varioPRINT 140 Series
$0.00
Monochrome production digital press featuring innovative technology that delivers sustainable productivity
- Up to 140/130/115 ipm
- Duty cycle of up to 2.2 million impressions per month
- Outstanding image quality and consistency
- White paper in, finished product out versatility
- DirectPress Technology delivers ozone-free printing with virtually no toner waste
Digital Printing White Paper Series LEARN MORE
View Full Technical Specs PDF
Techs. Specs. Detailed PDF
varioPRINT 140/130/115 |
MAIN ENGINE | |||
TECHNOLOGY | DirectPress | ||
RESOLUTION | Up to 600 x 2400 dpi | ||
PRINT SPEED (SIMPLEX / DUPLEX) | |||
vP140
vP130
vP115
8.5" x 11" | Up to 140 ipm | Up to 130 ipm | Up to 115 ipm |
11" x 17" | Up to 73 ipm | Up to 68 ipm | Up to 60 ipm |
PAPER SIZE | 5.5" x 7.17" to 12.6" x 19.2" | ||
PAPER FEEDING | |||
STANDARD | Up to 4,000 Sheets (20 lb. Bond) | ||
MAXIMUM | Up to 12,000 Sheets (20 lb. Bond)* | ||
PAPER WEIGHT | 13 lb. Bond to 110 lb. Cover* (50 gsm to 300 gsm) | ||
DUPLEXING | Automatic Duplex Any Supported Stock | ||
POWER SOURCE | 208 V/20 A | ||
DIMENSIONS (H x W x D) | 56.3" x 44.5" x 30.1"(Includes operator panel) | ||
INPUT ACCESSORIES | |||
ePIM (External Paper Input Module) | |||
PAPER CAPACITY | Up to 4,600 Sheets (20 lb. Bond) | ||
MAXIMUM CAPACITY | Up to 8,000 Sheets (20 lb. Bond)* | ||
PAPER SIZE | 8” x 8” to 12.6” x 19.2” | ||
PAPER WEIGHT | 13 lb. Bond to 110 lb. Cover (50 gsm to 300 gsm) | ||
DIMENSIONS (H x W x D) | 41.6" x 38.9" x 29.3" | ||
POWER SOURCE | 120 V/15 A | ||
DUPLEX COLOR IMAGE READER-L1** |
IMAGE SENSOR | CCD | ||
DOCUMENT SIZE | Statement to 11" x 17" | ||
RESOLUTION | Up to 600 x 600 dpi | ||
TRAY CAPACITY | Up 300 Sheets (20 lb. Bond) | ||
SCAN SPEED | |||
BW/COLOR: | Up to 120 ipm (300 x 300 dpi) | ||
BW: | Up to 108 ipm (600 x 600 dpi) | ||
COLOR: | Up to 120 ipm (600 x 300 dpi) Up to 25 ipm (600 x 600 dpi) |
FINISHING ACCESSORIES | |||
MULTIFUNCTION PROFESSIONAL PUNCHER-B1 | |||
PAPER WEIGHT | |||
PLAIN | 20 lb. Bond to 110 lb. Cover(75 gsm to 300 gsm) | ||
COATED | 20 lb. Bond to 110 lb. Cover(80 gsm to 300 gsm) | ||
PAPER SIZE | 12" x 18", 11" x 17", LTR, LGL, LTR-R, STMT | ||
DIE SET PATTERNS | Loose Leaf 3-Hole/5-Hole, Velo Bind, 11-Hole, Plastic Comb 19-Hole, Twin Loop, 21-Hole/32-Hole, Color Coil 44-Hole | ||
DIMENSIONS (H x W x D) | 40.9" x 17.5." x 31.2" | ||
POWER SUPPLY | 120 V/15 A | ||
HIGH-CAPACITY STACKER-H1 | |||
OFFSET STACK CAPACITY | Up to 6,000 Sheets (20 lb. Bond) | ||
TOP TRAY CAPACITY | Up to 200 Sheets (20 lb. Bond) | ||
PAPER SIZE | 7.2" x 7.2" to 13" x 19.2" | ||
PAPER WEIGHT | 14 lb. Bond to 110 lb. Cover(52 gsm to 300 gsm) | ||
MAX. CONNECTIVITY | 1 Unit | ||
DIMENSIONS (H x W x D) | 40.9" x 35.4" x 29.3" | ||
STAPLE FINISHER-W1 / BOOKLET FINISHER-W1 | |||
TRAY CAPACITY | |||
TOP TRAY | Up to 1,000 Sheets (20 lb. Bond) | ||
LOWER TRAY | Up to 4,000 Sheets (20 lb. Bond) | ||
SADDLE-STITCH TRAY | Up to 30 Booklets or Limitless | ||
STAPLE POSITIONS | Corner Stapling, Double Stapling | ||
PAPER WEIGHT | 14 lb. Cover to 110 lb. Cover(52 gsm to 300 gsm) | ||
PAPER SIZE | |||
STAPLING | 11" x 17", LGL, LTR-R, EXEC, LTR,12" x 18", 13" x 19.2", Custom Size(8.3" x 11" to 13" x 19.2") | ||
SADDLE FINISHER | 11" x 17", LGL, LTR-R, 12" x 18",13" x 19", Custom Size (8.3" x 11" to 13" x 19.2") | ||
STAPLING CAPACITY | Up to 100 Sheets | ||
BOOKLET STAPLING CAPACITY (20 LB. BOND) | |||
UNCOATED | Up to 25 Sheets | ||
COATED | Up to 10 Sheets | ||
V-FOLDING | Up to 5 Sheets without Stitch | ||
DIMENSIONS (H x W x D) | |||
STAPLE FINISHER | 48.8" x 35.0" x 31.2" | ||
BOOKLET FINISHER | 48.8" x 41.7" x 31.2" | ||
BOOKLET TRIMMER-F1▲ | |||
MARGIN TRIMMING | Front-edge Trim | ||
TRIM AMOUNT | 0.08" to 1.1" | ||
TRIM THICKNESS | 50 Sheets | ||
OUTPUT TRAY CAPACITY | 30 Booklets | ||
DIMENSIONS (H x W x D) | 40.9" x 62.1" x 30.3" | ||
TWO-KNIFE BOOKLET TRIMMER-A1▲▲ | |||
MARGIN TRIMMING | Top and Bottom | ||
TRIM AMOUNT | 0.08" to 0.59" | ||
DIMENSIONS (H x W x D) | 40.9" x 21.1" x 30.3" | ||
PUNCHER UNIT-BS1 (OPTION FOR STAPLE FINISHER-W1 / BOOKLET FINISHER-W1 | |||
PAPER SIZES | |||
2-Hole | Legal, Letter-R, Custom Size(7.2" x 7.2" to 11.7" x 17") | ||
3-Hole | 11" x 17", Letter, Executive-R, Custom Size (9.4" x 7.2" to 11.7" x 17") | ||
DOCUMENT INSERTION UNIT-N1 | |||
TRAY CAPACITY | |||
UPPER TRAY | Up to 200 Sheets (20 lb. Bond) | ||
LOWER TRAY | Up to 200 Sheets (20 lb. Bond) | ||
PAPER SIZE | 11" x 17", 12" x 18", 13" x 19", LGL, LTR, LTR-R, EXEC, Custom Size (7.2" x 7.2" to 13" x 19.2") | ||
PAPER FOLDING UNIT-J1 | |||
DOUBLE PARALLEL FOLD | Legal, Letter-R | ||
C/ACCORDION FOLD | Letter-R | ||
Z-FOLD | 11" x 17" | ||
HALF-FOLD | Letter-R | ||
SUPPORTED MEDIA WEIGHTS | 14 lb. Bond to 28 lb. Bond(50 gsm to 105 gsm) | ||
POWER SOURCE | From Finisher | ||
DIMENSIONS (H x W x D) | 46.87" x 13.25" x 31.25" | ||
WEIGHT | 157 lb. (71 kg) | ||
CONSUMABLES | |||
TONER | Canon varioPRINT DP Toner | ||
FOOTNOTES | |||
* With ePIM and two Duo Tray options installed ** Included in MFP model. ▲ Must connect to Booklet Finisher-W1. ▲ ▲ Must connect to Booklet Trimmer-F1. |
Product Disclaimer
Prices and specifications subject to change without notice. Actual prices are determined by individual dealers and may vary.
