VB-S32D
Discontinued
- Compact Micro Dome PTZ Camera with High Quality Full HD Video
- Genuine Canon 79° Angle of View Lens with 3.5x Optical Zoom
- 2.1 Megapixel (Native 1920 x 1080 Full HD Resolution)
- Enhanced Presets That Include PTZ Positioning and Video Settings
- Advanced New Image Processor Helps Maximize Image Quality and Minimize Power Consumption
- Area Specific Data Size Reduction and Motion Adaptive Noise Reduction
- Smart Shade Control and Auto Gain Control Limit
- Simultaneous Streaming of H.265, H.264, and M-JPEG Codecs in Multiple Resolutions
- On-Board Video Analytics and Versatile Functions
- Supports AAC-LC and G-711 Audio Formats
- ONVIF Profile T Conformant
- Built-in microSD Card Slot with Enhanced SD Card Functionality
- PoE IEEE 802.3af Compliant
Terms
Service
Eligible Products
Offers, Orders and Returns
Enrollment
Payment and Cancellation
Changes to Terms
Streamline your experience with MyCanon Account!
Product registration information for this product will be added to your Account when your items ships.
In the box
- VB-S30D Mark II Main Body
- Installation Guide
- Warranty Card
- Template
- Safety Wire
- 1x M4 Screw for Wire
Return Policy
The Canon Online Store will accept, for return or exchange, defective or unopened merchandise purchased at the Canon Online Store, subject to the exceptions and timeframe for returns listed below: All merchandise returned to the Canon Online Store must be in the original packaging with all original items (such as manuals, cables, etc.) accompanying the merchandise and a copy of the invoice/packing slip included to be eligible for return or exchange. Shipping and handling fees from your original order will not be refunded, unless the merchandise is determined by the Canon Online Store, in its sole discretion, to be defective.
See our Return Policy for complete information.
Return Policy
Overview
The VB-S32D inherits the high performance features of previous Canon Micro PTZ (Pan-Tilt-Zoom) dome cameras, but includes significant improvements with a new image sensor and processor. Ideal for retail, commercial, and surveillance markets, the VB-D32D contains a new 2.1 megapixel (1920 x 1080) high sensitivity image sensor, 3.5x optical zoom lens, that provides exceptional low light performance with a minimum subject illumination level of just 0.15 lux at 1/30 shutter speed in a compact form factor. The new image processor provides high quality video streaming, including H.265, H.264, and MJPEG video formats up to 30 fps. Along with improved video, the VB-S32D also now supports the AAC-LC audio standard for improved audio quality up to 48 kHz at 128 kbps.
An available simple camera setting allows users to instantly set their camera up to fit their application such as Motion Priority, Low Light Visibility, and Data size reductions. The VB-S32D is powered via Power over Ethernet (PoE) allows for single cable installation. The VB-S32D also supports ONVIF profile T to allow for quick integration with 3rd party video management solutions.
With all the new features and performance enhancements, the Canon VB-S32D continues the Canon tradition of exceeding the demands of the security and surveillance market.
Features
Remarkable Low Light Performance
The VB-S32D features a new 1/2.8 CMOS sensor. With this high sensitivity sensor, minimum subject illumination performance has been drastically improved from previous generation model, to 0.15 lux (VB-S32D) from 0.95 lux (VB-S30D Mk II). As a result of improved minimum subject illumination performance, even in dark scenes, images can be recognized clearly in detail with less noise.
- Monitoring Illuminescence: .15 lux
- Maximum Wide Angle
VB-S30D Mark II
VB-S32D
New Engine Dramatically Enhances Video Streaming
- The VB-S32D features a new video and network engine that enables delivering videos at maximum 60 fps for Full HD video.
- In addition to the new support for H.265 with compression efficiency higher than H.264, the compression efficiency has also been greatly improved for H.264, compared to current models resulting in a significant reduction in the delivery bit rate.
New Engine Dramatically Enhances WDR Performance
- In scenes where there is a large difference in brightness within the angle of view, it is possible to shoot from high brightness areas to low with higher visibility than the current models, which is effective in improving the accuracy when analyzing video.
VB-S30D Mark II
VB-S32D
3.5x Optical Zoom with AF support
Wide
Telephoto 3.5x Optical Zoom
New ONVIF Profile G and Profile T Support
AAC-LC High Quality Audio Coding Support
In addition to the G.711 μ-law used in current models, the new models support the international standard AAC-LC for higher quality speech coding. AAC stands for Advanced Audio Coding. It has a higher compression efficiency than G.711 and enables the conversion of wide frequency and the rise and decay in the original sound into high quality digital audio signals with greater fidelity.
Intelligent Functions
- Moving Object Detection
- Abandoned Object Detection
- Removed Object Detection
- Camera Tampering Detection
- Passing Detection
- Intrusion Detection
- Volume Detection
- Face Detection
CAMERA
Night Mode: 1.0 m (3.3 ft.) – infinity
SERVER
System frequency 50 Hz: 1, 2.5, 5, 6.25, 10, 12.5, 25 fps
– H.264: Max. 10 Clients
– H.265: Max. 10 Clients
Number of Linked Events: 2
Linked Event Conditions: OR, AND (whether or not there is a sequence to events)
