VB-H47
Discontinued
- 20x Optical Zoom with Fast and Precise Pan/Tilt Mechanism
- 2.0 Megapixel Sensor (Native 1920 x 1080 Full HD Resolution) up to 60 FPS
- Updated 1/2.8" type CMOS type CMOS Sensor with Superb Low Light Performance
- Enhanced Presets That Include PTZ Positioning and Video Settings
- Advanced New Image Processor Helps Maximize Image Quality and Minimize Power Consumption
- Area Specific Data Size Reduction and Motion Adaptive Noise Reduction
- Wide Dynamic Range (WDR)
- Simultaneous Streaming of H.265. H.264, and M-JPEG Codecs in Multiple Resolutions
- 2-way Audio supporting both AAC-LC and G-711 Audio formats
- On-Board Video Analytics and Versatile Functions
- ONVIF Profile T Conformant
- Built-in SD Card Slot with Enhanced SD Card Functionality
- Various Power Options (12 V DC and PoE IEEE 802.3af)
Terms
Service
Eligible Products
Offers, Orders and Returns
Enrollment
Payment and Cancellation
Changes to Terms
Streamline your experience with MyCanon Account!
Product registration information for this product will be added to your Account when your items ships.
In the box
- VB-H47 Main Body
- Power Connector
- Installation Guide
- Warranty Card
Return Policy
The Canon Online Store will accept, for return or exchange, defective or unopened merchandise purchased at the Canon Online Store, subject to the exceptions and timeframe for returns listed below: All merchandise returned to the Canon Online Store must be in the original packaging with all original items (such as manuals, cables, etc.) accompanying the merchandise and a copy of the invoice/packing slip included to be eligible for return or exchange. Shipping and handling fees from your original order will not be refunded, unless the merchandise is determined by the Canon Online Store, in its sole discretion, to be defective.
See our Return Policy for complete information.
Return Policy
Overview
The VB-H47 inherits the high performance features of previous Canon PTZ (Pan-Tilt-Zoom) cameras, but includes significant improvements with a new image sensor and processor. Ideal for the security and surveillance markets, the VB-H47 contains a new 2 megapixel high sensitivity image sensor (1920 x 1080) and 20x optical zoom lens which provides exceptional low light performance with a minimum subject illumination level of just 0.02 lux at 1/30 shutter speed. The new image processor provides high quality video streaming, including H.265, H.264, and MJPEG video formats up to 60 fps.
Other improvements include High Dynamic Range (HDR) that combines frames of different exposure, giving the user even exposure over the camera’s field of view. Along with improved video, the VB-H47 also now supports the AAC-LC audio standard for improved audio quality up to 48 kHz at 128 kbps.
An available simple camera setting allows users to instantly set their camera up to fit their application such as Motion Priority, Low Light Visibility, Depth Priority, and Data size reductions.
Various power sources include Power over Ethernet (PoE), 12V DC, as well as the optional PA-V18 ac adapter. The VB-H47 also supports ONVIF profile T to allow for quick integration of the new camera features with 3rd party video recorders. With all the new features and performance enhancements, the Canon VB-H47 continues the Canon tradition of exceeding the demands of the security and surveillance market.
Features
Remarkable Low Light Performance
The VB-H47 features a new 1/2.8 CMOS sensor. With this high sensitivity sensor, minimum subject illumination performance has been drastically improved from previous generation model, to 0.02 lux (VB-H47) from 0.05 lux (VB-H45). As a result of improved minimum subject illumination performance, even in dark scenes, images can be recognized clearly in detail with less noise.
- Monitoring Illuminescence: .02 lux
- Maximum Wide Angle
VB-H45
VB-H47
New Engine Dramatically Enhances Video Streaming
- The VB-H47 features a new video and network engine that enables delivering videos at maximum 60 fps for Full HD video.
- In addition to the new support for H.265 with compression efficiency higher than H.264, the compression efficiency has also been greatly improved for H.264, compared to current models resulting in a significant reduction in the delivery bit rate.
New Engine Dramatically Enhances WDR Performance
- The new engine of the VB-H47 has been utilized to install the new WDR function which uses multiple frame synthesis.
- In scenes where there is a large difference in brightness within the angle of view, it is possible to shoot from high brightness areas to low with higher visibility than the previous generation models, which is effective in improving the accuracy when analyzing video.
VB-H45
VB-H47
20x Optical Zoom Auto Focus Lens
Features 20x optical zoom lens and enhanced digital zoom function. Can digitally zoom up to 40x while maintaining image clarity.
Full Wide
20x Optical
20x Optical + 2x Digital
New ONVIF Profile G and Profile T Support
AAC-LC High Quality Audio Coding Support
In addition to the G.711 μ-law used in current models, the new models support the international standard AAC-LC for higher quality speech coding. AAC stands for Advanced Audio Coding. It has a higher compression efficiency than G.711 and enables the conversion of wide frequency and the rise and decay in the original sound into high quality digital audio signals with greater fidelity.
Intelligent Functions
- Moving Object Detection
- Abandoned Object Detection
- Removed Object Detection
- Camera Tampering Detection
- Passing Detection
- Intrusion Detection
- Volume Detection
- Face Detection
CAMERA
Night Mode: 1.0 m (3.3 ft.) – infinity (W), 1.5 m (4.9 ft.) – infinity (T)
SERVER
System frequency 50 Hz: 1, 2.5, 5, 6.25, 10, 12.5, 25, 50 fps
– H.264: Max. 10 Clients
– H.265: Max. 10 Clients
Number of Preset Tour Route: Max. 5
INTERFACE
– Class 10 recommended.
OPERATING ENVIRONMENT
STORAGE ENVIRONMENT
POWER SUPPLY
POWER CONSUMPTION
Max. approx. 9.7 W (240 V AC)
