal length that larger format lenses cannot cover
Difference of the focusing range between UJ111x standard and Novel Look
111x Optical Zoom Lens (925mm) with an Impressive Wide Angle (8.3mm)
The UHD-DIGISUPER 111 features 925mm on the telephoto end (1850mm with the built-in 2x extender), making it ideal for shooting live sports, nature, concerts, live events and other applications where focal length on the telephoto end is prioritized. Combined with an impressive 8.3mm wide setting, the UHD-DIGISUPER 111 broadcast lens is ideal for a wide range of in 4K UHD outside broadcast television productions.
uhd
Superb Image Framing Options
The lens can maintain full 4K overall optical image quality over the full 8.3mm to 925mm range, offering superb image framing options for all forms of outside broadcast television productions. The extensive framing latitude can dramatically capture all possible on-site sensations - from the emotion of an entire crowded stadium to other emotions expressed in the close-ups of facial expressions of individual players on the field.
comparison charts
Outstanding Optical Performance for 4K Cameras
The UHD-DIGISUPER 111 broadcast lens was built using our exclusive optical design technology, helping ensure consistent 4K resolving power and high contrast from the center of the screen to the periphery, maintaining 4K optical performance even when the 2x extender is deployed.
An integrated multi-group movable zoom system can control at points with major fluctuations in optical performance during zooming (wide middle, tele middle), working to maintain optical performance throughout the entire zoom range from the center of the image to the edges. In addition, integrated floating focus system helps reduce changes in aberrations when focusing to different object distances, while maintaining 4K optical performance in color reproduction over the entire focus range, especially on the telephoto side.
uhd
Outstanding 4K Imagery
The lens also features a combination of the latest materials, contemporary optical design, and multi-layer coatings to produce outstanding 4K imagery. This helps lower the monochromatic and chromatic optical aberrations to a level consistent with the highest quality 4K portrayal on large screens, allowing 4K cameras to reach their potential and deliver performance in live sports such as baseball, soccer and golf.
goalkeeper celebrating
Minimized Chromatic Aberration
uhd
Reduced Ghosting and Flare
Special coatings and an internal lens barrel designed to prevent reflection result in minimized ghosting and flaring, allowing users to take high-tonality images to support HDR. The UHD-DIGISUPER 111 is the first broadcast lens to feature Canon's Air Sphere Coating (ASC), which combines vapor-deposited multi-layer coatings with an ultra-low refractive index outermost layer. The lens coatings help to control the reflection on the lens barrel’s inner surface, helping suppress ghosting and flaring, resulting in HDR-compatible high-contrast imagery.
uhd
BT.2020 Support
The lens also features correction data that supports BT.2020, enabling excellent color reproduction to the corners of the screen when attached to a 4K camera.
UHD-DIGISUPER 111
Ideal for HDR Image Capture
HDR images offer excellent gradation representation and enhanced realism and dimension including texture for image representation close to the real thing. However, there can be noticeable color bleeding and flare, so HDR shooting requires high optical performance. Thanks to our exclusive optical design technology and Canon's Air Sphere Coating (ASC), the UHD-DIGISUPER 111 delivers the advanced optical performance that Canon considers essential for an HDR system lens, enabling the capture of more realistic imagery.
UHD-DIGISUPER 111
Optimized for 4K Production
Great consideration was given to the requisite precision mounting of all optical elements required to maintain full 4K performance over the extended focal range of the UHD-DIGISUPER 111 broadcast lens. Maintaining precision focus tracking over that long zoom rage was a central design priority. Digital servo speed has been optimized to meet the many operational requirements that support creative coverage of sporting events. Advanced, contemporary optomechanical design strategies were used to produce an overall lens size that contributes to its operational ease.
Dependable Image Stabilization Performance in 4K
Shooting in 4K is demanding - even the slightest vibration can greatly impact image quality. The UHD-DIGISUPER 111 employs Canon's optical and servo technologies to help ensure 4K performance from wide angle to telephoto even when using Image Stabilization (IS).
uhd
High Vibration Reduction Rates
The UHD-DIGISUPER 111 broadcast lens can achieve high vibration reduction rates in higher frequency bands (with excellent performance at the telephoto end) and stable operation even when panning.
uhd
Bokeh Effect
When shooting in macro, the focus position of the UHD-DIGISUPER 111 can be changed as the focal length is adjusted, when using the optional MCJ-S02 Macro Controller. This built-in feature can be utilized to support special techniques in which the focus position can be shifted within the same shot just by using the Macro Controller, allowing for subtle creative defocus effects. This can help provide a degree of creativity when shooting live events such as a concert.
uhd
Constant Angle Focus System (CAFS) Minimizes Focus Breathing
This function brings changes in angle of view due to focusing ("breathing") down to near zero. It functions by counteracting the zoom effect by the focus group movement to cancel out the effect on the angle of view.
uhd
Support for Virtual Systems
The UHD-DIGISUPER 111 broadcast lens utilizes the same standard controllers for zoom and focus operations that have been optimized by Canon over decades. The lens also uses the standard Canon 20-pin connector that provides an interface for the digital precision positional information of the zoom, focus, and iris operations required by many external virtual systems. The positional data is internally created by high precision digital encoders.
UHD-DIGISUPER 111
Standardized Lens Controllers
cast lens offers compatibility with HD demands used for broadcasting. Operators can continue using the zoom/focus motorized accessories and servo models they currently use with HD equipment, as well as Canon’s new ZDJ-S01 Zoom Demand and FDJ-S01 Focus Demand. These new zoom and focus demands are equipped with the flexibility necessary to meet the new and diverse user needs when shooting in 4K, while offering simple operability in a compact design.
UHD-DIGISUPER 111
New Streamlined Ergonomic Design
The UHD-DIGISUPER 111 is designed to satisfy professionals with its high-level combination of excellent specifications, enhanced optical performance, and outstanding usability. Featuring an ergonomic design consistent with our other 4K Premium lenses, the lens includes an integrated cover with an evolved version of the flowing L motion design, and a lens cover handle that extends to the front lens side to improve operability in shooting settings.
The UHD-DIGISUPER 111 was constructed with an on-board information display, enabling various function settings and adjustments when the lens cover is removed.
UHD-DIGISUPER 111
Compact and Lightweight
Weighing 58.6 lbs. and measuring 9.9" (W) x 10.1" (H) x 25.1" (L), the UHD-DIGISUPER 111 broadcast lens offers similar mobility and shooting style similar to our DIGISUPER 95 (XJ95x8.6B) 2/3” HD lens, while keeping the improvements in magnification and 4K performance.
UHD-DIGISUPER 111
Main Unit Spec
Informational Documents
File Name
Broadcast & Cinema Lens Catalog - Spring 2026
Date
04.15.26
File Size
44.6 MB
UHD-DIGISUPER 111 Compatible Products
Lens Accessories
Lens Accessories
