varioPRINT 140 series QUARTZ
As low as $0.00
Out Of Stock
  • Print speeds up to 140 letter ppm
  • Support of media up to 12.6" x 19.2" and 110 lb. cover
  • HeatXChange reuses heat to cut energy usage and paper curling
Printer Overview
Performance Throughout
Designed for small-to-medium size commercial, quick printers, franchise, and in-plants, the varioPRINT 140 series QUARTZ monochrome digital presses deliver productivity via configurable workflow, minimal waste, and print speeds up to 140 images per minute. Supporting a range of media from 13lb Bond to 110 lb. Cover (50-300 gsm) these presses can be configured to your production requirements, from scanning to copying to full in-line production.
SOLUTIONS
FOR
EVERY
WORKSPACE
SOLUTIONS
FOR
EVERY
WORKSPACE
varioPRINT 140 Series QUARTZ
PERFORMANCE
Increased Uptime, Reliable Performance
DirectPress technology improves image consistency while helping to reduce maintenance and increase reliability and system uptime. PRISMAsync offers intelligent job scheduling for uninterrupted production and smooth workload planning. The Job Scheduler provides up to eight hours of production planning, allowing the operator to monitor multiple jobs, receive custom notifications and change priorities. For optimal productivity, operators can leverage PRISMAremote Manager, a dynamic web-based multipress tool featuring a scalable and dynamic user interface.
image of the varioPRINT 140 series QUARTZ
Internal mechanism of printer
Impressive Productivity
EnergyLogic technology helps increase productivity. EnergyLogic’s intelligent response to media keeps the engine running, even as it heats or cools to adjust for media weight, providing non-stop production for mixed media jobs. This intelligent use of energy results in maximum performance without sacrificing quality and delivers a fast first print out time.
Directpress toner image
Consistent Quality
Directpress technology converts digital data to a toner image in a single step, with no ozone emissions, fuser oil, or developer, and virtually no toner waste. This allows for consistent quality across runs with high-quality printing on a wide range of media across jobs, systems, and time.
image of PRISMAsync on computer
Configurable Workflow Support
The PRISMAsync Print Server’s integrated user interface combines the functionality of a digital front-end with the engine controller. The result is simplified production steps for even the most complex jobs, thereby helping to reduce training time and increasing productivity. Remote management tools plus seamless integration with Canon’s optional PRISMA software suite can help accelerate workflow, reduce costs and attract more print volume.
Clean, Sustainable, and Ozone Free
The streamlined printing process — with no electrical charge used — provides a cleaner work environment, without ozone emissions, selenium, fuser oil or developer, and virtually no toner waste or particle emissions. HeatXchange technology cleverly reuses heat used in the fusing process and DirectPress technology's low-fusing temperature allows the press to run cooler, helping reduce energy consumption.
Image Alt Text
varioPRINT 140 series QUARTZS Demo
SIMPLIFY WORKFLOW, EMPOWER YOUR TEAM
The PRISMAsync family of print servers helps streamline production by making printing operations more intuitive and uniform. Managing and running jobs through multiple presses more easily than ever before. Plan-ahead up to 8 hours of production with the Job Scheduler. The intuitive interface helps operators easily manage jobs from composition to media to production to finishing—even those inevitable last-minute changes. PRISMAremote Manager features a dynamic user interface that allows Apps to be dragged, dropped and scaled to create a customized view with only the information your operators require!
PRISMA Workflow Solutions
PRISMA is Canon's family of workflow solutions designed to help optimize your print operation while positioning you for further growth. PRISMA workflow solutions include on-premise and cloud-based solutions to simplify job submission, accelerate document preparation, facilitate order and production management as well as tools designed to help support performance monitoring, cost allocation and color management.
WHITE PAPER IN-FINISHED PRODUCT OUT
Keep more jobs in house-and with less effort-by selecting from an extensive array of Canon and third-party in-line finishing options that offer punching. Wire-binding, booklet-making, and trimming. Inline feeding and finishing options are essential for print environments to achieve maximum versatility and flexibility when producing high-quality, professional print applications including brochures, manuals, reports, and books, among other materials.
Image Alt Text
View Full Technical Specs PDF
Main Unit Specs
Print Speed (Duplex)
Letter: Up to 140 ipm
11" x 17": Up to 73 ipm
Monthly Duty Cycle
Up to 2.3 Million
Print Resolution
dpi: 600 x 2400
lpi: 200
Paper Capacity
Standard: Up to 4,000 Sheets
MaximumFootnote2: Up to 12,000 Sheets
Paper Size
StandardFootnote3: 5.5" x 7.17" to 12.6" x 19.2"
Paper Weight
StandardFootnote4: 13 lb. Bond to 110 lb. Cover
Resources
File Name
Canon varioPRINT 140 series Quartz Brochure
Date
04.13.26
File Size
7 MB
File Name
PRISMAsync Brochure 2026
Date
10.30.26
File Size
9.1 MB
File Name
Canon varioPRINT 140 series Quartz Spec Sheet
Date
03.02.26
File Size
9.1 MB
Sort By:
varioPRINT 140 series QUARTZ Demo
Untitle Video
Capturing superior black-and-white prints shouldn’t be a convoluted process. With the reliability of a performance-driven press engineered to help maximize efficiency and flexibility on a wide range of finishing options, you can experience elevated uptime and output. That’s where Canon’s varioPRINT 140 series QUARTZ, a next-generation compact production press powered by DirectPress technology, shines. Watch it at work in the video below.
Product Disclaimer
  1. Prices and specifications subject to change without notice. Actual prices are determined by individual dealers and may vary.
  2. Capacity based on 20 lb. Bond.
  3. Maximum capacity is for Letter-sized sheets with ePIM and Duo Tray option in trays 3 and 4.
  4. See Customer Expectations Document and Approved Media List for detailed media specifications and supported media detail.
