varioPRINT 6000 series TITAN
VARIOPRINT 6000
As low as $0.00
Out Of Stock
  • Print speeds up to 320 letter ppm
  • Support of media up to 13.8" x 19.7" and 110 lb. cover
  • Gemini Instant Duplex Technology enables one-pass, two-sided printing
Printer Overview
Boost Production with varioPRINT 6000 series TITAN Digital Presses
The varioPRINT 6000 series TITAN monochrome digital presses deliver segment-defining black-and-white printing and eco-friendly features. Innovations and a robust steel build combine to deliver unmatched productivity and reliability. From commercial to financial printing environments, the varioPRINT 6000 Series TITAN has a model to meet your production needs.
PRINT
WITH
THE
POWER
OF
A
TITAN
PRINT
WITH
THE
POWER
OF
A
TITAN
PERFORMANCE
Millions of Prints Monthly
A durable design and impressive uptime make the varioPRINT 6000 series TITAN ideal for high-volume monochrome production printing. Unique Gemini Instant Duplex Technology boosts production by printing both sides of the sheets simultaneously, helping enable ultra-fast speed and benchmark reliability. Combining this with the innovative Copy Press technology helps the varioPRINT 6000 series TITAN deliver breathtaking productivity for digital black and white printing of up to 10 million letter impressions per month.
varioPRINT 6000 series TITAN durable design
varioPRINT 6000 with PRISMAsync Print Server
Maximum Uptime
Gemini Instant Duplex technology combines high-volume duplex printing performance with the production efficiency of the PRISMAsync Print Server to maximize the uptime of the varioPRINT 6000 series TITAN digital presses. Thanks to PRISMAsync, the varioPRINT 6000 offers up to 8 hours of job scheduling and remote management tools for workflow automation to support hours of unattended printing.
Gemini Instant Duplex Technology, Copy Press and ScreenPoint
Innovation Driven Quality
The varioPRINT 6000 series TITAN is driven by unique technologies — Gemini Instant Duplex Technology, Copy Press and ScreenPoint. These innovations combine to deliver simultaneous double-sided black-and-white printing for near perfect registration and sharp, elegant, matte print output.
Sustainability Goals
Designed for Sustainability
varioPRINT 6000 series TITAN digital presses are designed to meet the sustainability goals of our customers. These presses feature low energy consumption, virtually no toner waste and generate minimal ozone emissions and heat output. Copy Press technology boosts energy efficiency, while solvent-free toner eliminates the need for sophisticated air filters and specially ventilated work areas.
SIMPLIFY WORKFLOW, EMPOWER YOUR TEAM
The PRISMAsync family of print servers helps streamline production by making printing operations more intuitive and uniform. Managing and running jobs through multiple presses more easily than ever before. Plan-ahead up to 8 hours of production with the Job Scheduler. The intuitive interface helps operators easily manage jobs from composition to media to production to finishing—even those inevitable last-minute changes. PRISMAremote Manager features a dynamic user interface that allows Apps to be dragged, dropped and scaled to create a customized view with only the information your operators require!
image of PRISMAsync on computer
PRISMA Workflow Solutions
PRISMA is Canon's family of workflow solutions designed to help optimize your print operation while positioning you for further growth. PRISMA workflow solutions include on-premise and cloud-based solutions to simplify job submission, accelerate document preparation, facilitate order and production management as well as tools designed to help support performance monitoring, cost allocation and color management.
WHITE PAPER IN-FINISHED PRODUCT OUT
Keep more jobs in house-and with less effort-by selecting from an extensive array of Canon and third-party in-line finishing options that offer punching. Wire-binding, booklet-making, and trimming. Inline feeding and finishing options are essential for print environments to achieve maximum versatility and flexibility when producing high-quality, professional print applications including brochures, manuals, reports, and books, among other materials.
Image Alt Text
View Full Technical Specs PDF
Main Unit Specs
IMAGING TECHNOLOGY
Copy Press and Gemini Duplex Technology from Canon.
ENGINE RESOLUTION
LED, 600 x 1200 dpi, 85/106/125/141/180 lpi
PRINT SPEED
6330/6270/6220/6180Footnote1
Up to 320/266/216/177 (Letter)
Up to 167/143/116/95 (Ledger)
OPTIMAL MONTHLY PRINT VOLUME
1,000,000 - 10,000,000 (Letter images)
USER INTERFACE TYPE
Intuitive 15" touch screen user interface
CHARACTERIZATION
Multiple and customizable views help ensure a productive and controlled workflow. Queue Manager, Job Scheduler, system status overview, multiple queues, job definition and selection options, bundle printing
PAPER HANDLING
Maximum: 12.6" x 19.2" (320 mm x 488 mm)
Minimum: 8" x 8" (203 mm x 203 mm)
Optional: 7" x 10" (178 mm x 254 mm) with Statement-sized option
PAPER SIZE
8" x 8.2" (203 mm x 208 mm) to 13.8" x 19.7" (350 mm x 500 mm) with optional PIM Flex–A1
PAPER INPUT (STANDARD)
4 paper trays (2 x 1700 sheets + 2 x 600 sheets)
OPTIONS
Second and third paper input module (standard size or PIM Flex-A1)
MAXIMUM PAPER CAPACITY
24,000 Letter sheets from 4 standard and 8 optional paper trays (20lb Bond) with Duo Tray Option to increase Letter input capacityFootnote2
PAPER WEIGHT
Plain Paper: 13 lb. Bond to 110 lb. Cover (50 to 300 gsm)
Coated Media: 20 lb. Bond to 90 lb. Cover3 (80 to 250 gsm)
Light-Weight Media: 12lb Bond to 13 lb Bond (45 - 50 gsm) with the optional light-weight media module
HIGH CAPACITY STACKER
Capacity 6000 sheets - 20 lb bond (80 g/m2)
(2 stacks x 3000 sheets each).
FUNCTIONALITY
All paper input sizes and weights are supported including tabs. Supports OEM output to third party finishing solutions
OPTIONAL
Up to 3 Stackers can be configured inline, offering 18,000 sheets output capacity
FINISHER
Capacity 4000 sheets letter 20 lb Bond (80g/m2)
SIZES
The following paper sizes can be stacked (and stapled): all (custom) sizes between:
- long edge:10.8" to 12" (275 to 306 mm )
- 12" - short edge: 8.2" x 8.7" (208 to 220 mm)
- Number of staples in a set: 1 or 2
STAPLING POSITIONS
Corner portrait or landscape, side
STAPLING CAPACITY
100 sheets plain paper (20lb Bond)
NETWORK HARDWARE
10/100/1000 Mb, 1Gb Ethernet
NETWORK PROTOCOL
TCP/IP (LPR/LPD, socket), SMB static/auto IP (via DHCP) SNMP v1-v3 (printer MIB, private MIB, Job monitoring MIB), IPP
SUPPORTED PDLS (SUPPORTS AUTOMATIC LANGUAGE SENSING)
APPE (Adobe® PDF Print Engine)
Adobe® PostScript® 3TM/ streaming PostScript®
PPML/GA Level 1
PPML versions 1.5,2.1 and 2.2
PDF 1.7
PCL 6
Xerox® PPP support
IPDS(options)
Instant switching from IPDS or SRA PCL6 to PostScript 3/PDF/PCL 6
Streaming behavior for all PDLs
RESOURCES
File Name
PRISMAsync Print Server Brochure
Date
11.05.25
File Size
26.5 MB
File Name
varioPRINT 6000 series TITAN Brochure
Date
01.14.26
File Size
22.3 MB
Price and specifications are subject to change without notice. Actual prices are determined by individual dealers and may vary.
File Name
varioPRINT 6000 TITAN Specification Sheet
Date
03.02.26
File Size
3.1 MB
Sort By:
Canon varioPRINT 6000 Series TITAN - Snapshot
Untitle Video
To enhance the productivity of your print shop, you need technology that can help handle everyday tasks with ease. Canon’s varioPRINT 6000 series TITAN revolutionizes monochrome printing, helping you to deliver jobs efficiently on a wide range of media with excellent quality and minimal environmental impact. Watch this video to see how this dynamic device has been built to last.
Product Disclaimer
  1. varioPRINT 6330 speed model available only in TITAN standard and TP TITAN models.
  2. Maximum capacity of Letter-sized sheets based on 3 Paper Input Module (PIM) configuration including Duo Tray in all supported trays.
Prices and specifications subject to change without notice. Actual prices are determined by individual dealers and may vary.
