UHD-DIGISUPER 27
UJ27X SB
As low as $96,720.00
Out Of Stock
  • Optical Performance Exceeding 4K Resolution
  • High Dynamic Range (HDR) Performance
  • 16-bit Output Supporting Virtual Systems
  • Compatible with HD Lens Systems
Show more
Overview
Our flagship 2/3-inch format studio lens
The UHD-DIGISUPER 27 (UJ27×6.5B) studio lens is our flagship 2/3-inch format studio lens, featuring outstanding optical performance beyond 4K resolution with a 27x zoom ratio (6.5mm to 180mm) and wide angle focal length (6.5mm at 1×, 13mm at 2×).
A variety of Canon’s advanced optical design technologies combine to produce a lens that delivers both 4K resolution and color reproduction uniformly from the center of the screen to the corners. The lens also features reduced chromatic aberration and ghosting compared to previous models.
uhd digisuper 27 3q angle
Features
Optical Performance that Exceeds 4K Resolution
The most advanced computer simulation design techniques, deployment of new glass materials and optical coatings, and new precision optomechanical design strategies form the underpinnings of the outstanding overall optical performance of the UHD-DIGISUPER 27 (UJ27x6.5B) – achieving beyond 4K resolution even when the built-in 2x extender is engaged. These proprietary design strategies deliver exceptional 4K image sharpness and a very high contrast across the entire image plane and across the visible wavelength spectrum.
uhd
Ideal for HDR Image Capture
Recognizing the new importance of High Dynamic Range (HDR) to enhancing the overall image performance of both UHD and HD, the lens has been designed with proprietary coating and anti-reflection materials to precisely manage internal light reflections and to better suppress unintended ghosting and flare. This helps produce superb contrast and color reproduction of nominally exposed images, enhanced reproduction of scene speculars, and tight control over spurious effects of extreme scene highlights.
uhd
Stable Servo Performance
A 2/3-inch 4K acquisition system can result in a narrower depth-of-field than an equivalent HD system, making achievement of accurate focus more critical. To help alleviate this challenge, the operation of the focusing system within the lens has been improved compared to previous models, which aids operational tracking of focus on selected scene objects even when fast zooming is also engaged.
uhd
16 bit Output to Support Various Virtual Systems
The lens is equipped with 16-bit optical rotary encoders to output highly precise positional data of zoom, focus and iris on a 20-pin connector for direct digital interface to robotic and virtual studio systems.
uhd
Compatible with Existing Lens Controllers
The lens utilizes the same standard controllers for zoom and focus operations that have been optimized over decades of Canon HDTV field lens developments. Similar in size and weight to our 2/3” HD lenses, the UHD-DIGISUPER 27 allows for the same shooting style.
uhd
Main Unit Spec
Informational Documents
File Name
Broadcast & Cinema Lens Catalog - Spring 2026
Date
04.15.26
File Size
44.6 MB
UHD-DIGISUPER 27 Compatible Products
Lens Accessories
Lens Accessories
