VB-M741 LE
Discontinued
- IP66 Rated Enclosure and Built-in Heater
- Built-In Infrared Illuminators for Surveillance in 0 Lux
- Canon's Unique Remote Adjustment Function for Easy Post-Installation Changes to the Camera's Zoom
- Canon 2.4x Optical Zoom Lens with 113.4° Angle of View
- 1.3 Megapixel High-Sensitivity CMOS Sensor with Exceptional Low-Light Performance
- Advanced DIGIC DV III Image Processor to help Maximize Image Quality
Terms
Service
Eligible Products
Offers, Orders and Returns
Enrollment
Payment and Cancellation
Changes to Terms
Streamline your experience with MyCanon Account!
Product registration information for this product will be added to your Account when your items ships.
Return Policy
The Canon Online Store will accept, for return or exchange, defective or unopened merchandise purchased at the Canon Online Store, subject to the exceptions and timeframe for returns listed below: All merchandise returned to the Canon Online Store must be in the original packaging with all original items (such as manuals, cables, etc.) accompanying the merchandise and a copy of the invoice/packing slip included to be eligible for return or exchange. Shipping and handling fees from your original order will not be refunded, unless the merchandise is determined by the Canon Online Store, in its sole discretion, to be defective.
See our Return Policy for complete information.
Return Policy
Overview
When an application calls for an out-of-the-box solution able to deal with zero light conditions and harsh environments - trust Canon's VB-M741LE Infrared Outdoor Fixed Bullet Network Camera. This IP66 rated model is equipped with a built-in Heater and four infrared (IR) illuminators – two designed to maximize wide-angle shots and two for telephoto shots – that can be automatically activated in night mode to help capture brighter images right up to the edge of the screen across the entire field of view. This is combined with an ultra-wide 113.4° angle of view and an infrared (IR) corrected 2.4x Optical Zoom lens with Super Ultra-Low Dispersion elements to help reduce chromatic aberrations and an anti-reflective infrared (IR) lens coating to help improve IR sensitivity and reduce ghosting and flaring in night mode for clean, sharp images.
The cameras advanced optics, combined with a 1.3 megapixel high-sensitivity CMOS sensor and Canon's advanced DIGIC DV III Image Processor help to ensure exceptional image quality and low-light performance. The VB-M741LE is also equipped with a powerful Canon DIGIC NET II Processor for simultaneous streaming of H.264 and M-JPEG video streams in multiple resolutions for versatile monitoring and recording (including monitoring on compatible smart phones and tablets).
The VB-M741LE also comes loaded with an array of image-enhancing technologies. Auto Gain Control allows users to determine the fine balance of video brightness and low noise, while Canon's new Haze Compensation automatically enhances contrast and maximizes image quality when fog, haze, or smog are present. Area-Specific Data Size Reduction (ADSR) gives the user the opportunity to save bandwidth by applying different levels of compression to specific areas within a camera's field of view, and a selection of On-board Video Analytics are available including Moving Object Detection, Removed and Abandoned Object Detection, and new Scream and Intrusion Detection capabilities.
Canon has also simplified the integration and management of the VB-VB-M741LE. The camera includes Canon's unique Remote Adjustment Function which allows an installer to reposition the cameras zoom position remotely after the camera is installed. ONVIF 2.4.2 Profile S and Profile G conformance facilitates quick and easy camera integration into a security system, while the new Canon Camera Management Tool (CCMT) permits a user to configure and manage most Canon devices from a single screen.
The VB-M741LE also offers multiple power options including 12 VDC, 24 VAC, PoE, and PoE+ which allows for single-cable installation to power both the camera and heater (extreme climates may require additional power). Two-way audio communication between the operator and camera locations is also possible when a speaker and microphone are connected to the camera.
For high-quality imaging day or night choose the clarity and quality of the VB-M741LE Fixed Outdoor Network Camera.
CAMERA
0.001 lux (F1.2, shutter speed 1/30 sec., when smart shade control is off, 50IRE with IR lamp off)
Night Mode: 0.3 m (12 in.) - infinity
Daylight Fluorescent/White
Fluorescent/Warm Fluorescent/Mercury
Lamp/Sodium Lamp/ Halogen Lamp
Manual: One-shot WB/R Gain/B Gain
Auto: 3 Levels
Manual: 7 Levels
Auto: 3 Levels
Manual: 7 Levels
SERVER
H.264: 1/2/3/5/6/10/15/30 fps
user (level of control varies depending on user)
Cropping sizes: 640 x 360/512 x 288/384 x 216/256 x 144/128 x 72 640 x 480/512 x 384/384 x 288/256 x 192/128 x 96
INTERFACE
OPERATING ENVIRONMENT
AC, PoE+: -50°C - +55°C (-58°F - +131°F)
DC, PoE: -10°C - +55°C (+14°F - +131°F)
Start-up Temperature Range (including direct sun exposure)
AC, PoE+: -30°C - +55°C (-22°F - +131°F)
STORAGE ENVIRONMENT
POWER SUPPLY
POWER CONSUMPTION
(100 V AC) Max. approx. 12.8 W (240 V AC)
OTHER
- Length when joint fully extended (D): 384 mm (15.12 in.)
Product Disclaimer
“ONVIF” and
are trademarks of ONVIF Inc..
